Everything posted by Darius43
MTK Class 27 started this afternoon. Plan is to use a Lima Class 33 chassis with new wheels and motor from Peter’s Spares. First task is to trim the bottom chassis edge from the side parts and glue them together. I held them against a straight edge whilst doing this to keep them true. The fit of parts wasn’t bad considering it is an MTK kit. I used tape to hold the cab ends in place whilst the glue set. The Peter’s Spares replacement wheelsets are light years better than the Lima pizza cutters. Gone are the traction tyres - I reckon there’s plenty of weight in this kit. Some trimming and fettling of both will be needed for the body to fit the chassis. Cheers Darius
This type of doom laden story keeps popping up. Here’s a 1995 version. Only time will tell… Also helps authenticity wise if the video cover picture actually shows Hornby products instead of a mixture of US and European models. Cheers Darius
2600 Class DMU kinda sorta not really Repainted Bachmann Class 150. Fair to middling effort but the cab front is way off. Not Murphy Models… All for £250 plus postage. Cheers Darius
- 703 replies
- 18
Architectural model makers typically charge £1,000 to £2,500 for a model of size 200x200x250mm. Those are professional rates for businesses with overheads etc. but do not underestimate the time taken to produce a model of the quality that you exemplify in your work, which is superb by the way. In determining a total fee you will need to account for the time taken researching the station building(s), gathering whatever photos and drawings are available and then planning how the model will be constructed even before building commences. Based on your experience of the time taken to complete your models and a suitable hourly rate you would be surprised at how quickly the fee mounts up. Add to that the model topography issues and the shipping box etc. As to a suitable hourly rate I would suggest no less than £75/hr (or the equivalent in Euros) and, as you are clearly a talented modeller, probably more than that. At the end of the day the fee may be more than your prospective client is prepared to pay but I would advise you stick to your guns, so to speak. Another facet to building models to order is that it may cease to be “fun”, especially if the client wants to set a deadline or orders further models. This can leave you with little time for your own modelling and lead to stress, especially if the client wants changes or is not happy with something. I have built a few models to order and it was not a pleasant experience. Consequently, I now decline all requests to do so and only build the occasional model for friends for free. Cheers Darius
I ordered two and they are on my order along with six green ones. Cheers Darius
The flight path to Denver from Dublin took us due north so I was able to get a few snaps of places visited many years ago… Carlingford Lough. Lough Neagh foreground With Aldergrove Airport centre - just below the cloud. You can also see the former Langford Lodge airfield. North coast - Portstewart and Portrush. Cheers Darius
I'm now in Dublin en route to Denver having cleared US immigration. In the lounge in time for lunch Cheers Darius
Back to the B Class locomotive. I fitted a resin Sulzer powerplant to remove the see through effect and squeezed in DCC sound courtesy of Roads and Rails. Cheers Darius
Centre coach given the same treatment. Cheers Darius
Built over the past few days using the Silver Fox resin body and a cut down Hornby Railroad Class 55 chassis. Cheers Darius
- 3 replies
- 11
Wipers, cab ladders and light weathering to chassis. Cheers Darius
I pre cut the curves on pieces of Tamiya masking tape and apply them to suit. Cheers Darius
Window glazing fitted. All those side windows make the inside look rather empty so I have ordered a resin engine to fill the space. Cheers Darius
I guess paint dries quicker down here on the south coast. Cheers Darius
Silver Fox models B Class started. Hornby Railroad Class 55 chassis (as recommended by Silver Fox) modified to fit. I had to thin* the inside faces of the Silver Fix resin body with a Dremel so that the chassis would actually fit. The tablet catcher recesses below the cabside windows were a bit shallow so I drilled out the lower parts and re-made them using plasticard sheet. I cut away the Deltic bogie sides and glued in place the Silver Fox replacements. I sanded* the rear faces of the replacement sides to provide a decent surface for glueing. I glued strips of plasticard to the inside faces of the resin body to act as chassis supports. Body fitted to chassis - it’s an interference fit at the moment. Next tasks are further cleaning of the body and scratch building the tanks that sit between the bogies - the Silver fox ones aren’t that good. Cheers Darius * I always wear a respirator when sanding resin and keep it on until all the resin dust has been cleaned up.
