Silverfox Models A Class
Sails
I recently purchased one of the above, RTR, my only problem, how do I get the body off to install a dcc decoder? Can't see any obvious screws/retaining clips. Any feedback from someone who already has opened one up?
Regards
Mark
Hi Mark,
They tend to be held on with glue. Run a scalpel or thin blade around the base of the chassis and you should be good!
+1
Yes they use a soft setting glue that can be easily cut and pulled apart. It's like bostik.
  • 3 weeks later...
+1
Right I managed to cut through the glue after a bit of bother, not so soft after several years in place though. Unfortunately I managed to nick a couple pf wires in the process, I'll fit a decoder and see if it runs, however what should I do about those wires? Will they be okay? Hope the photos are okay.
Side note, what was this original beats judging by the chassis?IMG_4548[1].jpg
Thanks,
Mark
Hi Mark
Flowing in the footsteps of JHB I see! with the upside down photos:)
The wires look like they are still making contact, check to see if many strands are broken, even better check it with a meter continuity test, if there is you'll need to solder and insulate them. If still intact stick a blob of tek7 or the like on them to insulate and reinforce them....
If its a Mac camera you use and you take a photo with the camera upside down Windows cannot rotate it automatically like a Mac, you have to do it manually
Eoin
Ha cheers guys, rule number one of attaching photos, - don't do it without a tiniest bit of editing!!
Eoin, yeah don't see any obvious strands broken, sealing up as you say sounds good.
Thanks as always,
Mark
