Mol_PMB Posted February 2, 2025 Author Posted February 2, 2025 Of the old wooden containers, the common larger types were classified 'B', or for those with side doors, 'BD'. Again, there were many variants on BR, and more on CIE. The BR container diagram book can be found here: http://www.barrowmoremrg.co.uk/BRBDocuments/BRContainerIssueB.pdf These were quite common in Ireland and can be seen in some of the photos linked above, and a few more here: https://www.flickr.com/photos/irishrailwayarchive/53511462788/ https://www.flickr.com/photos/irishrailwayarchive/53511606818 https://www.flickr.com/photos/irishrailwayarchive/53511583540 https://www.flickr.com/photos/irishrailwayarchive/53511614184 Models of BR (and 'Big 4') types available include a vertically-planked type B originally by Airfix, now seen in the Hornby range but there's also a near-identical one by Dapol: Also a horizontally-planked type B with broad planks, in the Dapol Range. This is very similar to one of the CIE types as detailed a few posts back up this thread: https://www.flickr.com/photos/irishrailwayarchive/53500993248 https://www.flickr.com/photos/irishrailwayarchive/54255303079 The one in the background here is slightly different but an attractive livery of 2-tone green: Bachmann have one of the most common BR types also often seen in Ireland, the BD with narrow planking and side doors: Parkside also make a kit for something very similar, some subtle differences in the door strapping: Parkside also make the FM container, which was a bit smaller than the BD and was fitted with some insulation (though not heavily insulated like the AF). These were used for meat. The Parkside FM kit is for the planked version; the ply-sided version can be seen in Ireland here: https://www.kennellyarchive.com/media/39c56ad9-d5c2-4fcd-953e-c6112f4cf106 The CIE containers of the 'B' and 'BD' types were mostly made of alloy-faced ply rather than planks, as seen on this example which survived long enough to get a roundel: https://www.flickr.com/photos/irishrailwayarchive/53498764321 (There's a rarer BR insulated container in the background of this shot too, but we can't quite see enough of it) A few more in the backgound here in 1970, again these look to have roundels: https://www.flickr.com/photos/irishrailwayarchive/53511639484 The grey ones in these two images: https://www.flickr.com/photos/irishrailwayarchive/53570643358 https://www.flickr.com/photos/irishrailwayarchive/53570648873 And the three with yellow plastic sheets over them here, again at least one of these has a roundel: These CIE containers don't seem to have a direct equivalent in model form, all the model ones are planked. This is a pity because BR did have ply-sided ones and they would be a good match to the CIE ones. Some of the Irish planked containers had diagonal planks, either all in the same orientation or in a Vee pattern. I haven't seen any commercially available models with this arrangement of planks. Some real examples: https://www.flickr.com/photos/irishrailwayarchive/54255495975 https://www.flickr.com/photos/irishrailwayarchive/54255299053 https://www.flickr.com/photos/irishrailwayarchive/54255303904 https://www.flickr.com/photos/irishrailwayarchive/54255072361 I'd imagine that these would be fairly straightforward as 3D prints but I'm afraid I don't have that expertise. I also found a laser-cut kit for a BM container; I've not seen any of these in Ireland: Peco used to do some OO card kits for containers. Not Modelscene produce this, but probably not an improvement on the ones shown above: This thread on RMweb shows some different 3D printed examples, all GB prototypes: https://www.rmweb.co.uk/forums/topic/182716-big-4-pre-nationalization-container-diagrams However, it may not be too hard to scratchbuild, kitbash or simply repaint CIE examples from what's available. Many of the BR types are pretty close as shown above. 33 minutes ago, commerlad said: OK Not Irish I admit but The Bachman or Cambrian versions are close enough (for me at least) http://www.island-images.co.uk/Rail/Railstock/SteamStock/Q290739.jpg The livery, Simple DIY transfers. https://us.docworkspace.com/d/sIMm70cYj54j_vAY Help yourself to the design if you want a couple. Very nice! There were and still are some interesting container services to/from IoM. Ronagency was one I was looking at a while back.
Mol_PMB Posted February 3, 2025 Author Posted February 3, 2025 (edited) I found one more traditional container option - made by Replica Railways. I don't think these are in production any more but are available secondhand. This has the diagonal timbers in a vee pattern, which (with a repaint) would be ideal for those wanting to model a GNR furniture removals container, as seen at Broadstone in the links below. They had a very attractive livery. DSL_GNR_163_Broadstone_Dec_1960 (2) | [Photographer: Des Sca… | Flickr https://www.flickr.com/photos/irishrailwayarchive/54255495975 Edit, still available here, new and unlettered, for a fiver: Spares Edited February 3, 2025 by Mol_PMB 1
leslie10646 Posted February 3, 2025 Posted February 3, 2025 Re the Dapol one. This was one of my original quartet of wagons in 2007. I did these flats, similarly lettered, for No.4 Furniture container also. I think I have seen such containers as high as No.6! You can find them in various books. The CIE one would be easy enough to do but Dapol don't just do containers painted to order - I think I have to do a flat as well! They sell them unpainted as a pair. If anyone is interested in a "pretend" CIE Flat (lettering can be researched) with the white container - speak up! I've been looking at ways of doing a GNR / CIE / CDRJC half container of the type which was to be fou8nd latterly on the narrow gauge. Maybe a 3D print. 2
Mol_PMB Posted February 3, 2025 Author Posted February 3, 2025 Very nice! Sorry, they were a bit before my time and I hadn’t realised you had done them already. I have seen GNR numbers up to 12 I think, certainly into double figures.
Ironroad Posted February 3, 2025 Posted February 3, 2025 Given the direction this thread is taking it is worth mentioning that Some of the postings in the thread "We Got a Flat" -Announcing the Bullied & PWD Flat Wagons" are relevant to this conversation for example; https://igg.org.uk/rail/5-unit/unitload1.htm Fig ___ Standard closed containers 2
Mol_PMB Posted February 3, 2025 Author Posted February 3, 2025 27 minutes ago, Ironroad said: Given the direction this thread is taking it is worth mentioning that Some of the postings in the thread "We Got a Flat" -Announcing the Bullied & PWD Flat Wagons" are relevant to this conversation for example; https://igg.org.uk/rail/5-unit/unitload1.htm Fig ___ Standard closed containers Many thanks! It's strange, but to date I haven't found any photos of the Bulleid triangulated flats (as modelled by IRM) carrying enclosed containers of A / B / BD types or equivalent. Loads of photos of them carrying road vehicles, acting as runner wagons for overhanging loads, one pic with an open container, and a few other niche applications. Containers are much more often seen in open wagons (wooden or corrugated), or on GNR or CDR flats, or on the later type vac-fitted flat wagons such as the 25201 and 25436 series.
DJ Dangerous Posted February 3, 2025 Posted February 3, 2025 (edited) 49 minutes ago, Mol_PMB said: Many thanks! It's strange, but to date I haven't found any photos of the Bulleid triangulated flats (as modelled by IRM) carrying enclosed containers of A / B / BD types or equivalent. Loads of photos of them carrying road vehicles, acting as runner wagons for overhanging loads, one pic with an open container, and a few other niche applications. Containers are much more often seen in open wagons (wooden or corrugated), or on GNR or CDR flats, or on the later type vac-fitted flat wagons such as the 25201 and 25436 series. Somebody posted previously, possibly @DiveController but not completely sure, that the IRM Bulleid Flats never carried containers, only vehicles and loose loads. Edited February 3, 2025 by DJ Dangerous 1
Mol_PMB Posted February 3, 2025 Author Posted February 3, 2025 There’s always an exception to prove the rule, and this photo has a couple of good ones. https://flic.kr/p/2qE13Mk Lurking behind the grey H van with a black underframe, is a Bulleid flat carrying a container. But it’s an open container not a closed one, and it looks like it’s incomplete and here for repair, so not actually in traffic. This is the only example I’ve found of a container on one of these wagons.
Mol_PMB Posted February 16, 2025 Author Posted February 16, 2025 A photo newly uploaded by Ernie has some items of pre-ISO container interest, though only in the background. This is Galway in 1967: Just to the right of the loco, a 'Lancashire Flat' on a 20' fitted flat wagon, probably 25201 series. And to the left of the loco, a couple of CIE road division's livestock swap-bodies, painted dark green. I am also exploring the potential of one of these for a CIE container. It has the advantage of no planking, and I think it won't need much surgery to fit in a corrugated open wagon. Despite being a very old model the moulding detail is quite good: 1
Mol_PMB Posted March 24, 2025 Author Posted March 24, 2025 A very fine selection of CIE container images have recently been uploaded to the IRRS Archive on Flickr - many thanks Ciaran! These are all from around 1975: CIE 40' with side doors CIEU 060138: https://www.flickr.com/photos/irishrailwayarchive/54403834639 CIE 20' bitumen tank CIEU 060442, a very nice set of detail views: https://www.flickr.com/photos/irishrailwayarchive/54403662801 https://www.flickr.com/photos/irishrailwayarchive/54403834634 https://www.flickr.com/photos/irishrailwayarchive/54403662786 https://www.flickr.com/photos/irishrailwayarchive/54404027845 CIE 20' half-height open top CIEU 060018: https://www.flickr.com/photos/irishrailwayarchive/54402779127 CIE 20' double side door container CIEU 060750: https://www.flickr.com/photos/irishrailwayarchive/54403893218 CIE 20' side door container CIEU 060510 (?): https://www.flickr.com/photos/irishrailwayarchive/54403834674 CIE 20' tiltainer CIEU 060234: https://www.flickr.com/photos/irishrailwayarchive/54403893223 CIE barley hopper container CIE 480: https://www.flickr.com/photos/irishrailwayarchive/54403893248 CIE 20' insulated container CIE IRL 2071: https://www.flickr.com/photos/irishrailwayarchive/54402779217 Small non-standard tank container, informal number only: https://www.flickr.com/photos/irishrailwayarchive/54403893098 CIE 10' bulk glucose containers, one of each type (the cylindrical tank and the cuboidal version CIEU 060144) https://www.flickr.com/photos/irishrailwayarchive/54402779167 This shows the opposite side and end of CIEU 060144, and beyond is the end of a cylindrical one: https://www.flickr.com/photos/irishrailwayarchive/54403834694 There are also a selection of CIE swapbodies, some of which may come under the 'Lancashire Flat' designation: https://www.flickr.com/photos/irishrailwayarchive/54403834579 https://www.flickr.com/photos/irishrailwayarchive/54404027740 https://www.flickr.com/photos/irishrailwayarchive/54403893238 https://www.flickr.com/photos/irishrailwayarchive/54403662761 It's also worth looking in the background of these photos for other container and wagon types. Excellent inspiration for some intermodal modelling!
commerlad Posted March 24, 2025 Posted March 24, 2025 On 2/2/2025 at 7:50 PM, Mol_PMB said: Very nice! There were and still are some interesting container services to/from IoM. Ronagency was one I was looking at a while back. Do you have a link to a photo at all?
Patrick Davey Posted March 24, 2025 Posted March 24, 2025 Interesting thread, with cracking photos! 1
Mol_PMB Posted March 24, 2025 Author Posted March 24, 2025 8 minutes ago, commerlad said: Do you have a link to a photo at all? My previous model railway was/is based on the Manchester Ship Canal and I looked at the Manchester Liners containers in great detail. In the late 1960s they leased containers from CFC, and I wrote a little document to collate my information on CFC. Why is this relevant to your question? Because CFC also leased containers to Ronagency, as well as some of the Irish Sea operators like Greenore Ferry Services. So the attached pdf may be of interest, although it's a bit tangential. Ronagency served Castletown and this shows one of their ships there, with containers in the background: https://www.shipsnostalgia.com/media/m-v-tower-duchess.134401/ CFC_Commercial Finance.pdf
Mol_PMB Posted March 30, 2025 Author Posted March 30, 2025 More container photos in the latest IRRS upload: CIE furniture container in dark green with diagonal 'eau de nil' stripe, in a wagon: https://www.flickr.com/photos/irishrailwayarchive/54419737288 BR container in a UTA wagon with a GNR loco: https://www.flickr.com/photos/irishrailwayarchive/54419686089 CIE open container, with sheet, on a flat wagon: https://www.flickr.com/photos/irishrailwayarchive/54419695864 Some rather grubby older insulated containers in the background: https://www.flickr.com/photos/irishrailwayarchive/54418642707 End view of an early CIE ISO box, note the white lettering which was less common: https://www.flickr.com/photos/irishrailwayarchive/54418642157 Some nice 1980s ISO container variety: https://www.flickr.com/photos/irishrailwayarchive/54418592342 https://www.flickr.com/photos/irishrailwayarchive/54418592257 https://www.flickr.com/photos/irishrailwayarchive/54419646289
Mol_PMB Posted April 17, 2025 Author Posted April 17, 2025 (edited) From the book 'On the Move - CIE 1945-1995', a nice photo of a CIE container used on services across the Irish Sea on the Greenore-Preston route: A similar container in the background of Ernie's photo at Connolly in 1962: Edit: on the edge of this IRRS photo, one of these is shown in colour. It appears to be CIE dark green with white lettering: https://www.flickr.com/photos/irishrailwayarchive/53511302876 Edited May 30, 2025 by Mol_PMB marked in text 1
Mol_PMB Posted May 29, 2025 Author Posted May 29, 2025 In the NLI archive, alloy-skinned containers being built at Inchicore in 1959: https://catalogue.nli.ie/Record/vtls000304518 These are a very distinctive shape and I've never seen them on a railway wagon. Perhaps normally used by the road transport division? This one on the other hand is a more traditional shape and material, and nicely painted in CIE 2-tone green livery and on a flat wagon at Drogheda: https://catalogue.nli.ie/Record/vtls000305422 Could that be Shipping London chalked on the side? Also of note is that it's on a flat wagon (rather than the more usual open wagon), indeed LB flat wagon number 23415 of the type produced by IRM. So you CAN prototypically put a container on an LB flat!
commerlad Posted July 12, 2025 Posted July 12, 2025 (edited) Found another IOM one Can't say I know the type of container though. Anyone identify it? Edited July 12, 2025 by commerlad
Mol_PMB Posted July 12, 2025 Author Posted July 12, 2025 54 minutes ago, commerlad said: Found another IOM one Can't say I know the type of container though. Anyone identify it? That is an unusual shape and construction - possibly built by a road vehicle coachbuilding firm rather than a railway? Thanks for sharing. (The photo link worked for viewing on my phone but not on my PC - no idea why)
Mol_PMB Posted July 12, 2025 Author Posted July 12, 2025 A couple of other views of the pre-ISO containers, including some loaded on conflat wagons which was less common in Ireland. From Ernie, and just behind B159, is a BR 'BD' type container on a conflat wagon: A derailed container train with some conflats and containers at unusual angles: https://www.flickr.com/photos/irishrailwayarchive/54251716295/
Mol_PMB Posted September 15, 2025 Author Posted September 15, 2025 Some work is under way to produce a 3D printable version of the CIE alloy container of 1961/62, like the surviving example at Dromod: It is being developed by the same team who did these; I have provided prototype photos, dimensions etc: https://www.rmweb.co.uk/forums/topic/182716-big-4-pre-nationalization-container-diagrams/?do=findComment&comment=5345870 I will update this thread when more information is available. These containers are too long for traditional unfitted flat or open wagons, and need to ride on 25201 or 25436 series flat wagons. The 25436 series are quite well-known but the 25201 series less so - some photos and details here: https://irishrailwaymodeller.com/topic/17496-cie-ballast-wagons-late-1960s-to-1980s-not-hoppers-or-flats/#findComment-250654 It's a long shot, but does anyone have a diagram or drawing for the 25201 series flats? If not, I can probably work it out well enough from photos and known dimensions. Also, does anyone have any diagrams of CIE containers of this pre-ISO era? The 1965-built side door type shown in this RPSI photo would be of particular interest: Many thanks, Paul 2
commerlad Posted September 15, 2025 Posted September 15, 2025 (edited) Think I have found a fairly definitive set of standard container plans. BRContainerIssueB.pdf Just 1 of a large quantity of pdf's on a range of things (Buildings, Loco's, Coaches, Wagons, Track Machines etc) Edited September 15, 2025 by commerlad 1
Mol_PMB Posted September 16, 2025 Author Posted September 16, 2025 On 15/9/2025 at 7:54 PM, commerlad said: Think I have found a fairly definitive set of standard container plans. BRContainerIssueB.pdf Just 1 of a large quantity of pdf's on a range of things (Buildings, Loco's, Coaches, Wagons, Track Machines etc) Many thanks. That looks very good for the British Railways containers, which were common in Ireland. Some of the CIE ones were similar, others were rather different. I haven't yet found anyone with a copy of a CIE container diagram book that is old enough to show their pre-ISO containers. That may be because many of them were owned by the road freight division of CIE, rather than the railway. I think we can infer the dimensions of the traditional wooden types from the BR diagrams. The 1960s alloy containers were definitely bigger. Happily my plea for a diagram of the 25201 series flat wagon also produced an excellent result.
Mayner Posted September 16, 2025 Posted September 16, 2025 CIE produced an A4 spiral bound book with black & white photos and outline diagrams of freight stock and containers (in use and proposed) during the late 60s/early 70s in connection with its freight modernisation scheme. Seems to have been an internal use CIE document intended for staff in the freight sector I go a glimpse of the book at an MRSI Club night 50 odd years ago, but the club does not appear to have received a copy Its possible that there may be a copy in the IRRS Archive/Library or model railway club libraries. 1
Mol_PMB Posted September 17, 2025 Author Posted September 17, 2025 Is there anyone on the forum who lives close to Dromod? Or knows the people at the C&L museum there? We would really like to confirm a couple of dimensions on this container, to ensure that the 3D printed model ends up the right size. At the moment we're not sure the proportions are quite right. I'd be happy to make a donation to the C&L museum in return for 4 basic measurements. Cheers, Paul 4
Mol_PMB Posted January 5 Author Posted January 5 A nice pic showing CIE pre-ISO containers on CDR road vehicles at Letterkenny. The containers are the later type with side doors and have probably been interchanged from rail to road at Derry/Londonderry. Also interesting to see some of the CDR road fleet. John Powell photo on Flickr, Andy Lance collection. 6
Mol_PMB Posted February 3 Author Posted February 3 Thanks to Ernie, a nice shot showing two UTA pre-ISO containers, in 1964 at Larne. I've seen diagrams of these and photos of them on road transport, but not so often photographed travelling by rail. They were dark green with 'ULSTER TRANSPORT' in yellow/gold, and other lettering in white. 4
Mol_PMB Posted April 1 Author Posted April 1 One of the surprises on the Tailte Tours trip around West Cork was discovering an old CIE alloy container at Baltimore. We only had a very brief 'request stop' and I didn't have a tape measure with me, so all I have are some photos from a couple of the more accessible angles. At first glance I thought it was the same type as the one preserved at Dromod, but I was wrong. This photo from Pat Kirwan on Flickr shows the 1961/62 type of container on the left, with relatively sharply curved roof and 11 panels on the sides, this is the type at Dromod. However, the one at Baltimore is the 1962/63 type of insulated container, a bit taller with a larger radius on the roof and 10 panels on the sides, as shown on the right in the image below. 5
jhb171achill Posted April 1 Posted April 1 1 hour ago, Mol_PMB said: One of the surprises on the Tailte Tours trip around West Cork was discovering an old CIE alloy container at Baltimore. We only had a very brief 'request stop' and I didn't have a tape measure with me, so all I have are some photos from a couple of the more accessible angles. At first glance I thought it was the same type as the one preserved at Dromod, but I was wrong. This photo from Pat Kirwan on Flickr shows the 1961/62 type of container on the left, with relatively sharply curved roof and 11 panels on the sides, this is the type at Dromod. However, the one at Baltimore is the 1962/63 type of insulated container, a bit taller with a larger radius on the roof and 10 panels on the sides, as shown on the right in the image below. Note the lorry on the right still in green but with a "CIE" sticker over the "snail", a la container style. Hadn't seen that before. 2
Westcorkrailway Posted April 1 Posted April 1 They only seemed to half commit to that logo at the time so it is interesting to see it on things 1 1
Mol_PMB Posted April 1 Author Posted April 1 3 minutes ago, Westcorkrailway said: They only seemed to half commit to that logo at the time so it is interesting to see it on things This is the only carriage I have seen it on. Part of the slogan, but the typeface of the C.I.E. is consistent with the containers, not the rest of the slogan, so I think this can be considered to be the logo: https://www.flickr.com/photos/irishrailwayarchive/54372688542 As you know, it's on the annual reports for 1960, 1961, 1962 and 1963. Up to 1959 they have the snail, and from 1964 it's the roundel. 1
Mol_PMB Posted May 25 Author Posted May 25 Almost certainly yes. Maybe carries the remains of a later repaint in orange. Good find! A few similar ones were made for other ferry and transport firms. 1
Westcorkrailway Posted June 24 Posted June 24 Another Container, Near the entrance of Inchicore Works of I remember correctly 2 1
Mol_PMB Posted September 29 Author Posted September 29 Some container-related snippets from 'The Link', available online here: https://archives.cie.ie/records/CIE/9/1/1 (I found these while trawling for material on AEC railcars, which was also productive!) Not quite containers, but intermodal - road/rail demountable milk tanks (March 23, 1951) April 20, 1951: June 1, 1951. I think these cattle containers were only used on road vehicles - they were more like swap-bodies: June 29, 1951: Film Star? CIE Comet lorry and Container; July 27 1951 August 3, 1951: January 25, 1952: June 20, 1952: April 18, 1952: May 16, 1952: May 23, 1952: 5
Mol_PMB Posted October 1 Author Posted October 1 Some more from 'The Link'... Oct 31, 1952: These are more swapbodies than containers, but appear to be a predecessor of the ISO barley hoppers introduced later by CIE. Another photo of an insulated meat container in use, Dec 5, 1952: Moving on to the 1960s and the CIE magazine changed its name to Nuacht CIE, this appears in Nov 1960 Issue 3 showing the new container service from Greenore: September 1961 and the new aluminium containers are making an appearance: By July 1962 new bulk grain swapbodies were also being made from alloy in a similar style. It does appear to have lifting lugs on the roof, but probably a swapbody rather than a true container. A big zoom and crop on an IRRS photo of Barrack Street shows one of these in colour: 4
