Childhood layout photo discovered
Found this old photo of my childhood layout when I was about 12 or 13 many moons ago. I still have some of the rolling stock and buildings. I vividly remember mixing plaster to form terrain over scrunched up newspaper balls. No idea what the CIE shunter was. Most of the LLPs also survived and have walked the platforms of Kingsbridge. This was in the attic of my dads house.
  • Like 11
Is that a Wrenn tank engine on the passenger train?
I had one of those - big solid things. Wish I still had it.
Out of idle curiosity, if anyone else had one of those (4MT, I think the number was 80054), did you find that if you ran it chimney first, the 4-wheel bogie just wouldn’t stay on the track - it kept derailing? I always had to run mine bunker-first.
Also, would it be possible in this day and age to DCC-chip a thing like that?
  • 4 months later...
Expand
Yes that's an old Tri-ang MT with the hideous old X04 motors that started locos moving at 25mph, DCC might actually improve the crude motors performance due pulsed current and BEMF. There was certainly enough space inside those yokes to fit a decoder, but my memory is they were a horrible runner.
What I found was that you had to run them bunker first. Chimney first meant the trailing bogie lifted and derailed.
I thought it was just mine, in teenage innocence, but a school friend (who contacted me via Facebook two weeks ago, completely out of the blue, hadn’t seen or heard of him in 46 years!) had the same problem with the same engine.
I tried putting a small weight on it, but with limited space it didn’t make much difference.
Did anyone else have issues with these locos?
Apart from that I found it ok to operate.
Expand
That rings a bell alright. Tempted now to fish it out of the attic and give it a run on DC.
Edited by Noel
I had one and converted it to EM gauge. Ran without any problems, so guess I got lucky! Also used a Crown line detailing kit. Replacing the chimney was a nightmare as at the time didn't have the tools to cut through the cast Mazak body, which was unbelievably tough.
 The little diesel is indeed the Triang/Hornby 'Diesel Dock Shunter'. My one was a fearsome thing with a top speed of Warp 9 and sounded like an angry hornet. Had a working light though and would pull five coaches, which was more than my Princess Royal ever could! Strange, knurled wheels too.
Expand
Expand
I think that JHB and Noel are talking at cross purposes here. I believe that JHB is talking about the Wrenn 2-6-4 tank locomotive, whereas Noel is talking about the Tri-Ang 2-6-2 tank locomotive.
The Wrenn 2-6-4T had a tendency for the rear bogie to lift whilst under load. If I remember correctly, I think this was due to the tension lock coupling, being a retrofit to the ex Hornby Dublo bogie, being mounted a little lower than the standard tension lock fitted to Tri-Ang Hornby stock. The original Hornby Dublo version with it's buckeye coupling did not seem to suffer with this problem.
It is possible to fit a DCC Chip to a Wrenn locomotive, I fitted one to a Wrenn Duchess a while ago for a friend, but it requires a bit of surgery. The problem is that one of the motor brushes in Wrenn and Hornby Dublo locos is mounted directly in the diecast chassis, and needs to be insulated. This requires the brass brush sleeve to be removed, the hole enlarged and the brass sleeve refitted with an insulating sleeve.
