Bachmann announce new 21pin chip
About time Fran they've fallen behind big time in this sector
Yep, interesting to see how good they are and what price they will be. I have 141s, 20s and 37s I'd like to pair up!
Be interesting to see if they're any use in the 071s and 201s too.
Originally Posted by heirflick
fran, just out of interest, if you wanted to doublehead, why not remove the motor from one loco?
Double heading on models in some cases is just like the real thing as you need extra power to pull a train up an incline. Imagine the yank modellers taken the motor out of their locos to pull there long trains using just one loco. There wouldn't be enough power.
Edited by Anthony
I like to have the extra power especially on long trains and big gradients Seamus. And sometimes I'd want to run them single too. DCC gives you nice flexibility to do both.
You can always set both locos to the same address.
You can but then they're the correct lighting patterns to worry about! Maybe I take this too seriously....
no fran, you are right! if you are going to do it , do it properly!:)
Well that's not a problem as you can map the light functions to suit the consist.
That's a lot of faffing around though for me. Advanced consisting would sort out the lights when two locos are put together and when you put them back they can return to normal without extensive programming.
I see the new chips are made by Soundtraxx as opposed to ESU (who made the old Bachmann 21 pin and 8 pin chip) and is in the Blue Pullman. I can say that they are super smooth in my BP and the yank tsunami sound decoders I have are top notch control and sound wise.
I bought 4 of them from Marks Models, they are made by Soundtraxx. They are supplied with all CV's set to 0. So if you have a basic DCC controller you won't be able to program them.
Interesting Dave, thanks for that. Can you remember the price?
It was around €80 for the four. I wasn't impressed to find they are not programmed. I have the basic Dynamis so I'm changing it for an NCE Power Cab.
But AFAIK you can program CV's with the Dynamis can't you?
Dave do you get a list of CV's with the decoders so you know what's what
Yes you do, they are
Primary address 3
Start Voltage 0
Acceleration rate 0
Deceleration rate 0
Max Voltage 0
Voltage Mid point 0
Version 96
Manufacturer Soundtraxx
Extended address 192
Extended address 3
Consist address 0
Speed table select 0
Configuration 6
Thats the full summary
Primary address 3
Start Voltage 0
Acceleration rate 0
Deceleration rate 0
Max Voltage 0
Voltage Mid point 0
Version 96
Extended address 3
Consist address 0
Configuration 6
I've ordered one from Hattons so will give you a call and let you know how I get on. BTW check out RM web to see if anyone has put up any info regarding reviewing/programming of the new decoder.
I've ordered one from Hattons so will give you a call and let you know how I get on. BTW check out RM web to see if anyone has put up any info regarding reviewing/programming of the new decoder.[/quote
I'll check it out, cheers man.
You can only program with the pro box and its €200
Marks Models had the Probox in stock till fairly recently, Price E119.99, You can read back CVs etc with that unit.
They also have the new decoder in as well.
Cheers
George.
