James Posted 17 hours ago Posted 17 hours ago Hi all! Looking for some advice please! I’m thinking of putting some of my budget towards some brass kits to learn how to work with it and make some models that aren’t RTR. However, with some current projects I’m working on i would like to make some handrails to add some detail, however, I have no idea how to bend a brass rod to get it to the correct radius/bend. Any pointers would be greatly appreciated!! Many thanks, James 1
Tullygrainey Posted 16 hours ago Posted 16 hours ago Hi James, In my experience, handrail making is mostly a case of trial and error. Most handrails are straight with a right-angled bend at each end where they attach to the bodywork, like these on the model I'm working on at the moment Working in 4mm/ft scale, which I'm assuming you are too, I use 0.45mm diameter brass rod and a pair of flat jawed pliers to make the bends, checking by eye until it looks right. The tricky bit is actually making the second bend in the right place so that the length of the handrail matches the holes you've just drilled in the bodywork. As I said, trial and error and it's probably better to make a handrail to match the holes than end up drilling multiple holes to match a handrail you've just made. The more you do it, the better you'll get but be prepared to waste a bit of brass rod in the process. I have a tin full of handrails that weren't quite the right length for the job in hand. For the sort of handrails that curve round the front of a smokebox, it can help to find a cylinder of similar diameter to the smokebox - a bit of wooden dowel or brass tube or whatever you can find. I've used the handle of a screwdriver before now - and bend the rod round this until you've got the shape you need. Hope this helps get you started, Alan 5
Colin R Posted 16 hours ago Posted 16 hours ago Hi James, I would suspect that there are many answers to this one question, but I will start with a staple book, Miniature Locomotive Construction by John Ahern. Look on eBay for a reasonable second-hand copy from about £5.00. Dated, yes, but basic engineering principles never change. 3
murrayec Posted 12 hours ago Posted 12 hours ago A selection of wire & tube benders;- The best aid for bending both ends of a handrail and setting out the drill holes in Gauge 00 Eoin 3
Tullygrainey Posted 7 hours ago Posted 7 hours ago Forgot about the Bill Bedford jig! Useful little tool. Might be hard to come by now. Does anyone still sell it Eoin?
Signal Post Posted 5 hours ago Posted 5 hours ago That Bill Bedford jig looks like a great device, beautiifully simple. I would imagine it would be easy enough to make something like it with some brass sheet but without the indentations, just by drilling the holes and notches. 1
Galteemore Posted 5 hours ago Posted 5 hours ago 2 hours ago, Tullygrainey said: Forgot about the Bill Bedford jig! Useful little tool. Might be hard to come by now. Does anyone still sell it Eoin? 12A models do one Alan https://ebay.io/m/aMBpNE 1
