Everything posted by Signal Post
Yes your video above (125 and A3R) are playing perfectly. Enjoy the benefits of DCC, I personally think that DCC sound is great on shunting type layouts.
Delighted to hear that you got it sorted.
Sean Moncrieff on Newstalk did a piece on this very topic yesterday and decided to interview someone who knows what he is talking about, namely railway historian and writer Jonathan Beaumont (aka @jhb171achill of this parish). https://www.goloudplayer.com/episodes/the-history-of-irish-railways-N2IyMDYzZWMyODA3MjVhN2VhYjZhNzk5ZmVjOWQyZG An informative talk and I suspect that Jonathan's modesty precluded him posting the link here himself.
One other thing that you may wish to try is (with the blanking plate installed) place it on a DC layout (or rolling road) and bring up the power whilst checking the directional lights on the loco, they should be illuminated at a reasonably high power setting even if the motor has burned out, if they are not showing then the problem is likely to be in the circuitry or wiring of the loco (as @irishthump has mentioned above). Might also be worth trying the blank plate from your other 121 (No. 132), this would rule damage to the original blank plate (which I understand was installed at the time of the incident) from being the problem, it's unlikely that it is a blank plate problem but for the sake of a few minutes work might be worth checking.
I am sure that @DJ Dangerous did not mean to cause any offence, however I think it is very unfair to suggest to any member of the forum that they should desist from posting (unless they are being abusive or generally straying outside the norms and guidelines for posting on a forum, which is more a matter for the moderators than for us mere mortals). We all have our own aspects of the hobby that most interest us greatly and equally other areas that are of less interest to us. I for one have watched the progress of this wonderful layout from inception to exhibition display with great interest and was delighted to get the chance to view it live last weekend at the Wexford show and to get to meet @Noel and his glamorous assistant who were both most welcoming and helpful in showing me the workings of it. In relation to the criticism above of the posts lacking "newness" I could not agree at all, whereas there were no new developments in the layout per se, the story of the "life" of the layout making it's first appearance at exhibition and the story of exhibitors experiences in travelling to and exhibiting at the show, together with an outline of plans for the future expansion were, in my opinion, both interesting and newsworthy for the folks involved in our hobby. In conclusion let me say a big thank you to @Noel for creating and displaying this wonderful layout and for allowing us to see your progress through your posts on this forum. @Noel KEEP POSTING PLEASE!
Looks great, can't wait to see this layout in Wexford tomorrow! Safe journey.
Thanks for that Darius, it looks like a fabulous layout. I was fortunate enough to make a visit to the Allypally show a few years ago, if you think your travels to it were convoluted, mine involved a drive to Dublin Airport, flight to Heathrow, tube and shank’s mare to Allypally in the morning and vice-versa that afternoon……
Lovey photos Darius, thanks for sharing. Do you by any chance recall the name of the second dockside layout (photo 21 onwards)? It seems like a massive and unusual layout, was it OO?
You mentioned that you are new to DCC, so one of the first things that I would check is do the lights turn on or off? If not then before you start into resets etc could I ask what address you are using for the loco? Have you changed it (using your programmer)? It’s default value as shipped should be 3 (sometimes shown as 03 or 0003). If you have changed it (eg to 0071 ) and it has not responded to any commands then try using address 0003 (or 03 or simply 3) on the Hornby Elite in case the decoder has not changed address correctly, and see if there is any response from the loco (will lights turn on and off, will it move etc). All of this can be done with the loco on the normal running track, only if you need to proceed to the more advanced stuff (as described by the guys in the posts above) will you need to use a programming track.
Signal Post replied to Patrick Davey's topic in Irish Model Layouts
That's a wonderful layout Patrick, I've watched quite a few model railway videos over the years and yours of Brookhall Mill are amongst the best, many others have equally stunning buildings and landscape etc, but your videos take things to a new level largely because of the wonderful music that fits in so well with the video photography. I was a little disappointed when I read your introduction to this video that there would be none of your fine music to accompany it, until I watched and listened to it.....wow, what a masterpiece from the first sounds of the river onwards....This has now gone to the top of my list of favourite model railway videos. Very well done and keep up the good work! -
power going to "dead" track
Signal Post replied to derek's question in DCC, Electrics and Electronics
The photos are very useful (well done on your scenic work by the way), firstly they seem to confirm the absence of DCC track spring wires from the points (as suggested by murrayec above). I’m not sure how familiar you are with these springs but they are used to convert Hornby points for DCC, the spring clips are seen quite clearly in the photo below next to the fingers, but I don’t see any sign of these on your points. So hopefully that eliminates one of the possible causes of your problem and leads to the next likely cause, here is what I think is happening: Hornby points use a spring clip attached to the switch rails (also known as switch blades), this spring clip keeps the switch rail tight to it’s adjacent main rain when the points are set for that direction, this is for two purposes, firstly so that the wheels run smoothly over the points without de-railing and secondly, since the switch rail takes the current from the rail that it is in contact with and feeds it to the required rail leading out of the points, in the diagram below the current goes from point C via the blue switch rail in the diagram to point D with the points set as shown for the main line. When the points are set for the siding current flows from point E via the green switch rail to point F. With the points set as shown above for the main line the green rail is away from its adjacent main rail at E and because of this should be disconnected from track power (Broithe above refers to this as the disconnected rail). What appears to be happening on your layout is that the “green” rail is physically moving away from the fixed rail but is remaining electrically connected to it, probably due to the spring clip touching it. I have drawn a diagram of a cross-section of the points between points C and D, Fig 1 shows the points set for the siding with the green rail held in contact with rail B by the spring clip below it. Fig 2 shows the points set for the main line , the green rail has moved away from the black one and it is electrically disconnected from it (this is how it should be). Fig 3 shows what I suspect is happening on your layout where the green rail is physically away from the black rail but it remains connected to it electrically by way of the metal spring clip. Fig 5 (don’t ask me why I didn’t label it as Fig 4!) shows an exploded view of the clip (coloured red), I suspect that it may have been bent very slightly upwards, this could have been caused by ballast hardening immediately underneath the clip and preventing the clip from being pushed down as the switch rail moves above it thereby distorting the clip somewhat. The solution to this would be to remove (most) of the ballast from directly below the clip. Having done this then press very gently on the clip so as to ensure that there is no connection between the switch rail and the clip and then try running a loco on the main line (anywhere on the main line will do, it doesn’t need to cross the points) and see if the loco in the loop moves, you may need to press the clip on both of the points (i.e. at opposite ends of the loop) at the same time (if both points have been similarly affected) whilst simultaneously using the controller, this will probably require a huge amount of dexterity or the aid of a pretty assistant! If that is successful but the problem continues when you are not pressing gently on the clip then the outermost part of the clip (I.e. the free end) will need to be bent back into position, this will require great care as the clip still needs to be tight when the rail is set for the siding, possibly a paper clip or similar placed under the “hump” of the spring (without bending it) whilst gently pressing the free end down a little, it is likely that the amount of movement required will be very small. Hope this is of some help. -
Can you confirm that when you have both points set for the outer mainline (i.e. the black track in the diagram) that a train will run around the complete oval without entering the red loop and that this will work in either direction (i.e. if you reverse the direction of travel by using the switch on the controller) without any problem affecting that train/loco? That may sound a bit complicated, what I mean is if you send a train from the "bottom" of the diagram through the points that you have labelled as "L/H Point" along the single black line in the diagram past point X then through the "R/H Point" and on up to the top of the diagram and then change the direction of travel (with the controller) and travel in the reverse direction all the way from top to bottom? Ideally if you could put up photo of both L/H and R/H points points this might be a help. Also do you know if the points are Hornby or a different brand? -
A very interesting and enjoyable evening at the museum, many thanks to yourself and your friends there for putting it on. A pity I wasn't able to join ye in Duffy's afterwards unfortunately an early start this morning precluded that (work, the curse of the drinking classes). Your idea about future gatherings sounds like like a good one...
