GNRi1959 Posted November 29, 2021 Share Posted November 29, 2021 Is it best to solder any ‘multiple’ looped cables under a baseboard, as opposed to using block connectors? It sure would reduce risk of break in sound power supply from possible frayed cable, wouldn’t it? Quote Link to comment Share on other sites More sharing options...
0 Broithe Posted November 29, 2021 Share Posted November 29, 2021 (edited) A good soldered connection will generally be a better bet than a screwed one. It can even be worth tinning multi-strand wire, if you do want to have screwed connections for the occasional disconnection. With a soldered joint, you do still have the potential for breakage where the solder ends and the multi-strand wire emerges - reasonable support will largely prevent the stress concentration there becoming a real issue. When I had a proper job, our control cabinets were arranged with large banks of screwed connector blocks, but the connections were not directly to the wire - the ends of the wire had crimped blades attached, to avoid the crushing/cutting of the wire strands that can occur as the screw is tightened. This sort of thing - the 'hook' on this sort means that you can 'feel' that the full end of the screw is on the blade, not just a bit of it catching the very end of the blade. Edited November 29, 2021 by Broithe Quote Link to comment Share on other sites More sharing options...
0 GNRi1959 Posted November 29, 2021 Author Share Posted November 29, 2021 What I done this morning was tinned the ends of the cables and put the back into their connectors, seems to be fine and I can keep an eye on things. Thanks 3 Quote Link to comment Share on other sites More sharing options...
0 Broithe Posted November 29, 2021 Share Posted November 29, 2021 1 hour ago, GNRi1959 said: What I done this morning was tinned the ends of the cables and put the back into their connectors, seems to be fine and I can keep an eye on things. Thanks That should be fine. It's probably the best compromise for model rail use. Quote Link to comment Share on other sites More sharing options...
0 GNRi1959 Posted November 29, 2021 Author Share Posted November 29, 2021 1 minute ago, Broithe said: That should be fine. It's probably the best compromise for model rail use. By the way, I’m using these snap connectors as I find them much better that screw type 2 Quote Link to comment Share on other sites More sharing options...
0 Broithe Posted November 29, 2021 Share Posted November 29, 2021 (edited) 35 minutes ago, GNRi1959 said: By the way, I’m using these snap connectors as I find them much better that screw type They will be more than adequate for anything likely to be required on a model rail set-up - and they have the advantage that the wire isn't subject to the turning end of a screw as it is tightened up. Edited November 29, 2021 by Broithe 1 Quote Link to comment Share on other sites More sharing options...
0 David Holman Posted November 30, 2021 Share Posted November 30, 2021 Probably fine for a home layout, but hard soldering every time for me as my layouts regularly get taken apart (well, at least they used to) and put back together again for exhibitions. Am sure it is all this movement that has the potential to cause problems. The main ones I've had to deal with were broken solder joints on point tie bars, though there are ways to minimise this. The two worst were firstly a single stray strand causing a layout wide short and shut down and, most recently a dry solder joint on the plug/socket for my hand held controller. Both immensely frustrating as you first need to find where the problem is - though generally easy to fix, as long as you remembered to pack a soldering iron that is. I also once had a wire break on an alignment bolt on the fiddleyard. Unfortunately, I'd only got an 18 watt iron with me and spent 20 minutes gently warming up what seemed like the whole layout in an effort to get the solder to run! Nowadays, always take the 100 watt iron with me... Given I have attended over 100 shows, the number of problems has been minimal, but can't help thinking screw joints would increase the chances of something going wrong. A belt and braces approach seems to be best. No experience of snap connectors, but again, should be fine for home use. 1 Quote Link to comment Share on other sites More sharing options...
0 Mayner Posted November 30, 2021 Share Posted November 30, 2021 There seems to be several alternatives all of which work the snap connectors seem to have a following in the United States and seem to have been featured in more recent work (less than 25 years ago!) The most important thing is to twist, tin and solder the ends of the cables whatever type of connector you use. I use a mixture of screw terminals and tag strips, though I could not get tag strip on a recent visit to the local electronic parts store. I used terminal blocks on a recent N Gauge but had forgotten what I had used. Black and red is for DCC Track Power, Blue and Brown DCC Point power, apart from the wire and terminal blocks everything is salvaged from a layout built over 20 years ago in Ireland. Point control is Tri-ang passing contact point switches connected to a terminal block. The Lenz LS 110 Stationary Decoders are due to be removed and points wired direct to the Tri-ang levers as the LS110s are not man enough for working Seep Point motors particularly in pairs in crossovers. I will use the LS110s with Peco point motors on South Dock with DCC radio remote control through the Throttle, I better finish the wiring on East Dock the layout is falling behind Tony and David 1 Quote Link to comment Share on other sites More sharing options...
0 GNRi1959 Posted November 30, 2021 Author Share Posted November 30, 2021 Nice to read all comments. This is the first layout where I actually spent more time under the baseboards, than above. Previously, in a rush to get some signs of scenic life showing, I lost sight of what was absolutely essential underneath. So, at the moment I’m taking it in stages and find the under-baseboard challenge interesting for a change. I think, ultimately, when all works well I may replace all temporary Connectors for solder joints. 3 Quote Link to comment Share on other sites More sharing options...
0 GNRi1959 Posted December 1, 2021 Author Share Posted December 1, 2021 Dear friends, I think I have all my point motors in position and almost all wired. The question I have, I am now taking cable from each motor back to the individual switches, so I assume that I cannot loop these, I must feed each point motor from its own switch, makes sense I hope. Quote Link to comment Share on other sites More sharing options...
0 Galteemore Posted December 1, 2021 Share Posted December 1, 2021 (edited) This may help, Tony - some good wiring diagrams. Do you want some of the motors to throw simultaneously? https://www.google.co.uk/url?sa=i&source=web&cd=&ved=2ahUKEwir18ykhcP0AhWZQfEDHWzWBNAQjhx6BAgBEAI&url=https%3A%2F%2Fwww.rmweb.co.uk%2Fcommunity%2Findex.php%3F%2Ftopic%2F115511-wiring-multiple-point-motors%2F&psig=AOvVaw3EC3RxG3OQJ2-AfHfgnmkt&ust=1638463175358378 Edited December 1, 2021 by Galteemore Quote Link to comment Share on other sites More sharing options...
0 GNRi1959 Posted December 1, 2021 Author Share Posted December 1, 2021 I could have one switch operating a paired crossover but I don't mind going separate with each point as there are only 6 in total anyway Quote Link to comment Share on other sites More sharing options...
0 Sven-E Posted December 8, 2021 Share Posted December 8, 2021 On 29/11/2021 at 10:59 AM, Broithe said: It can even be worth tinning multi-strand wire, if you do want to have screwed connections for the occasional disconnection. This industry practice seems to have changed over the years and not recommended anymore. The problem is possible breakage at the end of the tinning, as you already mentioned for soldering cables together. There is also a potential problem with the tinned copper that it shrinks over time, thus making screw terminal loose. Retighten now and then, just like IKEA furniture. 1 Quote Link to comment Share on other sites More sharing options...
0 Broithe Posted December 8, 2021 Share Posted December 8, 2021 44 minutes ago, Sven-E said: This industry practice seems to have changed over the years and not recommended anymore. The problem is possible breakage at the end of the tinning, as you already mentioned for soldering cables together. There is also a potential problem with the tinned copper that it shrinks over time, thus making screw terminal loose. Retighten now and then, just like IKEA furniture. There is no perfect solution. You just need to select one that is adequate for your application. You can even have corrosion issues, from the junction between dissimilar metals. A lot of us will have suffered from having a screw loose now and then... 1 Quote Link to comment Share on other sites More sharing options...
GNRi1959
13 answers to this question
