Goods wagons in the fifties, and a UTA example
DiveController replied to jhb171achill's question in Questions & Answers
Pender & Richards Book book (Summer 1967)refers briefly to these, as rebuilt in 1965 by the UTA. Note that JB's wagon is C352 and doesn't fall within that sequence -
Carting the turnips, 2003-6
DiveController replied to jhb171achill's topic in Photos & Videos of the Prototype
"A" class farewell tour
A very fine locomotive. I'm so happy that she has survived. There's a lovely color picture of a brand new A3 outside Inchicore, 1955 in Colin Boocock's Locomotive Compendium p55, complete with silver chassis and thinner letters. It certainly is an impressive sight in all silver (for however long that lasted). What was the correct color for the letters? -
THanks for that, Popeye. Look very similar to above. Do you happen know their origins? -
Ant one have any photos of what this looked like or book with a photo. I didn't manage to find one online
The only possibilities I could find to potentially identify this 6W brake van are 315A, a PW van/sleeping van, previously GSR 70 built 1888 as a former GS&WR passenger brake, 6-wheel, 30ft, one of eleven, b. 1882-99. Record seem to indicate that it was converted in 1955 to departmental use. The other might be departmental sleeping van 368A, formerly GS&WR/GSR 14, built 1911, as a former GS&WR 6-wheel brake, 30ft, one of 36, b. 1885-1911. Recorded as converted to departmental use in 1960 which would precede the introduction of B'n'T in 1961 These seems to be the only vans left by 1973 so other than 69 for preservation, this van must have been scrapped in that interval after 1967. Ref. Irish Railway Record Society 174 The Last Wooden-Bodied Carriages of CIÉ (Michael Baker) EDITED FOR CLARITY after post below
Smaller UK/US Model Stores - Has anyone ever used/bought from?
DiveController replied to Blu Bianco's question in Questions & Answers
They make this apparently odd claim on their website regarding ProCab "We provide a Power Supply sourced within the UK, so no US-UK adapters, the Power Supply is of a better specification than that supplied by NCE for the UK market. We have found that with the NCE supplied UK transformer that the track voltage is too low to work with the ‘00’ market and results in slower top speeds and stuttering sound." …….although I haven't heard anyone complaining about their NCE system in this regard -
Right now, Des it would only what doesn't fit. Maybe next weekend if I get time with work.
They don't fall well especially with the weight. They don't even travel well even in their boxes (if dropped). I had one damaged in the post. It was obviously dropped. It needed buffers and pilot beam assemblies both ends although under frame was undamaged. Some parts may fit back. The buffer beam assembly pushes directly up into the end of the body and buffers fit into it. If the body where these insert is damaged that will be more of a problem. POst some photos if you need advice from the members.
Container flat & CIE container
Another interesting photo, JB. The 20T 27101-27300 series flats were built 1970 and were hand and vacuum braked. I cannot appreciate where that (vacuum)is on this flat wagon. I presume they were built specially for increasing container traffic at that time? The container is interesting in that I had believed that all things brown and (sitting on something) fitted had white CIE lettering and surrounds but the roundel is black on these doors. Doyle & Hirsch book 1st. Ed also has 27430 20T flat with a Uniload container with entirely black letters and surrounds (on white Uniload pale ?white background). Now that I look at that uncoupled flat in the CIE & NIR ruling stock book, I do see a vacuum pipe below the coupler which would probably make sense as they may not have lasted very long in an elevated position like the gypsum/dolomite/magnesite/ballast wagons! Why were the latter positioned higher on a pipe on locos and these latter wagons? -
Jim at Marks Models or write directly to Murphy Models via their website What's wrong with it?
The range seems limited for most lineside items except for the signal box. They do look well and the some of the others may find use in some layouts. It's a shame he doesn't actually do something that is, in fact, Irish. I've always thought it would be useful to have a resource section with photographs of a prototypical Irish railway places/items all in one place, with finished models or kits that closely resemble them alongside. The latter would be easily transformed to the prototype by the average modeler (repainting, nipping off some extra stairs or platform on a signal cabin etc.)
GNR and GSR goods vans in 1970s CIE use.
DiveController replied to jhb171achill's topic in General Chat
The GN wagon seems to have lost its CIE "N" suffix. Any ideas what 181AX means. The X may be for scrapping. "A" would have been of GSWR origin which it's not, correct:confused: I was also wondering about the "C" on this van And the significance of 248X on the GSR van -
Looks like 11814 to me. The tan surround would have been hard to see on that brown background. But if I understand your post correctly, grey H & Palvans had tan surrounds but GREY opens had white as this GREY brake vans. Which brake van is that at the back, JB?
Good luck with the club! Sounds great:-bd
Budget DCC controller
DiveController replied to longdavey's question in DCC, Electrics and Electronics
Most decoders are one amp decoders so the maximum current draw that you will have per locomotive would be 1Amp. More than this and your decoder will fry. When the locomotive is stalled, you will have a high current draw, which will increase with a longer train and increase more I you have a gradient to climb. No matter what lighting etc., the maximum will be one amp per decorder or you'll fry the decoder. So maybe you need one amp per simultaneously running locomotive plus anything else you need to run. If you introduce carriage lighting or lighting on the layout, turnouts that you want to control by DCC, etc. you will want to account for that also. Consider what you want to do with the layout in the future and if any additional power needs will be required. Lots of people with a lot of experience with DCC on here. Just my 2 cents. -
Great thread, Jb but you have just given me some more homework to do since I'm only familiar with 60% of theses wagons or liveries or both! Was the C352 NCC352 or Courtaulds (and that wagon is part of my homework)? Look like a poorly stenciled UT followed eventually by NIR's stamp. I like these wagons because of they unusual shape. A purpose built older ballast would have been a 2 or three plank wagon, I presume, and I presume the cutting was to allow it to be unloaded by hand or mechanical digger? The wagon behind is in NIR grey? -
Ah Jayzus, John! ………..and me here with Rails through the West in me hand with B145 on the cover pulling a train with Bell Containers
Did you pick these up as a set or just the driving coach? which manufacturer? Looks good on the video
Hi Tommy, You asked me to report back on the Frateschi chassis when I got one, it finally arrived in the post during the week. It's a G12 chassis which I thought was the same as the G8 (and it may or may not be) having failed to get any definite answer from Frateschi in Brazil or the US distributor, so pretty much 'zero' for customer service. That said, it's definitely too long for the inside of the MIR kit and in all probability the bogies will foul in the inside of the chassis especially on curves. Haven't had time to get to it but will likely need a will a cut and shut to remedy this. So much for it being HO! Fortunately I did not invest a huge sum in it as it was purchased used in NZ livery on eBay, still significantly cheaper than acquiring on in the US or from Brazil (due to the postage cost) The bogies look prototypical versus the Athearn SW1500 chassis which Gerry is using but I'd bet the Athearn's running characteristics are better. The Frateschi is noisier then my lone Atlas switcher and way noisier than a MM 141. Max speed like the 141 is not that fast, slow speed is not that slow but it pulls very well. The catch is that he weights are mounted fore and aft snugly inside the BODY. It's likely they might not fit easily somewhere on the chassis under the MIR body without running a drive shaft through the weights, in which case there should be plenty of room between the flywheels and gear towers.
DSER short wheelbase goods van
Interesting roof, looks like corrugated sheeting:confused: JB, you have us well trained now! I go to the kitchen for 7 minutes and three of us have turned the photo!! -
That being the case, I wonder why locomotive-powered passenger trains persisted at that time versus dumping of nearly every locomotive in the 2000s in favor or railcars. Steam locos like the 800 were replaced by a fleet of diesel locos.
Probably the thin end of the wedge, JB. It's still strange that the romanticized 800 train is illustrated but the new 'ugly duckling' (no offense to lovers of railcars intended) is not, mere the efficiency of the new diesels alluded to. Were the new railcars well received by the traveling public then (by comparison with previous opinions on the fora that diesels locomotives were initially perceived as dirty, oily polluting beasts)?
