Another DCC Dilemma......
I have two 121s - 125 with a sound decoder, and 132 with a standard decoder.
Last night I had a friend in, and I was all set to show off the amazing sound capabilities of 125, but she didn't come to life - boo.
So I had a closer look today and in short:
* 125's sound decoder won't respond - it's not the loco, because she runs when I put 132's standard chip in
* No movement, no sound and no lighting
* I reset the decoder using CV8 etc, and still nothing
* The decoder doesn't work in 132 either
* The decoder and my NCE PowerCab are definitely speaking because the loco makes those weird noises during the reset and renumbering
* All other DCC locos work fine
Have I just had my first deceased sound chip?  Hoping the knowledgeable folk here can suggest a solution!
Edited by Patrick Davey
15 answers to this question
**UPDATE**
I paid a visit to Kieran Lagan earlier, and Kieran kindly tested the misbehaving sound decoder for me in his decoder test setup.  Interestingly, it passed all the tests!!  I won’t be able to check it again in its ‘resident’ loco until Tuesday, but at least I know the - expensive - sound decoder is fine.  It’s still a mystery how the loco hasn’t been recognising it, yet she was fine with a standard decoder…… standby for a further update on Tuesday!!
I’m no expert but just a thought. One of my friends using NCE had a problem like this when he consisted a loco with another. Then when he tried to use the loco on its own (without disbanding the consist) it misbehaved.
That's a good shout. NCE controllers can be a but prickly if you don't clear the consist, that usually stems from functions that are selected to work when the loco is operating in a consist.
You could also try setting CV19 to 0 which will make sure the decoder isn't assigned to operate in a consist.
2 hours ago, Patrick Davey said:
Good advice folks thanks and yes the consist issue had arisen previously so I had made sure to delete the consist prior to all this.
Did you reprogramme CV19 to a value of 0 on the loco? I'd do that just to be sure.
No but that'll be on the list when I get back to the layout - cheers!
  • Agree 1
8 hours ago, Georgeconna said:
dumping the NCE was the best thing I ever did. Dunno how people use that Archaic yoke.
Out of interest, what have you replaced it with?
For what it’s worth…. When I was getting into DCC I was choosing between the NCE Powercab and the Gaugemaster Prodigy 2. I went with the Gaugemaster and have no reason to change. It’s never given me problems. I’ve actually acquired a couple of extra controllers so I should be set for life!
NCE are known for not playing nicely with Loksound decoders, and I also found the programming features clunky as hell.
However, if I were replacing everything I’d go for a Lenz system.
its a pretty basic system really, 20 years old. Switched to a Z21, option to use handset and tablet. will never change. So simple a 10 year old kid can use it.
Yeah, Z21 is good setup. I just prefer the Lenz handeld. But you cant go wrong with any of the German manufacturers.
That will happen with pretty much any controller. When you consist a loco you’re basically telling it to respond only to the consist address and ignore its regular address.
16 hours ago, Patrick Davey said:
Pleased to report that 125 is now fully functional again after the chip went for testing by Kieran Lagan - thanks Kieran!
Great news! Did he reprogramme it in any way?
