richrua Posted October 25, 2016 Posted October 25, 2016 Simple question: What locomotives were assigned to the push pull mk3 set in ir/ie era ? Quote
0 Garfield Posted October 25, 2016 Posted October 25, 2016 All members of the 121 class apart from 121, 125 and 135 were fitted for push-pull working (although the equipment in 132 was decommissioned after a short time). Â The push-pull 201s were also used after they entered service: 206-209 and 215-234. Quote
0 richrua Posted October 25, 2016 Author Posted October 25, 2016 So I could use 222 with a push pull ? Quote
0 Garfield Posted October 25, 2016 Posted October 25, 2016 Can't recall off the top my head if silver/green Intercity-liveried 201s worked Mk3 push-pull services but there was a three-year overlap so it's quite possible... Quote
0 richrua Posted October 25, 2016 Author Posted October 25, 2016 Grand thanks. I smell my next project attempt. Quote
0 JasonB Posted October 25, 2016 Posted October 25, 2016 So I could use 222 with a push pull ? Â There's a couple of photos in a book I have here called from CIE to IR.The 201 is in the silver green Intercity livery pulling a mk3 push pull set. Quote
0 richrua Posted October 25, 2016 Author Posted October 25, 2016 Thanks Jason. That'll do . I have 222 so I will use it . It'll look good. Quote
0 Mayner Posted October 26, 2016 Posted October 26, 2016 :trains:Used to work near Pearse Station in 2003-4, during off peak periods there used to be a great line up of 201 powered Pushpull Sets stabled between the station and the Boston Sidings. From memory the 201s were in the as delivered paint scheme the large yellow nose scheme was introduced in 2005. Â Never thought I would get nostalgic about the MK3 Push Pull sets, though I developed similar feelings for Network South East 1st generation DMUs on Bedford-Bletchley & Gospel Oak -Barking trains Quote
0 hurricanemk1c Posted October 26, 2016 Posted October 26, 2016 Absolutely you can use IC locos on Mark 3 push/pulls. Not the best shot but: Â Â Quote
0 Railer Posted October 26, 2016 Posted October 26, 2016 On the box of MM 222 there is even a photo of 222 hauling a MK3 PP set out of Connolly on a GAA special. Quote
richrua
10 answers to this question
