Everything posted by patrick
This is the paint I used Stephen. I don't remember where I got it, possibly an auto parts store but it was chosen because it matched the gray trim on the Bachmann Irish station building. The colour is described as Machinery Gray on the can. At some stage the bridge will get weathered with an overall wash of very diluted black and drybrushed with white.
The Hornby footbridge at Glen More finally got lowered to an acceptable height and got repainted. It needs a little weathering.
Lovely kit but outside my era. Hope Leslie does a CIE 20 ton model.
What started yesterday as a minor buffer repair on one of my palvans turned into a rebuild and repaint of two of them. The wagons were some of the first Irish rolling stock constructed about 10 years ago to evaluate the practicality of building an Irish layout. Does anyone know if the roofs of the prototypes were painted black?
The signal box is a Ratio kit with the stone steps replaced with shortened ones which came from the Dapol box which it replaced. The goods shed is scratch built from foam board covered with Plastistruct embossed stone sheet. I still have to get around to finishing the roof. The station building is a Dapol kit. None of the buildings are accurate models of any prototype but capture the atmosphere of a small station in the South East in the seventies. A prototypical paint scheme goes a long way to achieve this.
Yes, that brake van looks great. Wish mine came out that well.
I personally found it a bit of a challenge but then again it is only the second brass kit I assembled. The first was a similar SSM brake van which got completed last month after being on my work bench for about six years! The buffers are from Dart Castings which are a big improvement on the ones supplied with the Dapol underframe which comes with the kit. Since the model will receive frequent handling in the fiddle yards at the end of its run styrene running boards were cemented to the underframe which are much more durable than the brass ones provided with the kit not to mention far less fiddly to assemble. Some cleaning up still needs to be done on the model before getting a coat of matt varnish and weathering.
It's a SSM kit on a modified Dapol Prestwin underframe.
The transfers came with the kits Leslie. It's additional transfers for the Vac Brake version we are referring to here.
Ah yes, the transfers, or lack of! I wonder if anyone could be persuaded to produce them.
I thought I could get away with using Athearn freight car brake wheels which I had in the scrap box but not only are they the wrong style but also too large and looked totally wrong on the wagon. I think I will cut to the chase and order the correct ones from Des.
None of the 29 Provincial Wagons on the layout have brass bearings. While they are not the most free rolling wagons out there they perform fine on the layout which has no gradients and trains are 15 wagons or shorter.
Three cattle wagons were put into service tonight. Leslie's kits generally don't gather much dust on the work bench but these have been an exception taking several months to complete. Two more are in the works, both being adapted to the Vac Brake version.
Nice! Hopefully we will see a layout thread soon.
A favourite Irish place name of mine is Ratass Tralee, pronounced Raa, site of a cemetry and the ruins of a medieval church. It is also the name of a level crossing on the line from Mallow.
Personally I appreciated being able to pay in advance when funds are available rather than having to come up with a payment last minute before items are sold out which has a habit of happening immediately after the washing machine has bit the dust. I'm thinking that stocking up on gift cards is the answer.
Check out the other videos on the channel, this is just the 70's stuff.
. Just found this treasure trove of 1970's CIE videos on You Tube. I somehow managed to put in 2 links twice and cant find a way of fixing it. Can a moderator fix it?
Tralee had one operating the level crossing between the passenger station and the North Kerry yard.
