Dave Dawes Posted December 12, 2019 Share Posted December 12, 2019 Hi all, I am thinking of going into the dreaded ( in my book) world of airbrushing. What would any of you recommend, it will be used mainly for scenery work Quote Link to comment Share on other sites More sharing options...
Wexford70 Posted December 12, 2019 Share Posted December 12, 2019 Good explanation here: https://spraygunner.com/blog/types-of-airbrushes-few-things-you-should-know-before-buying-your-first-airbrush/ Also some good courses if you are near the venue: https://airbrushes.com/product_info.php?products_id=22721 1 Quote Link to comment Share on other sites More sharing options...
RedRich Posted December 12, 2019 Share Posted December 12, 2019 I would always advise that an airbrush with a full catalogue of spare parts is a must. Prolonged use dictates that at sometime spare parts will be needed. Good luck with the airbrushing in the future. Rich, 1 Quote Link to comment Share on other sites More sharing options...
Georgeconna Posted December 12, 2019 Share Posted December 12, 2019 I can highly recommend a Badger 155. One Size needle, Plenty of spare, Had one now for 10 year, No issues. https://www.amazon.co.uk/BADGER-Airbrush-Anthem-BA1559-155-9/dp/B00397A3UI/ref=pd_day0_hl_201_1/260-9038622-4650453?_encoding=UTF8&pd_rd_i=B00397A3UI&pd_rd_r=93b20a18-925b-4d77-9322-af1b4feeb300&pd_rd_w=lJPoW&pd_rd_wg=bpV63&pf_rd_p=41dbe6ca-a21b-4cfc-8629-394c3728d27a&pf_rd_r=1BAMYSCSGJ0X38A6DH1T&psc=1&refRID=1BAMYSCSGJ0X38A6DH1T The Model 155-9 airbrush set features the "Anthem" with a Single needle/nozzle which sprays pencil lines to 3-inch (76 millimeter) patterns; includes air hose, jar, extra jar, extra needle and tip, cap, manual in a sturdy plastic tool box The Anthem’s body design provides exacting balance and long term user comfort for hobbyists, artists, crafters, T-shirt painters, body painters, taxidermists, sign and automotive painters; Dual action, internal mix, siphon (bottom) feed Single needle/nozzle for spraying all mediums, inks, dyes, watercolors, acrylics, enamels, lacquers, glazes, latex, Air-Opaque, Air-Tex, SpectraTex, MODELflex TotallyTattoo and Totally Tan colors Very user friendly airbrush; fastest patented needle release on the market; easy maintenance and cleaning with finger tight assembly tolerances and minimal spare parts to stock. Provides flawless performance in the most rigorous airbrushing environments Badger Airbrushes are American Made. One year on mfg defects with a lifetime on the PTFE needle bearing and any factory labor repairs I also use a top feed Renegrage https://www.everythingairbrush.com/airbrushes/badger-airbrushes/badger-renegade-series-krome-gravity-feed-airbrush.html he Renegades are for use in extremely detailed and tight graphic applications. The Badger Renegade airbrushes are superior to anything that has preceded them in the custom graphic market and they truly take your airbrushing to the next level. Badger have taken the advancements introduced in the Renegade Series onto the next level with the release of the New Badger Renegade Krome. Featuring New Chrome Finish, Air Valve Finger Rest, Cut Away Handle with Paint Flow Adjusting System and much more... Features Air Valve Finger Rest Cut Away Handle with PPS Paint Flow Adjusting System Improved Trigger Action Suitable for use with Acrylics, Lacquers and Urethanes Includes Badger Renegade Series - Velocity Gravity Airbrush 0.21mm 0.33mm Needle & Nozzle included Cup Lid 1/8bsp Hose Adaptor Presentation Case 2 1 Quote Link to comment Share on other sites More sharing options...
WRENNEIRE Posted December 13, 2019 Share Posted December 13, 2019 I like to use Tony Mirolo's air brush 2 Quote Link to comment Share on other sites More sharing options...
PorkyP Posted December 13, 2019 Share Posted December 13, 2019 Tbh i bought the most cheapo 'set' off ebay, with a small ' compressor' and everything, it was fine for my basic purposes of wafting a bit of muck over locos / wagons.... 1 Quote Link to comment Share on other sites More sharing options...
