Mallow to Killarney loco 164
Just watch the rough riding in the cab,I wonder
is it the track or the bogies on 164
I think the camera man may have had the shakes ;).
Bogies the roughest running was as he powed up on the newly laid CWR for the climb out of Headford Junction.
A light weight freight bogie was used under the Bo Bos and Yanks to keep within the axle load down, there is a story of the driver of a 121 on the up Enterprise in the early 60s having to make an emergency brake application approaching Malahide.
The loco was swaying so badly as he crossed the Broadmeaows he thought that the cab might strike the rather tight bridge at the Dublin end of the station.
Looks like a normal cab ride to me.
It looks worse than it is due to the hand held camera.
You have no room for a tri-pod in the cab.
Check out the last bit of my footage on this one as it picks up speed.
Wiggy.
Looks pretty normal to me, the cab always moved around fairly freely on the 141's/181's and I'd imagine it looks worse inside than it does outside.
Wiggy.
Wig, maybe its just happening for me but that video you posted is coming up with the message 'This video is private', and won't let me view it.
OK try that.
Youtube some how has changed all me videos to private.
Just had to change them all back to public.
It all so won't let me remove a subscribers video 'remove it from feed'.
Not sure what is going on with them.
Here is another one.
Wiggy.
Edited by wiggy
OK try that.
Wiggy.
Ta, it works now! Cool vids. The 075 one is a new one to me.
Just a guess but sounds like a typical software update, in-house with them, which has jumbled things up for some!
Edited by Blu Bianco
It's an experience that you can still have at Downpatrick any time 146 is running. DCDR sells footplate passes for the day. Usually it's steam on the public services, but 146 or A39 (and occasionally a "G") are regulars on the 12:30 empty stock to Inch Abbey, and the 17:30 equivalent.
  • 3 weeks later...
Ah but not at 60mph down the Kerry Line!
