Mol_PMB
Everything posted by Mol_PMB
Work in progress with the simple option, it needs some more black diamonds on the intersections and there's scope for better detail on the quarter-circles. I also need to think about hinges and catches. Dimensions of this gate are 40mm x 19mm in 4mm scale.
For an etch. It's far too fine to be punching out rivets - the metal would become badly distorted. The top and bottom of the gate are 2"x2" angle which is about 0.7mm, the diagonals are 1.25" x 0.375" strip which is about 0.4mm x 0.125mm. We can do that - my E class is etched in 0.25mm thickness nickel silver so a half-etch would be 0.125mm thick and a line thickness of 0.4mm is practicable - some of my grilles were a bit less than this. So the simple option is to ignore the rivets, in which case the gate could be done as a single-piece etch with the diagonals half-etched from one side or the other to give the overlapping appearance. The more complex option is to make the gate in two layers, again the diagonals would be half-etched but this would allow the rivets to be left proud as full thickness. One set of diagonals would be on one layer, the opposite diagonals would be on the other layer, and the top, bottom and verticals would be on both layers. I'd arrange it so that the two layers would be surrounded by a fret that folded, so the two layers would be folded onto each other and soldered or glued together while still attached to the fret (ensuring perfect alignment) and then separated from the fret and cleaned up. More complex, but you get the rivets and the layered detail of the quarter-circles in the corners, and there's also the ability to have the top and bottom rails visibly thicker than the diagonals as they should be. So, the conclusion is that it can be done by either method, one is a bit more complex to make and requires a bigger area of etch. If I was working in 7mm scale I'd definitely go for the 4-layer rivetted variant, but in 4mm scale I think maybe the simpler option is more practical (much as it pains me to simplify...)
Thanks. I think the Mainline/Bachmann LMS ones capture the style better, but the disadvantage is the lack of the corridor third. Though I think a cut'n'shut of bits from the brake third and/or composite would work. The GSWR did have some composites of this style too, but they weren't like the LMS composite so are probably harder to do.
Thanks - some nice stuff there, not often seen. Gypsum and ballast hoppers, plough vans, fertiliser, spoil and keg bogies. I was hoping there might be some cement bubbles but perhaps that was unrealistic! This is quite a good price for a sound-fitted A class; I was tempted but I have several As already: https://www.ebay.co.uk/itm/267179992632
Lovely drawing, and there's a scale along the bottom so I should be able to work out the true size. But I'd still be interested to know the dimensions of the other type if you get a chance - would be interesting to see whether they are the same. I'm sure a gambolling lamb could find its way through any fence or gate into the path of a train. I've certainly run over a few in my time. 4 sheep and a badger, which makes me an ace!
I have an idea for an etch in 4mm. Let me see how practical it is - the detail is rather fine but I have a cunning plan. There are several variants - are people fussy about which sort? I could potentially put a mix of different ones on an etch.
Seems there was more variation among these than I had imagined; the first one is the same as @Fran's friend's example: Gate by the old railway © Michael Dibb :: Geograph Ireland Branching off at Duleek A Thomas Telford sunburst gate, Treborth © Meirion cc-by-sa/2.0 :: Geograph Britain and Ireland
Selling like hot cakes toasties! I'm pleased there are some of the grain hoppers left over. You didn't happen to find any more of the black oil tanks, did you?
The "Eyre Lee Bird" railtour Cork-Galway-Return 5th April 2025
Mol_PMB replied to Niles's topic in What's On?
Thanks! But which of the Cork-Tralee services is a Cravens set these days? Guess I might be waiting a while for that to happen again, but it was fun while it lasted. Fond memories of a 141 flat out climbing up to Rathpeacon, or in earlier years an 001 trundling through the Kerry countryside! I recall I even had a 'mixed pair' on one Cork-Tralee service, which seemed quite unusual at the time. -
Some IRM wagons have now reappeared in the AS warehouse, including: H vans Grain vans 4-wheel flat wagons Esso oil tanks Get them while they last.
I like that very much! It's upside-down in the photo; the extra bars to block smaller animals should be at the bottom. If you get a chance, could you measure the overall width and height and let us know? I'd also like to make a little one for my model railway.
That's a good idea - I wonder if that line will ever reopen? Excellent - hopefully we can meet and put a face to a name. -
Wonderful - thanks! I'll take a look. -
Thanks Jonathan, I appreciate there's a lot of complexity! Looking at the photos, this GSWR corridor third from the 1918-1925 period seems to be a reasonably consistent design made in large numbers (for Ireland - around 30 of them) and quite long-lived. Photos of 1294, 1300, 1310 and 1317 are virtually indistinguishable to my eye, so I think they were fairly consistent in shape and detail. They also have the advantage of being very similar in dimensions and style to some LMS coaches readily available in 4mm scale. What I'm wondering now is whether a pair of etched overlay sides exactly to the GSWR drawing might be a better option than cutting-and-shutting the Mainline/Bachmann coaches. But I think even just a simple repaint of a Bachmann composite would be fairly convincing, especially in black'n'tan livery which tends to hide slight discrepancies in the window layout. Put the footboards on and it becomes even more Irish. Having one of these in a rake that was otherwise more modern CIE stock (including Park Royals) would be entirely prototypical and would provide an interesting contrast.
Nice - thanks for sharing the photos. The green livery looks spot on - can you remember what shade of paint you used?
I've booked the railtour, as well as flights and hotels. Hopefully meet some of you on board? I'm planning to make a long weekend of it, arriving Friday morning and leaving on Monday. Hopefully I can do a trip to Midleton (a line I've not been on) and walk the Tralee-Fenit greenway as well. It looks like there's a bus service from Tralee to Fenit if I only want to walk one way. From many many years ago I remember the Fransiscan Well in Cork having some interesting beers. Is that still a good place to go? Other pub recommendations welcome! Mol -
Ah, those must be the ones I remember from the west of Ireland. Not quite the same design, even accounting for the missing bits and modifications. Is there a drawing for one of those anywhere?
Lovely! I remember my dad pointing those out to me when I was on childhood holidays in Ireland. I think they must have been used elsewhere too, not just the GNR, as we normally visited the west of Ireland?
I was looking through photos of passenger trains at Fenit yesterday, and found one which included an 8-compartment corridor second (formerly third) in black and tan livery: https://www.flickr.com/photos/irishrailwayarchive/53511154971 Here's another image from Ernie showing the same type in green livery: The first coach is one of these, showing the compartment side. The fourth coach is also one of these, but shows the corridor side which had quite a different appearance. This sent me down a rabbit-hole as my initial thought was that this coach looked similar to some LMS vehicles. I did a bit more research and found that this is a GSWR type, still being built very early in the GSR era. I think they were numbered 1290 to 1322, although there may have been minor variations between the earlier and later builds. So there were a good number of them and many seem to have survived into the 1960s. Here are some more photos from the IRRS Archive showing both sides. These are in the older dark green livery: https://www.flickr.com/photos/irishrailwayarchive/53508911093 https://www.flickr.com/photos/irishrailwayarchive/53509172220 https://www.flickr.com/photos/irishrailwayarchive/53511165871 And these are in Black'n'tan: https://www.flickr.com/photos/irishrailwayarchive/53511331613 https://www.flickr.com/photos/irishrailwayarchive/53511597330 https://www.flickr.com/photos/irishrailwayarchive/53511331608 https://www.flickr.com/photos/irishrailwayarchive/53511303071 https://www.flickr.com/photos/irishrailwayarchive/53511303076 Key dimensions were 57' underframe, 61' over buffers, 42' bogie centres, 9' wide over body, and 13'2" total height over ventilators. These compare pretty closely to the early LMS corridor thirds from the same period, diagram 1695: 57' underframe, 60'8" over buffers, 40'8" bogie centres, 9' wide over body, and 12'10" total height over ventilators. To my eye, the styling also looks very similar to these early LMS carriages. On the compartment side the layout of doors and windows is identical, and the panelling layout very similar. On the corridor side, there are the same number of doors in a similar arrangement but the windows are distributed slightly differently - the GSWR type has more deadlights where the LMS ones have glass. These are the Comet models etched sides for LMS D1695: Now, the Mainline / Replica / Bachmann LMS coaches are representations of this type, but they only make the composite and the brake third, not the full third. These are the two sides of the composite: I've seen accounts of people doing a 'cut and shut' using parts of two brake thirds to make a full third, or of course you can overlay the Comet etched sides to make a third. Now, I know that Bachmann produced their composite and brake third in CIE dark green as part of their Irish set, and some people have dismissed them as completely incorrect. But are they really that bad? Am I missing something? The older Mainline versions can be picked up on Ebay for not much more than a tenner each, so they would make a cheap basis for a conversion. I was wondering whether anyone has used these as the basis of Irish models? Some details could be changed quite easily: adding full-length footboards and an Irish livery would help a lot even if you didn't change the window arrangements. Please show me what you've done!
Looks great! Nice work. The gauge glasses are very effective.
Making an ‘E’ – the Maybach Diesel Model Assembly thread
Mol_PMB replied to Mol_PMB's topic in Irish Models
I'm pleased to say that I have managed to make time for a good few hours of modelling today, and I've been focusing on the chassis for the E class. Making up the High Level hornblocks and hornguides and getting them all to be a smooth fit was a time-consuming task, lots of fettling required as the parts supplied had some dimensional variations. I got there in the end though. Main frame components ready for assembly: Hornguides fitted and fettled (again) so the blocks all slide freely: Once that was done, progress was much faster. Here are the main parts soldered together and checked for fit. I had to file a little off the ends as they clashed with my messy soldering of the vacuum pipes inside the bufferbeams, but otherwise it fits well: CSB pivots and brake hanger rods fitted, nuts added to coupler mounting plates. Geartrain case completed and the hornblocks ready to fit: Rough positioning of the QuaDriver motor and gearbox which drives the two closely-spaced axles at the front. The geartrain in the foreground connects to the third axle: And finally for today, the gubbins tray which bolts in place above the motor. My intention is that this can be used to carry extra weight, and/or to mount decoder, stay-alives etc. There's plenty of room above it in the bonnet: Hopefully at the weekend I can try fitting this all together with axles, gears, wheels, suspension and pickups. If that goes well it will be ready for a test-run, so I was delighted to hear that my 21mm gauge flexitrack bases went in the post today!- 200 replies
- 13
