Darius43
Everything posted by Darius43
  1. Still a bit too neat and tidy - needs some spoil spills, sleeper stacks, random bushes etc. Photos of the site show random concrete slabs, so I placed these over the omega loop pits of the point control system - to protect them. Cheers Darius
  2. Ballast and static grass this weekend. Cheers Darius
  3. Thanks Leslie - need to build some more Cheers Darius
  4. Quarryside scenic background completed. Cheers Darius
  5. There’s always an exception… MED 23 pulls away from Whitehead with a service to Belfast York Road. MED 19 sweeps through Trooperslane station with a York Road, Belfast - Whitehead local service. Cheers Darius
  6. Module in place. Cheers Darius
  7. Sceniked… Cheers Darius
  8. Second scenic module takes shape. Cheers Darius
  9. Reading this it’s not that puzzling why nobody gives a d….. or says thanks. Cheers Darius
  10. Sorry to see this layout disappear. It was an evocative display for your amazing locomotives and rolling stock. Cheers Darius
  11. And some grass to finish. Cheers Darius
  12. After getting plastered, we get stoned. Cheers Darius
  13. Base colours applied. Once this is dry, rather a lot of spoil and gravel needs to be affixed. Cheers Darius
  14. Now running on the new (under construction) layout. Cheers Darius
  15. Hot wire cutter used to sculpt the polystyrene. Then we get plastered. The slope at the right hand end is too steep so I’ll re-profile it later. Re-profiled. Cheers Darius
  16. Scenic element made from expanded polystyrene packaging and card stock for the roadway. I’ll let the glue set overnight and then sculpt it with a hot wire cutter. Cheers Darius
  17. No busses on this bridge… Dump trucks are repainted Oxford Diecast. Cheers Darius
  18. Bridge painted and weathered. Cheers Darius
  19. Quarry road bridge constructed using hardboard, plywood offcuts and card stock. Cheers Darius
  20. Come on IRM - where are those Jeeps? Cheers Darius
  21. Water tank made from card and plasticard. Cheers Darius
  22. CAF 3000 unit now running. The unit was made using CMAC 3D printed body shells on modified Bachmann Class 170 chassis. Cheers Darius
  23. Spoil loading bank painted and weathered. Cheers Darius
  24. Spoil loading dock constructed using 2mm card stock. The dock structure has now been coated with diluted pva prior to painting. Cheers Darius
  25. MED now running nicely. Added pickups to the trailing bogie of the power car to improve things. Cheers Darius
