Warbonnet Posted October 24 Posted October 24 As part of our deep diving on the missing link in Irish model diesel locomotives, our C class Project Manager Gareth Bayer has studied the history of these locomotives extensively over the past couple of years. Here he outlines the history of the claas, including their reliability woes, experiments and ultimate rebuilding with EMD power plants. Take it away, Gareth! CIÉ C Class History Delivered between 1957 and 1958, the 34 members of Córas Iompair Éireann’s C Class, numbered C201–C234, were designed for branch-line operation, secondary services and station pilot duties. At just 42ft in length and weighing 58 tons, they were the diminutive Bo-Bo counterparts to the 60 larger, six-axle A Class locomotives built by the same British consortium between 1955 and 1956 for main-line passenger and freight work. Both types had been specified by Chief Mechanical Engineer O.V.S. Bulleid, whose original recommendation to look across the Atlantic for new motive power was overruled. The family resemblance between the two classes was unmistakable. Developing just 550hp, the C Class locomotives were constructed by Metropolitan-Vickers, which supplied the electrical equipment and assembled the locomotives at its Dukinfield Works in Manchester. Nearby Crossley Brothers provided the two-stroke EST V8 engine, while Metropolitan-Cammell of Birmingham built the bodyshells and English Steel Castings was responsible for the one-piece Pennsylvania swing-bolster bogies. The similarities extended beyond their external appearance, with both classes using the same MV137CW traction motors and many other common components, although the C Class was not initially equipped with staff snatchers. Fuel capacity was also limited to 300 gallons. The cab interiors were almost identical and established a template for subsequent Irish diesel types, being designed exclusively for single-person operation with dual controls. Neither class was equipped with train-heating equipment, helping to keep the axle load to 15 tons and ensuring system-wide route availability. Within weeks of C201’s arrival in February 1957, the class had begun replacing steam on branch-line services, with the Farranfore–Valentia Harbour route the first to succumb to the new ‘baby’ Metrovicks. Cork and Dublin received allocations soon afterwards for pilot and goods duties, while steam was quickly displaced at Bray, Clonakilty and Skibbereen, on the Galway–Tuam route and on the freight-only Castlecomer branch. In October 1957, C204 began working cement trains on the new, three-mile Castlemungret branch. By the time the final locomotive was delivered in June 1958, C Class allocations had spread to Athlone, Limerick, Kilkenny, Mallow, Sligo and Waterford. For branch-line duties, ten locomotives were fitted with a jumper box on the bufferbeam to supply power for electric train lighting. Sadly, over the following five years, many of these local routes closed, along with numerous other lines across the country. The C Class often found itself working the final trains on routes destined for closure. This widespread loss of work left the ‘baby’ Metrovicks increasingly surplus to requirements, and they were frequently transferred to duties for which they were ill-suited. As well as sharing a family resemblance, the A and C Classes also shared many of the same shortcomings, reflecting the drawbacks of CIÉ’s rapid transition to diesel traction. The programme would see Ireland become the first European country to eliminate steam traction in 1963. As with the 1,200hp Crossley HST V12 engine used in the A Class and British Railways’ Co-Bos (Class 28), the EST engine in the C Class proved to be the fleet’s Achilles’ heel. Its unbalanced design caused vibration-related failures and fractures, particularly in pipework. These problems emerged early and were compounded by cracked cylinder blocks, connecting-rod big-end failures, defective pistons and cylinder heads, exhaust fires, braking problems, high-water-temperature shutdowns, water ingress into the Hoffman axleboxes, and generator and traction-motor flashovers. Despite numerous attempts to rectify these issues, it was clear by 1960 that new motive power was required, and CIÉ finally turned to General Motors. During 1962–63, more than 50 B121 and B141 Class locomotives arrived from LaGrange, Illinois, proving an immediate success. Their introduction eased the pressure on the railway’s most important passenger services, but there remained a need for the ailing Metrovicks to handle special passenger trains, freight, pilot and transfer duties. When CIÉ made further approaches to GM for replacement engines, its requests were rebuffed. The railway therefore turned to Maybach in 1964 for a pair of 12-cylinder MD650 engines to evaluate in a trial. With only around a third of the C Class fleet normally available for traffic—an even worse record than the A Class—and the type being woefully underpowered, there was no shortage of potential donor locomotives. C233 and C234 emerged from Inchicore following their rebuilds between August 1965 and May 1966, the pair being redesignated B233 and B234 to reflect their new 980hp rating. The rebuilding programme included enlarging the radiator grilles from six to ten elements and fitting a correspondingly larger roof fan. Bufferbeam-mounted vacuum pipes were also installed to allow the locomotives to work with AEC/Park Royal railcars. The rebuilt locomotives acquitted themselves well, although they were initially restricted to services between Dublin and Limerick. The repowering experiment demonstrated that the type could have a future with CIÉ, but the complicated Maybach engine was not the answer. The order for 12 B181 Class locomotives, equipped with the new EMD B-645E power unit, in 1966 appeared to be the catalyst that finally persuaded the Americans to release a pair of engines for evaluation in two A Class locomotives, A58 and A59, which were completed in 1968. The 12-cylinder EMD 645 engine proved a good match for the rewound Metropolitan-Vickers electrical equipment, and the remaining 58 examples of the A Class were subsequently rebuilt, with the programme completed by 1971. In September 1969, former C206 emerged from Inchicore as B206, fitted with an eight-cylinder, 1,100hp version of the same EMD engine. B222 followed in 1970. The pair quickly settled into services between Dublin and Tralee, later also working Cork services. While the A Class repowering programme was winding down in 1971, Inchicore managed to complete approximately one C Class conversion per month, beginning with B230 in February 1971. The final locomotive, B220, was completed in mid-1972. Like the Maybach-powered locomotives, which were not initially included in the GM repowering programme, the B201 Class was also fitted with multiple-unit sockets and bufferbeam-mounted control pipes to enable operation with similarly equipped B141 and B181 Class locomotives. However, only the Maybach-powered pair ever used this equipment. Other improvements included dual headlamps of an identical design to those fitted to the A Class, staff snatchers to permit use on mail services, and an additional underframe fuel tank that increased capacity to 540 gallons. The upgraded B201s found a new role on Dublin’s intensive suburban services, working alongside de-engined 2600 Class railcars from 1972. This partnership lasted until the creation of the electrified DART network in the mid-1980s. The locomotives also remained a familiar sight as station pilots across the network, while becoming regular performers on freight services, including the B+I liner train, cement and sugar-beet traffic, and permanent-way duties. The first casualty was B201, lost in August 1973. Although it had received its GM engine as recently as June 1971, it was bombed at Meigh while working a Dundalk–Derry freight train. It was the only member of the class not to survive the decade. The two Maybach-powered locomotives eventually received their GM rebuilds in 1979–80. Both retained their distinctive plated bodyside windows following conversion. The first withdrawals took place in April 1984, when 203, 204 and 207 were removed from traffic. No. 202 followed before the end of the year. Four more locomotives—210, 214, 217 and 231—were retired in September 1985 as the new 8100 Class DART electric multiple units entered service in increasing numbers. At the end of that year, the first of a planned six locomotives moved to Northern Ireland Railways (NIR), initially on lease, for freight and departmental work. Regular passenger duties were largely impractical because of their vacuum-brake-only status. Locomotives 216, 218, 227, 228 and 230, together with ex-Maybach 234, were renumbered 104–109 and became known as the MV or 104 Class. NIR purchased them outright in April 1986. A major cull of the class followed in September 1986, leaving only 213, 218 and 232 in traffic. The class officially ended its CIÉ service in November 1986, although 213 continued working as a pilot at Inchicore until February 1988. No. 218 joined its counterparts at NIR in 1987, following the discovery of a bent frame on 224. In 1990, desperate for long-distance rolling stock, Iarnród Éireann struck a deal with Leicester-based Vic Berry to exchange withdrawn C201 Class locomotives for British Rail Mk.2 coaches that had been sold for scrap. Fourteen locomotives were eventually cut up in the UK. These included several examples from Inchicore’s notorious ‘sound barrier’: a long line of redundant ‘baby’ Metrovicks intended to keep residential neighbours happy by providing a barrier against railway noise. Of the remaining locomotives, all but 226 and 231 were scrapped at Inchicore. No. 226 is now based at Carrick-on-Suir, while 231 can be found at the Downpatrick & County Down Railway in Northern Ireland. Both are preserved by the Irish Traction Group. Unfortunately for NIR, the anticipated freight contracts that had prompted the purchase of the 104 Class never materialised. No. 107 is believed never to have worked for the operator. Stored in its new NIR livery at Belfast York Road, it became the first to be withdrawn, in March 1993. It was scrapped alongside 224 at Ballymena in January 1996. No. 109 was out of use by August 1987 and was cut up at York Road in March 1993. Of the other four locomotives, 105 was withdrawn from traffic in November 1993 following a fire, while 104 and 108 were stopped at the end of 1994. MV106, formerly 227, was the last to remain in service, surviving until March 1995. It was subsequently preserved, initially at Cahirciveen, County Kerry, but exposure to the elements and later vandalism took their toll. The locomotive has since been scrapped. The other three members of the group met the gas axe at Harland & Wolff, Belfast, in August 1997. Like the A Class, their smaller counterparts wore a colourful array of liveries throughout their working lives. Both classes were initially delivered in a striking all-over silver scheme that extended to the running gear, where every Crossley-related oil stain was on full display. From early 1958, the silver began to give way to green with a thin Eau de Nil band, although by 1960 this had been simplified to all-over green. In 1962, the first examples were repainted in an attractive new scheme of black with a golden-brown lower bodyside and a white upper-body stripe, known colloquially as ‘black and tan’. Later in the decade, this was simplified to a more austere all-black scheme, relieved only by the ever-present red bufferbeams—a feature of CIÉ liveries—and a white band above the cab windows. Some locomotives later received half-yellow cab fronts, while at least one had a yellow bufferbeam. ‘Black and tan’ returned to the class in 1969, when prototype B206 emerged from its rebuild in the original 1962 scheme. This was subsequently modified to incorporate a dipped centre section on later repaints, with the exception of the Maybach-powered pair. In 1973, the Supertrain livery of golden brown and black made its debut on the class. The locomotives would wear this scheme until the end of their CIÉ careers. The six locomotives sold to NIR, meanwhile, received that operator’s all-over blue livery, complete with orange chevrons on the cab fronts. Pre-Order Your C201 Class Here! View the full article 14 2 2
jhb171achill Posted October 26 Posted October 26 A vitally important part of the railway scene from the late 1950s to the mid-80s. Great to see this project advancing. 2 1
Leyny Posted October 26 Posted October 26 (edited) It’s just as well that locomotives don’t have emotions. If they did, I’ve always thought the poor oul’ C Class would have had the right to feel like a very unloved child. They were damned even before birth, not only with the unreliability of the Crossley engines, but also by the fact the 8-Cylinder version they received was hopelessly underpowered. To put that into perspective, it generated only 63 BHP more than the Mirrlees D Class shunters. They shouldered those 2 design flaws as best they could but then suffered the further misfortune of practically all the lines they were built to serve closing within 5 years of their delivery. Lacking both the power and dependability for most revenue-earning duties, they spent the better part of the next decade spluttering around on the thankless chores of pilot work, transfer freights and PW trains, with only the very occasional passenger outing, and even then usually over no more than cycling distance. When they finally did receive the lifeline of a reliable and adequately powered engine, they were almost immediately assigned to arguably the most punishing diagrams in the book - getting flogged on the high frequency, start-thrash-stop cycle of Dublin suburban work. Passengers around the Capital came to dread the sight of them on a Push-Pull, not because of any shortcoming on their part, but for the increasingly decrepit condition of the coaching stock they were hauling or propelling. The lack of regard for them was also evident in the rather questionable decision to withdraw the class en masse in 1985/86. Stopping perfectly good, working locomotives still capable of hauling most passengers trains then in use on the network at the required speed never made much sense to me and time would soon illustrate the folly of that choice. It was already evident by then that they and their bigger brothers, the re-engined A Class, shared an Achilles heel - their electrical equipment. This had been rewound rather than replaced when the locos were re-engined. In terms of making that whole rebuild project economically viable, that decision was understandable at the time. But by the mid-80s, it was clear it had come at a price, as both classes started to suffer generator flashovers and traction motor failures (and sometimes even fires), as the equipment cried enough. Replacing these components was never going to be feasible, so none that suffered such setbacks ever ran again. The problem was that these issues occurred completely randomly across both classes. So after Management had consigned the C Class to the scrapheap, the Operating Department could only look on with gritted teeth as the numbers of A Class dwindled by the year, with no replacement motive power available. By the early ‘90s, Irish Rail were frequently 20 locos short of their daily required quota. Where might they have conceivably found at least a fair chunk of the motive power needed to plug that shortfall under a more enlightened policy? Well, you do the maths. Even in retirement, further misfortune and insult was inflicted upon the Class. It’s fair to say the sale of a half-dozen of them to NIR never really worked out, as the traffic they were bought for never came to fruition and they spent too much time sitting around to be reliable even for PW work. Many of the remainder in Inchicore were dumped opposite the running shed to replace the recently-scrapped Sulzers in the sound barrier. Some of these and others around the Works were effectively sabotaged by the rather unnecessary decision to replace the 567 engines in the Baby GMs with their power plants. The scrap-for-scrap deal with Vic Berry saw 14 of them return to Britain for cutting up, as if being banished from the land they had served in a final gesture of condemnation. Even beyond the cutter’s torch, there was to be further ignominy bestowed upon their memory, as the newest Class of GMs were allocated their old numbers, an Orwellian attempt to erase them from the history books forever. The model railway world has heretofore failed to show them due respect either. The Lima model was theoretically a tribute to them, except of course it was actually just a repaint of a BR Crompton - arguably fine for its time and place, but a tad affronting viewed through today’s lens. The Silver Fox version was an improvement, but itself was flawed and failed to capture the essence of the original. Even IRM chose less likely candidates for Production runs ahead of them. Now, at long, long last, we will all have the chance to show these quirky, troubled, neglected and spurned daughters of Irish railways some much needed love. Lord knows, they deserve it. Cinderella shall finally go to the ball. Edited October 26 by Leyny 13 3
jhb171achill Posted October 26 Posted October 26 An excellent account; and one of the most important announcements yet for anyone modelling 1957-86! 2
Colonel Posted October 27 Posted October 27 Am sure I'm not the only one, especially on this side of the water, who didn't appreciate what a varied life and career the little C class had. From a modelling point of view, their size alone make them ideal for a small layout - proper branch line loco, enabling much more interesting operation than a railcar shuttling back and forth. 2 1
Mayner Posted October 28 Posted October 28 Observed (if that the word) and travelled behind B201 class over several years on Dublin suburban and the Drogheda line. During the early 70s sometimes took the train (Saturday afternoons) from Connolly to visit the late George Hannah Malahide model/art shop. The regular consist appeared to be a B201, 3 coaches (Inchacore 51-53 stock) and BGSV (conversion of Bredin/Inchacore 51-53 stock) with working steam heating! Worked close to the line (at various locations) between late 70s and mid 80s. One striking memory is of an apparent procession of Southbound B201 hauled bulk cement (bubble) trains passing Howth Junction on a saturday afternoon, another was watching B201s noisely approaching/departing Tara St and crossing the Loop Line viaduct during the evening 'rush hour" from the vantage point of one of the upper floors of the (12 storey)Hawkins House. Final memories of B201 Class were of a number of survivors on Pilot Duty at the North Wall during visits to Ireland during the late 80s, earlier I remember large numbers of 'stopped" 001 & B201 at Inchacore following the comissioning of the DART. Although mainly associated with Dublin suburban services at one stage both the Maybach and GM re-motored B201 Class locos regularly worked main line passenger and freight workings. The Maybachs regularly worked Dublin-Limerick (via Nenagh) passenger services and bulk cement trains from Castle Munget. A GM re-motored B201 was rostered to a Dublin-Tralee passenger service before the class was concentrated on Dublin suburban services. The higher power output of the 645 engine and steadier riding of its swing link bogies, may have give a B201 a slight advantage over a B141 on high speed passenger work. (the flexicoil bogies considered to be one of the weak points of the B121,141.181 Classes) Drogheda appears to have regularly rostered B201s on freight duties, incl. Drogheda-Dublin Bulk and Bagged Cement trains (H & ex GN cement vans), Ardee and Navan-Kingscourt workings. The final Ardee branch goods appears to have been worked by a B201, while there is an account in an IRRS journal paper of a loco swap between 001 & B201 hauled gypsum trains at Navan. Apparently a 001 was rostered to an early morning Drogheda-Kingscourt and its laden return working, a B201 to a second mid-late morning working. The B201 scheduled to cross 001 on the laden return working at Navan. The crews (and 'control") agreed to swap locos at Navan as the 001 would be more capable than a B201 of hauling the heavier/longer second gypsum train over the more heavily graded Navan-Kingscourt section. 2 2
