Noel
Everything posted by Noel
  1. Hi Richie, thanks, understand those practicalities. Re limited area, somewhat less restricted than the small route the Tara's ran on Is the long Cork main line not the busiest on the island. At least the flowing sculpted lines of the mk4 DVT is a thing of great beauty, unlike the Frankensteins head that is the De Dietrich DVT. Would they be wider than the cravens? Noel PS: Thought it was the 22k ICR seats that folk found uncomfortably hard compared to the soft comfy mk3 seats.
  2. Your welcome. I was only affirming what @WRENNEIRE had already posted. The RPSI coaches are beautiful and mine are just waiting for a 3173 maroon GSV to run with.
  3. Thanks @popeye. Ok thats good, I have a pack of those. BTW, Absolutely fabulous job on your C class above. Classy professional paint job and like the steps added to the bogie sides. Do you mind me asking if and how you did the lights (i.e. fibre optic to LEDs, or 1.8mm LEDs through body, or other, etc)?
  4. Not so. I understand RPSI contracted directly with a factory in China rather than Murphy Models. I understand Murphy Models kindly allowed their Craven design to be used and assisted RPSI with same. They are the same moulds as MM Cravens, but the blue/cream coaches were contracted by RPSI directly from a different factory.
  5. What oval sprung buffers do folk recommend for A/C class kits? I would like to replace the resin ones on the SF kits. I was thinking about using Hornby X9313 BR class 31 oval sprung buffers.
  6. Ah that's clever using Glue'n'Glaze
  7. Thanks Gerry. Did you fill the apertures with fibre optic or put plastic lens in?
  8. Hi Gerry. Did you use a lighting kit for the two Metro Vic locos, or DIY? LED through body or fibre optic from internal LEDs, etc? Noel
  9. Two links here: CIE Bauxite 20 Ton Brake Van CIE grey 20 Ton Brake Van
  10. I got a pair of 20 ton RTR from IFM, both planked. Expensive but worth it to have the real McCoy behind my rakes of loose coupled pick up mixed goods trains. http://www.irishfreightmodels.com/index.php/shop.html#!/CIE-20-Ton-Planked-Brake-Van/p/45444642/category=3587606
  11. Fabulous. I nearly fainted. All fab scenes but that first photo.
  12. I have no doubt IRM have many other really interesting projects planned for the Irish market. This may turn out to be a blessing in disguise. Not my era, but I suspect, there may even be more sales opportunities for IE mk4 than mk3 anyway. Good luck guys whatever you have planned. Happy to wait.
  13. If I was a cynic I'd wonder if Ox just made some rumour noise to discourage potential competition from IRM. I'll believe the rumour if and only when I see their IE coaches which I doubt will be anytime soon (if ever).
  14. Thanks Stephen. The newly released mk3s are not exactly receiving glowing reviews over on rmweb.
  15. Hi Stephen, there had been rumours about this for a year or two, has something substantive actually happened or could this just be more noise from oxford? There is no mention of it on their 2018 catalog nor website. Noel
  16. Agree 100% and based on recent track record IRM coaches would have been in another league for authenticity and hyper detail.
  17. Thanks Fran. Understand. Noel
  18. Hi Fran. Are mk3 on IRMs radar?
  19. Heard that alright. Sounds promising. Any idea if EGV is to be included? Will be interesting to see what shade of orange they go with.
  20. Eoin, have you considered making any of the bodies very slightly longer or shorter than scale length so they might be a snug fit for a popular RTR chassis which out the need to cut metal?
  21. Four started. Spent a few hours removing flash and preparing these before first stage prime using Halford plastic grey primer in the spray booth. A few hours filing and sanding, but the resin bodies were in pretty good shape, mainly work to tidy up around the windows and buffer beams. The SF B101 sulzer will be first to get attention as next before any more painting there is the matter for fitting a cut'n'shut 071 donor chassis and figuring out how I can transfer the lighting from the 071. The chassis will need two cuts to shorten it each side of the motor so the cardan shafts will still be long enough to allow both bogies move freely when she goes around bends and over points. This is when it starts to get exciting . . .
  22. That's an excellent conversion and an absolutely superb respray. Top class.
  23. Agree different shades can look well, but the roofs on those Mk2d's are a bit like H&S hi-vis jackets. They are so bright marshals could use a pair of them to direct aircraft.
  24. Also https://marksmodels.com/?cid=692
  25. Marks models and ID models sell Humbrol weathering powers and Humbrol washes. Also less expensive powders using by the Warhammer community. https://marksmodels.com http://idmodels.ie AK pigments/powders https://marksmodels.com/?cid=692
