Everything posted by Georgeconna
Thanks lads...As I have said before its down the the Design of the kit, It is pretty much Perfect.Clean Crisp and solid Etched parts. Hope the Roof fits nicely once the Glazing goes in!! Thats my main worry!! This is the 1st time I used this primer and it is Brilliant, I used Car spray stuff before but this is Phoenix Stuff is excellent, It has Activation Properties that make sure the Paint holds onto the brass. I found with aerosol primers they did not have the grip and ruined the finish when you pulled the Masking tape off the paint came away in small Sections and thats with Tamiya Tape!! Looking forward to the Finish, Its gonna be Black and tan!!. Thanks George
Heres is the Lastest Installment, As I mentioned I had to solder up the Footsteps which were a Simple fold and sweat together, The Door handles were then soldered using a thin piece of Brass as a gap between the body and the door handle, I then soldered on the Water Tank Filler pipe and now she has a coat of paint on her.I used Phoenix Precision Etch primer which is a two part mix and man alive does it stink, I needed to open all the windows and doors in the Shed for this one!! Here some shots of the Fully Assembled Van. I must say I have enjoyed this model, A real joy to build and an easy one to start off with I think If you wanted to try a brass kit, That and SSM Brake Van. Now 2 more Vans to do.. Heres she is in Good Company Primer on: Now the Fun Begins!! and the roof needs fixing just yet, I wait till I put the Glazing in obviously!!
Yep All Soldered, Jut spent the Last couple of hours soldering the Footsteps, Door Handles, Water Filler pipes. Pictures shortly....
Could do with a Spring on the back of the coupler to keep it in check though but thats for another day.
Yep, Phoenix Precision etvh brass primer I use. The usual primers dont hold the paint on I find. G
Ready to plant Buffers For Taras
Georgeconna replied to Georgeconna's question in Questions & Answers
Horray, suggest you do a few extras den, A Lad down in Wexford wants some. G -
I wonder did these Van have Partitions in or Even cages for the Luggage?
Heres the next bit of work done, I needed to fit Tension locks Couplers on the ends as the chap running it has those on his layout. I used a slimline one. I drilled a hole in the Chassis floor and the Tension lock coupler and and using a bit of brass wire threaded through the hole in the Chassis, Through the Tension lock to Articulate it and then through the Resin Fuel Tank. I Sanded off the Excess wire flush with the Resin tank. It works an all!! Here you can see the Wire sticking up at the base of the End plate Here you can see the fuel tank with the hollow part in the Resin for a Kaydee or coupling of your choice. Great Idea. Here you see the Wire going from the above the Coupling and through the Coupling itself. Here you see where I sanded off the Excess Wire protruding from the Resin
will pas it on, Tks G -
Just wondering lads A Friend of mine is doing a rake as was wondering if there are Ready to stick Buffers that are like the Taras out there somewhere. I Know as few chaps Scratched their own but this route would save him a bitteen of time. G
Done another bit tonight, Hate to see what the ESB bill will be after this yoke. Started at 1000 and went till 0100hrs. Heres the pics of the Progress so far, Nothing tricky to report. Everything seems to go very well except when you think you know better and skip reading the Instructions. Wheel and bearings on Battery Boxes Went together well. White Metal fittings on. More to do. Roof Vent on Gangway Completed, Just need to Add the Crepe paper surround and the hanging bars: Other end to do tomorrow
Busy Enough Rich, 3 more SSM 20ton brake vans came today!!. Maybe time to advertise on Job Bridge for someone to build a layout for me!! only joking of course.....
Just beed using the Hold and Fold tool at the top this evening and it is a quality product for sure. The Handrail jig is next up!!
LOL, That jet wont be Oragne for sure, Thats was meant to be a quick build but is now in its 4 month. anyhow 1.5 hours later we have reached this stage: Everything went together pretty well except for the W irons where one set of tabs is fouled by the Solebars but 2 mins with a needle file and it was sorted. No problem. The roof is just placed on at this stage. Looking forward to the Next bit!!
Love the reverse Curve Kirlry.
Fantastic bit of kit, Thought out well too, I Like the ideas of the servos too as they are much kinder to the point and great possibilities with signals. Can see one of these being purchased in the future. Seems fairly Straight forward to work out how to do it also!! Thanks for throwing this up. G
Well the Postie arrived yesterday with a Parcel from the southern Hemisphere and by god what a package. Upon opening the box you are greet with a fairly substantial instruction sheet as well as some illustrations and a bit of history of the van. The brass was each packaged in its own Tissue paper,Lovely white metal pieces in a separate bag, Clear Acetate for the windows, Pre rolled roof and pre rolled side. In fact Mr Mayner has not left much out in all fairness. The kit looks exquisite. I told myself to hold back but I started as small bit tonight. There are some Fiddly bits to do, The Gangways probably the most difficult part. Over all a well thought out kit with Clear and Concise instructions that don't Confuse a Nation!! 10 out of 10 form me so far!! Heres some shots of the bits n bobs. Thnak you John for the Excellently Pre rolled Sides and roof!! Heres the Start. Sides and Ends Folded. Could not help Myself, Test fit of the Fantastic Roof Cheers G
Wow, They look Brilliant and almost could build themselves. Can wait to see them in the Flesh!
Cheers Rich.This had roof detail in the form of a Square section where the Exhaust pipes pop out. Has BB on the Etch though. The Grills aer soldered onto the inside.
Hi Lads, Aint done much in the Way of Building but have moved on and corrected the A Class over size white stripe and the little angle at the cab end. it was bugging me. Also restarted a Bill Bedford Mk.3 EGV Van, Not a good as SSM ones to be sure.. Hope to be able to stick a bit more up and I am getting back into the Swing of thing now. Cheers George
That sounds pretty good, Love the Exhaust note.
Despressingly Bloody good, The Little Railcar unit is fab as well.
Cements look pretty good to me and not a bad price either!!
Must take a look at those Eamonn - missed em. Met the guy the other week and a nice chap as well.
