Georgeconna
Everything posted by Georgeconna
  1. Err, That was myself or Roy Mckay (I sold my PC-9). I had a kit in my hand the other week but sold it. It was 1.72 resin. G
  2. Is the power track your using a orange coloured one?, Hornby have a DDC power track specially for DCC. If it is the Orange coloured Power track socket, then you can take off the cover and remove the Supression Capaictor in that or change it for a DCC power track which is: R8241 Also it could be the Back EMF is set wrong. Had this problem on a few baccy chips recently. Hope that helps but try the power track solution 1st. tks George
  3. cricky, Your a warrior for those 201 kits, Great work as well, Loving the weedspray to Had a chap that brought in a 08 that did not work they other day, DCC fitted as well. Took a look at it and found two holes had melted on the roof where the chip had been placed. Some amount of heat must of been produced to do that from such a small PCB!!. He thought it was the Exhaust ports!!!
  4. Its amazing what the eye does not see and the camera picks up, Need to tidy up the buffer casting as well by the looks of it!!
  5. In between quiet times I have been Beavering away with this one. Simple enough kit of a lovely Aeroplane. She is gonna be in Suez Markings.
  6. The MIL arrived tonight, Quick visit down the pub and back to the bench, 1st two 40fts are done, 2.5 hours soldering the attachment points along the side, Cleaning up and soldering them on took most of the time up. Quick wash, There are a bit wet still and touch of paint on em. The extra shim on the bogies came in handy as it is now nicley buffered up to the 141. There is some weight in these!! Quality model kit. It will be interesting to see the new version from SSM. I think will have a bash at the A Class in the correct scheme though.
  7. Excellent info. Bit of a minefield this or any railway stuff....!!!
  8. Yep have that book, As I mentioned or mad an excuse that the Decision on the number came a wee bit too late, I will change it I think for Accuracy sake anyhow along with the Back. Thanks for the feedback!!.
  9. Sorry HF, It is for a IE Driver so cant really flog it , Don't fancy getting thrown in the Tracks just yet!! LOL From me Metro Vick book I see some A Class had a straight line instead of the kinked one which was the one I was going with, The actual decision on the number came a bit late to change so is there a piccy of a Straight line orange A20r out there. I doubt it somehow...
  10. Found out!!!, knew about that kink but its a balls to mask as I have the handrails on, Gotta do it now though!!! Eagles Eyes Action Men!!! Cheers for the input boys..
  11. Ill stick all these in one post to save a bit of time: First up is the Q kits a Class, Got a little packet of buffers this am (Off a Hornby class 31) and test fitted them on, I am quite happy with them. Somethings bugging me though on this Model and that is the white stripe, Its a tad too wide, what do ye think lads? I might reduce the width a wee bit. The bit of Fibre optic is for the running lights so gonna have good fun with that now shortly. The white plastic patch was needed as the drillbit shattered the moulded raised light housing. You would not believe how brittle this it is . need to re drill a re paint that it too. Next up is the MIR 071, Painted black over the areas that needed and and she is a bit more presentable. Need to re fit that etch grill too. Next step is a gloss coat, Decals, Handrails, Lights. The 40fts got their bogies and I fitted some hornby tension lock couplings with a dab of the ol Superglue to test run them. They will be fitted with Kaydees so I am waiting on a sample pack that was picked up from Warley last weekend (Freaked out at the price of It!!!). I need o put a 2mm shim in between the bogie and the frame as the wheels where touching the frames when cornering. Little bit of plastic tube did the trick cut on a square. EDIT: just looked at these and the piccy quality is not great, I used a small setting on me camera so might up it a bit for the next ones.
  12. If there was a like button I would hit it!!! LOL. Spent many a frantic minute doing the homework on the school bus back in the day!! Thanks for the comments as well lads.
  13. Knocked this out during the week. No idea of the type of Bus, Brief was to paint it Schooly like an a biteen of country dirt. Decals from Wizard Whesty. He has Expressway decals one out know as well
  14. There 40ft and there flat, Mir kits from some chaps loft and it looks like he got them before I was born looking at the price!! Soldered together using carrs 70 Deg Solder and an adjustable iron. Lots of tidying up to do and I need to put a spacer between the bogies and the frame due to the fact if you have a curve in your layout there gonna get stuck. Had to cut back the under frame too as the bogies snag that. White metal is great to work with but a tad messy with the filings etc.
  15. The Airfix Skyhawk is a great kit. Is she gonna be Argie or Us ?
  16. They will be in the MM shops in Dublin and Cork. I will let him know of the interest and see what he will do. The small tins are E4.25 I think. Not sure what the 50mls will be. Cheers George
  17. They do the smaller tinlets of the other colours at the moment. tks G.
  18. Few an Post Vans on the go too. These are oxford Diecast with Studio Scale Models Decals.Need one or two coats or Varnish to Finish off.
  19. Lads, I was asking Mark could he get the Larger size tinlets in the shop as he got small Tinlets last year which sold out pretty quick . Is there any interest in the larger tins as I can give him an idea of how many to order? Cheers George
  20. Started this last year and have got the decks clear of some other stuff so need to complete it once and for all. I have the main brass and bits n bobs on and have spray the White first using Revell Satin white. The masked that off using 1mm masking tape. Then the black, Masked that off and Phoenix precision paint. I used a MM 071 as the template for the location of the white lines as as you can see the decal supplied by MIR are way too narrow hence the two white lines on the front, so I need to remedy that next when the decals dry. Microset was used to melt the decal around the raised detail. sorry piccys are great as I shot them on low size file
  21. Well its is their culture after all...
  22. Georgeconna
    Dick Fearn
    Is that good or Bad. There will be diesels running in the Schedule next there!!!
  23. yep, There was O gauge on sale at the Show. Not sure if they were repaints, There was a class 33 as a A Class and a couple of coaches. Not too sure of the Origins I dont have any pics personally but check the threads mentioned above for piccys. G
  24. Its N gauge that one,There was a 16ft layout with DCC block system, The wiring alone made me weak there was so much of it. unreal...
  25. Front page on the local rag, Why don't they ever do this beforehand, could of done with the publicity
