Brians Workbench
Hi Guys here's the latest update
First here's one of my re-repainted Mk 3's
c150e2a7.jpg?t=1335206033
Here's the start of the kadee's being fitted but after seeing them run with the cravens I might just leave them to the loco's and coach rake ends so I might fit the cravens with the roco couplings
5f799c32.jpg?t=1335206026
63f45f0c.jpg?t=1335206024
  • 1 month later...
Hi Guys
After a long battle with a new printer:confused: I finally got around to making the free containers that FrankS pointed out
They are easy enough to make ,but the use of thick paper/card and balsa wood for strengthening really makes a difference
Here's the link to the pictures
http://s1096.photobucket.com/albums/g329/brianwalshmk3/?action=view&current=d412848a.jpg#!oZZ1QQcurrentZZhttp%3A%2F%2Fs1096.photobucket.com%2Falbums%2Fg329%2Fbrianwalshmk3%2F%
The 201 has now been sprayed orange
68392421.jpg?t=1340921340
Also I'm currently in the process of respraying all of my MK 3's
Here's the first
48669df9.jpg?t=1340921342
For some reason it hasn't completely dried:( so I might try it again
Brian it might be an idea to spray more light coats and allow it to dry between coats. Any little blemishes or imperfections can be rubbed out with some very fine wet and dry. I know that when I sprayed my first models many years ago I was a little enthusiastic and tended to spray more heavy coats. Four or Five light passes of the airbrush or rattle can will give much better results than one or two heavy coats.
I use a dual action airbrush myself Brian as it allows you to control the amount and flow of the paint. It's been one of the best investments I have ever made. You have done smashing work with the 201 and MK111 coach in your first pic and the Kadees look great on your Cravens. Keep up the good work and you will be a match for anybody on here soon, well done :tumbsup:.
Rich,
Rich,
Thanks
I had a thought a while ago to convert some redundant Mk 4 coaches to Mk 3's
The Mk 4 is a few mm longer than the Mk 3 but that doesn't bother me too much
I started by cutting the 8 windows out of the coach all in one piece
I then cut out one of the square vents/windows
I put the square window/vent at the opposite end of the coach and glued it in place,then I sandwiched the windows inbetween
666d9ddf.jpg?t=1341483860
8296865d.jpg?t=1341483863
Another project is to convert the 3 window Hornby Mk 3 Buffet into the Irish version
Here are the unfinished results
27f5193e.jpg?t=1341483880
aa36a693.jpg?t=1341483877
9795e04a.jpg?t=1341483870
Here it is with the Mk 4/3
398de12b.jpg?t=1341483883
e5350c47.jpg?t=1341483886
The gaps on The Mk 4/3 will be filled before painting
  • 4 months later...
Here is a little project I thought I'd do for a bit of fun
It's a 4 wheel timber wagon
did it with no drawings or anything out of pure laziness
I might try the rest of the rake with proper drawings and am I right in saying that a dapol prestwin or presflo would be a sutable chassis?
8C70769F-27D9-4E7E-A2D7-D3B280FF8BE2-1444-00000234ABA9EA23.jpg?t=1352741576
D847C585-2F39-481D-A9C4-FDAA174E482A-1444-00000234B5402A24.jpg?t=1352741580
48947460-27EB-444E-B17B-57F7E4BA4E22-1444-00000234BA692874.jpg?t=1352741584
And no 112
Yet to be weathered and fitted with Kadee's
CA7E3608-9634-4E4D-BD23-0E67F76C9AC5-1444-00000234C16603EF.jpg?t=1352741594
BA6A8528-F003-45D9-99C3-3B690B440758-1444-00000234C73D0C02.jpg?t=1352741613
Good man, a nice way to kill a few hours. I bet you enjoyed it, well done.
Rich,
Cheers Rich
Next time i will use more accurate measurments and hopefully get something good out of it
Cheers Rich
Kit bashing and scratch building has always played a big part in modelling Irish Railways. I'm glad you enjoyed it and it looks like you know what you are doing, so that's half the battle.
Rich,
Doing a prototype, no matter how bodged (!) is the best way to find better ways of doing things. It just means that when you go to build a rake, it should be fairly worthwhile! :-bd
Good advice from a master. The more he does Richie the better he'll get and the more enjoyment and personal satisfaction he will have. BabyGM you're on the right road and you'll only get better, good for you.
Rich,
that wagon is a little beauty and looks so simple to do (but i bet its not!) i hope your baseboard runns fully up to the wall in your gaff....dont want the gm to go overboard!
Thanks Heirflick
It dosen't run quite up to the wall but I'll be putting plastic around the edges to protect all of the stock
Looking good nice to see you getting into modifying RTR locos. :tumbsup:
Thanks:D Next step is painting
I've been thinking of modifying a Hornby Black five to 800 Meadbh
The Scot class is a closer match to Meadbh as far as I'm aware. As far as I know I think Weshty has the decals for the 3 800 class. Make sure you get the newer Super detailed Hornby Scot as they are fantastic runners, the Bachmann Scot has the wrong firebox shape. Drop Heirflick a wee PM as I think he has one and may post up some pictures for you
Edited by Anthony
Thanks I'll look into it :)
  • 3 weeks later...
I only got around to doing some work on this in the last few days
I added the brass and whitemetal pieces though I haven't bothered with the cab detail
15792D2F-0220-489A-AB48-C7F4FD4B0557-1599-0000017290C11924.jpg?t=1354478312
56989993-297D-4217-8FE8-DD1E5D296BEB-1599-00000172A34041D3.jpg?t=1354478327
C3109403-9484-46D8-974A-619C8974AE22-1599-00000172B446BCEB.jpg?t=1354478331
F744A337-55D8-49CB-8CAC-5A82EA1F4969-1599-00000172D1CAA761.jpg?t=1354478349
You did a lovely job on the j15. What livery are you going to paint your 071 in when built?
Thanks,
Originally it was going to be in the freight livery, however changes in the release dates of the MM 071's changed my mined to IE orange
