This point is causing me trouble on my DC layout.
The bottom part is the mainline, the top of it goes to a siding. I have an insulated joiner to prevent a short if switching to the siding. I am relying on the switch blades to carry power through to the rest of the point. Trains stall between the insulated rail joiner and the switch blade on the main line. I guess it has become dirty over time. It did work flawlessly before, even after ballasting.
First of all, what is the best way to clean in between the switch blades and stock rail? Secondly, what would be a more permanent solution to power the point? Could I just drop a wire down from the V and put it on a switch that goes between both bus wires, or am I better using a point motor which has a polarity switch? I'd like to avoid ripping out the point.
Thank you.
