Mayner
Everything posted by Mayner
  1. Come to think of it I had similar problems with clearances while assembling 4mm Tralee & Dingle 2-6-0Ts & C&L 4-4-0Ts about 30 years ago An article in Narrow Gauge and Industrial Review during the 90s flagged the clearance problems with the Branchlines Tralee & Dingle 2-6-0T loco kits when using wider than P4 profile wheels. Along with the very tight clearance between slidebars/crossheads and coupling rods, it was necessary to move the cylinders outwards with the cyinder covers outside rather than inside the valences as the hub of the Ultrascale wheels originally commissioned for the kit was wider than expected. I used Sharman B profile wheels for 3T & 6T which were narrower in width than the Ultrascale wheels, but cylinder covers placed outside the valences. Sharman wheels were supplied with an integral 14BA steel crankpin, with the top hat crankpin bush secured by a 14BA nut. On outside cylinder locos I normally use an inverted 14BA threaded crankpin bush. If I cannot source a threaded bush, I simply fill with solder and tap. No 3T & 6T were assembled about 30 years ago and still see occasional use! The other bit of skulduggery was performed on a pair of Backwoods C&L 4-4-0T assembled a couple of years earlier, where I cranked the connecting rods on locos fitted with Markits wheels supplied with the kit. I suppose the moral is that it may be necessary to move out the cylinders & valve gear or some other form of distortion on an Irish 3' or 5'3" model assembled with wider than prototypical width wheels. Would be interesting to test the compromises necessary to assemble a 7 or 4mm---5'3" gauge model of an outside cylinder loco like an 800 or Compound with the same or similar wheel profiles to the current generation of rtr models.
  2. Josh. your potentially setting yourself a major research project as apart from information/drawings published in books & held by the IRRS al ot of the information is held by individuals, and specialist groups and museums/histporical societies in the UK. The majority of steam locos and stock used on the GSR & CIE systems were built in Ireland by the GSWR at Inchacore and MGWR at Broadstone rather than imported from English & Scottish builders. New Irish Lines published twice a year by Alan O'Rourke in Sheffield https://newirishlines.org/archive/ regualarly publishes drawings and published a Register of GSR locomotive diagrams between 2014-2016 to compliment Jeremy Clements & Michael McMahons book "Locomotives off the GSR'. Upon formation in 1924 the GSR acquired 587 Steam Locomotives divided into 114 Classes! The Historical Model Railway Society https://hmrs.org.uk/drawings.html collection includes drawings and photos of stock supplied to Irish railways. During the 70s & 80ss and number of model railway magazines published drawings of Irish lcos and stock, may be covered in index in NIL on-line archive At one stage a number of major museums in the UK supplied drawings and photos of locos and stock supplied to Irish companies e.g. Manchester Beyer Peacock locomotove GAs (major supplier to GNR and companies in Ulster, Glasgow photos oof locos supplied by NBL to GSWR, MGWR & others.
  3. Carriage Sheds appear to have had corrugated iron roofs, but the GSR removed the sheds to reduce their Rates Bills during the 1930s I think Schull on the Schull & Skibereen retained its Carriage Shed to the end. The majority of buildings on the Valencia and Kenmare branches including station buildings, goods shed and carriage sheds were in corrugated iron though Cahirciveen engine shed was timber. Westport Quay Goods shed was corrugated iron though the station building was stone. The buildings in the NLI Cahirciveen photo are similar to Kenmare & the goods shed similar to that at Westport Quay https://catalogue.nli.ie/Record/vtls000318850 The Ratio OO Carriage Shed is similar in styling and construction to carriage sheds used at Irish branch line terminals, though usually single track. I usually use Wills Coarse Stone (actually stone laid in regular courses as opposed to random rubble) for buildings buildings like railway goods shed and Wills Corrugated Asbestos for corrugated iron because corrugated iron sheets were usually longer in length and fixed in a more regular manner than the Wills iron sheets.
  4. With laser cutting you can omit the intermediate stage of using an overlay by engraving brick-stonework directly onto the laser cut shell. I produce my own drawings and have used businesses like York Model Making and a local business to do the laser cutting. The GSWR Signal box incl stairs and windows was laser cut by York Model Making, I mitred the corners of the wall panels to minimise joint thickness, roof and ridge tiles are Will Materials. The laser cut windows were basically an expirement, I prefer to use etched window frames on foreground buildings. Westport Mill was laser cut in Ply by a local business, the exposed concrete frame on one layer, the infill panels on another, windows laser cut in plastic. Building painted using "Match Pots" from a home decor shop matched to photos of the original.
  5. Ironically for many year NZ Customs used to charge 5% duty plus GST (VAT) + processing + Bio-Security fees on model railway items with a value in excess of $850US. The duty mainly affected high value items imported from the United States (mainly e-Bay and Accuacraft). I challenged duty being charged on model railway items, being exempt in UK and Europe but chargable in this part of the World. NZ Customs tended to focus on collecting their duties, taxes and fees and not get too hung up on the technicalities of the declaration. Its possible US Customs simply may not have the capability (staff or technology) to process low value parcels following the change in policy. The Irish Customs/An Post and most other countries spent two/three years preparing to implement the 2023 changes to Global Customs Clearance requirements.
  6. Well my intention to spend a hour/half hour in the workshop every evening lasted about two days before being disrupted by a series of family crisis that blew up in both New Zealand and the States last Tuesday. I finally managed to find some time for myself this afternoon and evening. Giving the re-trucked Bachmann Tank Car a test run and working on some projects in the Workshop. Tank car had a shakedown run on a Way Freight while I sat in a chair on our deck looking at alternative options for our kids education, probabably the first time I made the time and sit down and simply watch trains go by in about a year. Tank car ran steadily without the wobbe and occasional de-railments with the origonal cars. Back in the workshop things did no go so well but managed to fit the replacement balcony rails and ladders to the damaged end. Attempts to fit the replacement footsteps by drilling into the existing solebars and tapping 10BA were unsuccessful as the solebars/under frame members turned out to be hollow and incapable of holding a thread when tapped. I got a 2 part filler product capable of heing tapped from the local hobby shop, but the activator was well past its sell-by date with a consistency like treakle. Some success of the small-scale loco front finally finshed E421 to OO a Shapeways (B Lancer) body on a Bull Ant chassis and fitted a DCC "stay alive" decoder salvaged form one of my Large Scale railtrucks, runs find on analogue with an interesting "momentum" effect, but programming function on DCC system bought over 20 years ago no longer appears to work and manufacturer no longer supports particular command station or throttle, so I will probably revert to DC, just need to add some section switches. G617 which has a worm and layshaft drived cobbled up from a pair of Hi Level RoadRunner+ and a TenderRiser sounds like a coffee grinder and stalls all over the place, probably replace the current wheels with wheels salvaged Bachmann diesel bogie wheels to see if it improves pick up.
  7. Interestingly the original version of the WW G (cabsides wrong orientation) was supplied with a simple fold up 21mm N/S chassis complete with 2 nylon worm & gear sets! Even more interestingly Jeremy Fletcher talks about a fold up 21mm gauge gear box supplied with the parts on his article on building the loco on the WW website https://www.worsleyworks.co.uk/Image-Pages/Image_4mm_Deutz-3.htm Photos of Mike Edge (possible pattern for DC G Class) & Jeremy's G Class indicate that at one stage the WW G was supplied with plastic spring and axlebox castings. I still have the original 21mm gauge fold up chassis supplied with my G Class, perhaps some day get around to motorising it with my own drive based on a High Level QuadDriver or more likely a drive designed by Paul. I used a scratchbuilt chassis to power the loco while running in OO, basically two plain strips of brass and commercial turned frame spacers possibly supplied with an SSM J15!
  8. Mayner
    Irm wagons
    It looks like a friend in the States has agreed to adopt James, big challenge if he survived the flight and quarantine would have been James challenging our other four male cats for the Alpha position. CIE Cattle wagons all appear to have been on the traditional Irish timber underframe like Leslie's model, none that I know of on the Triangulated Underframe
  9. The 'coach' in the 1st photo looks like the passenger portion of an ex-West Clare Walker Railcar the second coach some form of railcar conversion with open end balconies. One of the ex-West Clare conversions was used as the Coach on the Bellacorick bog train hauled by a Ruston diesel modified with a hydraulic transmission similar to the second generation Hunslet Wagonmaster. Does anyone know whether the two Clonmacnoise & West Offaly coaches or the ex-West Clare railcar conversions have survived? The biggest challenge of modelling the BNM Peat Energy Division was the sheer scale of the operation on most systems and lack of operating interest basically 15 wagon Merry Go Round trains between the loading points and power stations. The older sod peat systems like Allenwood and Portarlington were a bit more interesting on a smaller scaleand actual shunting taking place at the Power Stations and BNM locos doing the 'main line work" with ESB locos shunting the power stations where individual wagons were unloaded by lifting from their bodies to the top of the power station bunker using overhead gantries. Some of the Horticultural peat systems were more modellable in nature and smaller in scale with wagons (sometimes 4w) unloaded by an end tipper or rotary tipple.
  10. Mayner
    Irm wagons
    Say no more: there is no one forcing anyone to pay an inflated price. Just wait for the wagons to show up on the second hand market, swapmeets or deceased estate sales. As an old work mate used to say there was no barbed wire on the door forcing a guy to spend all his wages in the pub.
  11. My attempt to carve out ½/1 hr daily (modelling) time for myself is largely as a result of a family crisis that arose 18 months ago that left our family split between the States and New Zealand as a result of caring commitments, which left me and the wife on opposite sides of the Pacific with very little free time to pursue our own personal interests and the situation is likey to continue for some time. The only advice I can offer in my late 60s is to make the best of the present time because none of us have a guarantee that things will go as planned, best laid plans of mice and man etc.
  12. The Worsley Works G builds into a nice model and is supplied with a 21mm gauge chassis. Des SSM produced a very nice waterslid transfer set for this loco including legible Duetz makers plates, unfortunately the origonal cabside transfers wore off with handling when I attempted to convert the loco to OO several years ago Although originally motorised with a "Black Beetle" motor bogie re-gauged to 21mm, G611 currently runs on a scratchbuilt chassis powered by a Coreless motor driving a pair of Hi-Level Roadrunner+ gearboxes using a layshaft with a Tender-Riser steo down gearbox. Like my other locos with can or coreless motors and Hi Level gearboxes could never get this loco to reliably operate on DCC, in this case driving each axle with a separate gearbox may have resulted in increased friction and current consumption. Long term plans are to power the 21mm gauge version of this loco with a customised "Quad-driver" arrangement similar to Pauls E401 Class
  13. Started a routine of having a hour/half hour in the workshop after 10 most nights once days duties are done Catching up on large sacle repairs & locating parts to complete other projects. Repairing balcony rails and ladder RGS Caboose 401. Originally bought this 1:20.2 Scale Caboose when I started large scale modelling in 2007 then sold to a local Garden Railway modeller when I realised that Bachmann 1:22 is scale "Big Haulier" stock was more affordable, then bought back in 2017 after the narrow gauge lines in Colorado and realising the massive nature of the locos and stock. One end of 401 had been through the wars and this is the second attempt at repairing the balcony rails and ladder, hopefully she will be good for another few repairs. Last tie round I made a jig for repairing/replacing the ladder, this time I used the ladder and rails from the opposite end to mark out the position of the rungs on a piece of ply, soldered the top and bottpm rungs to one stile, before fixing to the opposite stile and doing a test fit before soldering in the intermediate rungs. Test fit. The roof walkway was also damaged at the same end about 2008 or 9 and repaired with plasticard which has held fairly well requiring some minor repairs. Intermediate rungs are the only new parts soldering took about 15 minutes, phosphoric acid flux and 120degree solder using a soldering station with temp set at max. Everything primed with a grey self etch primer followed by a coat of "Appliance White" aerosol form the local big box DIY store. I'll finish with an aerosol 'clear coat' laquer tommorow and allow the paint to cure for 3-4 days before fitting to 401. Been digging through my stock of J15 spares and found some of the missing parts for the Superheated J15 including the worm for the High Level Load Haulier gear box, but a pair of Sharman Type B profile wheels suitable for a J15, but no 3rd wheelset and an assembled set of J15 mainframes. I bought 2 J15 kits form Paul Greene in 2007-8 with the intention of using one of the locos to replace my original TMD J15 bought in 1986, one of my first attempts at assembling an etched kit, retaining 191 a J15 I assembled about 30 years ago together with the 2 new locomotives and a part built J15 I bought at Expo-EM about 20 years ago. The plan changed over time to build one of the 'new" J15s as a superheated loco with heavier GSR replacement frames, which freed up a set of replacement frames for the original 1986 loco which has Sharman wheels! An early effort it could do with some minor body repairs, but what to do with 5 J15s in the display case particular someone that set out to model the Midland 40 odd years ago? A bit more prosaic a pair of anchor mount tanks on IRCH "Standard" wagon underframe. The tanks are from the IRM "WeedkillerTrain" pack, the chassis my own from LMA wagon chassis. I originally bought the train pack intending to produce an etched Triangulated chassis, but decided to shift to 3D printing after success with the 20T Brake Van prototype. CIE used this form of tank and underframe for Bitumen wagons, but adding the insulated cladding not really worth the challenge.
  14. Mayner
    Irm wagons
    More a larger box than needed for the other much smaller species of grasshopper, apart from the minor technicality of exporting a legally protected species, ensuring it survived the trip and made it through bio-security on arrival. Or maybe I am just talking through my hat as I get older My 15 year old is currently agonising about bringing one of our cats "James" home from the States (16 hrs flights-6 months quarantine) when the other half returns later this year, chances of someone adapting James are slim, not sure he would remember us after the flights and quarantine, or integrate him with our other cats, but difficult to leave a good mouser behind. Going more and more off topic by the moment, though should have some IRM/Accuracraft Grain Wagons on the way in the not too distant future.
  15. Mayner
    Irm wagons
    call that a Grasshopper! this is a real grasshopper! A Giant Weta little problem with needing a bigger box. Smaller variety sometimes hibernate in my workshop
  16. There were two siding on opposite sides of the running lines at the Dublin end of Clonsilla. The short siding on the Down side opposite the signal cabin served a short loading bank and may have been used for general goods traffic and later used by the p.w. Dept for parking track machines, https://catalogue.nli.ie/Record/vtls000307491 There was a Cattle Bank on the Dublin side of the signal cabin served by a siding that trailed into the Up Main Line. The arrangement of the cattle bank was unusual in that it was in the form of an island between the main line and siding which ran alongside the canal, this siding was removed at some stage before the station was re-opened in 1981. A section of the Down Main line was retained as a siding/layby for goods trains after the Main Line was singled in the late 1920s, 191 derailed on the end of this siding as a result of a deliberate run-away incident from the North Wall. At one stage there was a loco shed connected to the Meath Line at the Navan end of the station.
  17. Apparently some (Green?) H vans were labeled to work between Amiens Street and Donabate on the GNR main line in CIE days for urgent traffic in fruit between Lamb Brothers orchards and their Dublin Jam factory. Seasonal work in the orchards and the factory was a major source of 'summer jobs' for Dublin families until the business failed in the early 80s, rail traffic would have ceased earlier.
  18. I produced a test etch for these wagons about 10 years ago, which for a variety of reasons (mainly the absence of suitable detail parts) did not progress to production. I am considering producing a production version of the kit and accepting feedback/expressions of interest to accept potential demand. If there is sufficent interest its estimated that an etch containing parts for two wagons would retail at approx. £30 Stg + Vat & Postage shipped directv from our UK supplier. The production version will include a number of corrections identified from the original test build and may potentially include a version compitable with sprung suspension. The kit is basically self jigging using fold together slot and tab construction and although I prefer solder this kit is suitable for glued assembly (using superglue). If there is sufficient interest I will consider producing a set of 3D printed detail parts
  19. When I was involved in both housing and commercial construction clients sometimes became convinced rooms were painted in different colours, despite the paint being from a batch of the same colour. In one case a client became convinced that the hall and living room of a new home were painted in different colours because of natural lighting and the relative size of the rooms, built on an East-West aspect the much larger living room was exposed to direct sunlight in the mornings while the hall was in shade the opposite in afternoons.
  20. The British Standard for Eau de Nil is BS3181C-216 https://www.britishstandardcolour.com/ Its likely that the Eau de Nil used by CIE during the 40s and 50s may have been derived from a British Colour Council reference code in use at the time. I think its unlikely that CIE would have been able to select a RAL colour during the late 40s, a German system wound up by the Nazis in 1942, incorporated in the German Standards Committee in 1952.
  21. Really sorry to hear about Mark's passing, I enjoyed his sense of humour and we had several long telephone conversations often late at night (living in different time zones) when placing/following up on orders and ending up talking about life in general. Marks willingness to incorporate a run of wheelsets with 28mm pin point axles into his production allowed me to produce a range of "21mm friendly" wagons of which I sold over 300 in RTR and Kit form over a 3 year period and built up a nice collection for my own use. Oddly enough one of my customers used EM for modelling the Irish Broad gauge for many years, but last year commissioned me to assemble a D17 in OO feeling that he just has not got the time to work in EM as he get older. In "Railway Modelling" published about 65 years ago Cyril Freezer (Author & long time Editor Railway Modeller) commented that it took 'approximately twice as long" to get something up and running in EM as OO, which I believe still applies today.
  22. Use of a marginally narrower gauge than 21mm. One of the arguments against using 21mm gauge with EM or RP25 profile wheels for modelling Irish steam outline locos is whether to compromise by widening/distorting the body to allow the wheels and running gear to fit or whether to reduce the gauge. The issue with wheel clearences with sheet metal bodies in P4 as the wheels are basically scaled down from the prototype as opposed to a compromise designed to allow reliable running in a limited space. The use of 20.2mm as opposed to the prototypical 21mm is not significantly different from the EM Gauge Society use of 18.2mm for Standard gauge compared to P4 18.83. The EM (Eighteen Millimeter) Gauge was initially developed to provide a more protypical gauge and wheel standards than OO and subsequently widened to 18.2mm. 18mm appears to have been selected as a results of the limitations of the techniques and components availabe at the time. While not my personal taste reducing the gauge below 21mm would potentially allow modellers to use steam outline locos with plastic injection moulded, die-cast or 3D printed bodies without major modification. Stephen once said that it was not practicable to produce an EM gauge rtr version of the Accurascale Manor s it was not practicable to achieve sufficient running clearance as a result of the characteristics of the meaterials used, similarly its necessary to modify the running board and splashers of Bachmann LMS 3F & 4F 0-6-0s and 0-4-4T for EM or S4 gauge. I have built several 21mm gauge steam outline locos from etched kits using Gibson OO/EM profile wheels, acheiving sufficient running clearance on locos such as an SSM J15 or GNR S was challenging, basically paper thin clearances between wheels splasher sides. There are similar issues converting the 1st generation of MM B141/181 Class to 21mm gauge the original RP25 profile wheels foul on the bogie sideframe. Two of my B141s are fitted with Ultrascale wheelsets, the third retains it original Bachmann wheelsets on new axles with ther rear of the bogie sideframes ground away to provide clearance. Components: One of the advantages of forming a society, group or becoming a trader is the ability to source componets in bulk potentially at a trade rate or discount. Wheels axles. For example Markits fitted an order (1000+) wagon & coach wheel sets on 28mm axles (suitable for 21mm gauge) into their production schedule when I placed an order several years ago. Similarly Markits were willing to produce a 21mm gauge axle suitable for their steam loco driving wheels based on a minimum production quantity of 1000. Markit wheels are extremely robust, relaatively simple to use and ideal for intensively used locos. I am not sure if the business is currently in operation as I understand that the owner was ill. Utrascale may be willing to reduce their 12 month lead time if a group or society were to place a bulk order for 'drop in wheelsets" for Irish GM diesels, or a bulk order for replacement diesel locos placed with an Irish or UK machnie shop. Track points. While Templot plug track may be suitable for finescale use, a simpler system based on a one piece 3D printed sleeper strip with integral rail fixing is likely to be more attractive for general use particularly those using re-gauged RTR quipment with their existing RP25 wheels pushed out to Irish "Broad Gauge" Injection moulded plastic flexible track bases may be worth considering a number of UK cottage industry suppliers including SMP(Marcway) C&L produced EM flexible track using plastic bases many years before Peco produced their EM gauge track system in colloboration with the EM Gauge Society. Similarly a society could comission Marcway to produce a bulk order of 21mm gauge points as opposed to producing 21mm gauge points to order.
  23. If there is a level of support for 21mm modelling as Dave suggests the first step would be to form a group to promote the gauge, develop an agreed set of standards and commission companies to produce track, drop in wheelsets and other components. One of the biggest challenges facing a 4mm 5'3" group would be agreeing on a set of standards that would "meet the needs of the many" as Dave put it, in particular the questions of wheel profile, running clearances and minimum radius curve. Adapting a 5'3" Standard using or derived from one of the "finescale" Standards such as P4 or EMF would potentially involve the costly replacement of the NMRA RP25 wheelsets fitted to the majority or RTR Irish outline locos and stock, a high level of precision in baseboard and track construction and larger minimum radius curves than commonly used in OO. The majority of my (mainly steam outline) locos and stock run on EMF profile wheels set with a Back to Back dimension of 19.3mm together with a flangeway gap of 1mm through pointwork similarly derived from EM Standards. Brendan on this forum sets the existing wheelsets on re-gauged IRM to a Back to Back of 19mm, similarly David uses a Back to Back of 19mm on his 7mm 3' Gauge (21mm models) with a 1mm flangeway gap. The 19.3 B-B based on EM standards may reduce hunting (side to side wobble) and on plain track compared with a 19mm B-B and reduce the risk of a wheel set "dropping down" where the track is slightly wide to gauge. Personally a 4mm 5'3" track standard derived from the Double O Gauge Association "Intermediate" https://doubleogauge.com/standards/ or NMRA (United States) https://www.nmra.org/index-nmra-standards-and-recommended-practices possibly with the gauge reduced to 20.2 or even 19mm may be a better option to 'meet the needs of the many" than using a P4 or EM derived standard. The selecting a narrower gauge that 21mm in combination with an "Intermediate" standard would reduce the narrow gauge effect compared with OO, potentially allow smaller radius curves that feasible with EM or P4 and potentially allow scale width steam outline locos to be modelled with plastic injection molded or 3D printed bodies. Personally I have never seen the absence of ready to lay 21mm gauge track or pointwork an issue, scratch or kit building steam Irish outline locos was always a greater challenge. A lot of my influence came from American modelling where traditionally there was a preference for hand-laid track (spiked to wooden ties) even on Basement Empire style layouts. Using a bit of lateral thinking a group could sponsor/commission 5'3" 3D printed or plastic injection molded track bases and custom order 5'3" gauge pointwork through Marcway Models Sheffield https://marcway.net/point.php Ultrascale could be commissioned to produce "drop in" wheelsets for diesel outline locos, or potentially commission a machine shop to produce replacement stepped axles for the recent generation of RTR locos with revolving roller bearing caps. David on this Newsgroup commissioned Marcway to produce track and points for both his 7mm Broad and Narrow Gauge Layouts, while modellers in New Zealand have commissioned local manufacturers to produce brass rail and injection molded track bases in a number of scales. So it can be done if there is sufficient interest and a will, particularly with the availability of "21mm friendly" locos and stock from IRM & MM something that was unimaginable 20 years ago.
  24. Tony invited in to the operating area behind the 2nd layout when he 1st exhibited it at the Bristol Show in 1978. I don't remember whether I asked a question or made a comment or simply recognised an Irish accent, but I was invited immediately in behind the layout something that never happened at another exhibition. I was living at the time in London but later moved to Shropshire (for a short while) not realising Tony was living nearby in Ludlow. The Adavoyle layouts appear to have been a colloborative rather than an individual effort first on Merseyside and later the Welsh Marches, I think at one stage he was involved with the Aberystwyth Club on the West Coast of Wales quite a distance away.
  25. Currently in the care of the South Dublin Model Railway Club the current layout is the second iteration of the Adavoyle layout started by Tony Miles in 1963. Tony pioneered Irish finescale modelling in 4mm, he developed his own track and wheel standards from the prototype around the same time as and independently of the Model Railway Study Group who developed P4. The majority of locos and stock originally used on the layout were either scratch or kit built, tender locomotives were powered by a large motor in the tender powered on the split chassis/axle pick up system, with power transmitted to the loco driving wheels by a carden shaft driving a gear box on the loco extremely powerful, some locos also had working inside valve gear https://www.templot.com/GNRI/adavoyle.htm
