Ballinree
So with the demise of my old layout here is a smaller more portable layout
It is 6ft 2inches bu 3ft 1 inch, name Ballinree and principally preserved steam
Here is the track plan
This is only a rough design so it will undergo alot of change
The blue line represents a partition between the scenic and siding part(there will be maybe three sidings in this area) of the layout and the grey box represents platforms
  • 4 weeks later...
So with my exams over I was able to start on my new layout
The way I have built the baseboards mean that when in use it is put on tresles and when no in use stacked against the walls
Here are a few pictures
juiy46.jpg[/img]
nz3m9c.jpg[/img]
1zna4hk.jpg[/img]
And a few pictures of 186 and a meat train
33eud7o.jpg[/img]
nch314.jpg[/img]
2ms2e1g.jpg[/img]
mcad5t.jpg[/img]
Wagons are weathered using weathering powders
Thanks for the support lads
Heirflick, Yes 286 is a Dean goods, unfortunately tender driven:((which makes for poor enough runnng, for the small curves i just used very thin plasticard or more likely paper and manipulated it into the correct radius the glued it on
