BosKonay
Moderators
Everything posted by BosKonay
  1. Nice. Will give that a go! Thanks!
  2. Looks super effective! Any particular card type?
  3. And yes, as part of the adjustments to the points i remove the springs and cut the ends off the tie bars.
  4. The motors are Cobalt Digital from DCC concepts. The motor itself it digital so it plugs directly into the bus and is programmable with an address. It also has connectors for additional switching like signals as well as frog polarity. In terms of positioning there is a template they supply that you place under the point and it lines up all the drill holes. I'm using their double sided foam sticky pads to fix to the board. It's at least twice as quiet as screwing them in. Using the template, you don't need to worry about centering. It works perfect first time They are about half the physical size of the tortoise, don't need additional cabling or accessory decoders and have a lifetime guarantee.
  5. Looking amazing! Did you use card for the hard standing ?
  6. Looks great! Which timbers are they? (Which manufacturer/supplier)
  7. Cheers Anthony
  8. Yep, and now I've a sore back, strained eyes but two dozen fully programmed working points
  9. No escape from the filthy stick :)
  10. hehe, 'some' trains ran clean Just look at most of the RPSI stock, even B141 That said, a little frame and brake dirt is never a bad thing :)
  11. I'm very impressed by them. I seem to have a few from a batch that are a bit dicky (they wont accept an address). But otherwise they are (relatively) tiny, very powerful, very quiet, and include frog polarity switching, and two additional switches as standard (for if I ever get around to adding signals!). Best of all, the motor incorporates a decoder, so its' literally two wires to the motor and you are done! I'd definitely recommend them.
  12. No where near brave or competent enough for that yet Merlin I actually found on ebay! About two years ago, iirc!
  13. Today was mainly about Point Motors 16 More to program and install tomorrow
  14. Very very tasty Heirflick!! Lovely shade of blue!
  15. If anyone else has done 85, please post up some photos (or videos!)
  16. https://www.youtube.com/watch?v=Aq7bcY9tuao
  17. Has anyone completed Maedbh yet?
  18. RPSI 461 in her Original DSER livery
  19. Meave, Merlin, Dunluce and a great big GM for good measure :)
  20. And, built from a Triang / Honby 2P, No. 74, Dunluce Castle in NCC red
  21. Video of her moving to Cultra
