Everything posted by Si2020
Thanks Robert, Yes its for lights with each end having the following 2 x Marker lights 1 x Day light 1 x Night light 2 x Tail lights 1 x Cab 2 x external working lights 1 x Top light So around 20 wires for the leds to be threaded back to the decoders. There are some more wires ie pick up etc to add even more in to the mix. The job has been made a bit more difficult as it was sent to me to install the lights with no thought to how the wires would run etc. When i get roud to building my two then it will hopefully be a little bit a lot easier to install the lights. Thanks
Hi all, So not much has been happening on the layout recently as I've been busy with work and doing a couple of extra bits that I do. But you may have noticed that the layout now has a name, No Place. Now you are probably thinking he's lost the plot, (well I might have but thats a whole other story) but No Place is a small Village near Beamish in the north east corne of England. Just below the area seen on maps of dragons and other mithyical beasts!! Its ideal as I wanted to be able to swap the buildings on the layout to move the layout to different areas of the country to enable me to run different stock.
MIne was seeing Bath Green Park at one of the Exeter shows which i was exhibiting at and their fiddle yard got a hump in it. At one of the Railex shows whilst helping on Mini M-S-W with Alan we had all but one loco shunt down with the heat in the hall. It can be a strange one with the effects. Totally agree with the clearances on the FR and as you say best to leave the track to settle on its own as it normally returns to its starting point with the occasional help need. I'm tempted to do a test peice and het it up to see what happens.
Im the same, boxes of random stuff that has been "gifted" to me over the years and one day I will hopefully get to use it all. When I started building this the brass chairs hadn't been thought of so I used the copper strip and will probably leave them at the board ends as I have put down small sections of rail of about 1 cm long to act as sacrafical bits incase they get knocked plus they will be covered by some of the scenery. At the end of the rail sections on the rest of the layout, I will be doing the same as you and using them as anchor points for the ends. I did contemplate about soldering them to the rail but want to have the rail to have the abilty to move with heat. After seeing a few layouts developing track buckles and witnessing the effect of heat on real rail it makes you think. I may be going slighty over the top but when you have seen fishplate bolts loosened and the 65-lb rail expand to fill a 1/2 inch gap quicker than you can blink its made you think about how it effects the model.
HI all, The track laying was progressing along. To try and get nice flowing curves it was case of pinning the rail in place and then gluing the chairs to the sleepers whilst keeping an eye of the curve. The photo shows the entry and exit points in the fiddle yard.
Hi, I saw that one as well. Not seen any photos in this direction before and its an intresting view with lots of detail information on it. Things like the run of the telegraph poles and the stay on the down signal. Not sure that we can add it as the embankment on our model isn't deep enough at this point, plus we will probably catch it when cleaning the track.
hello, So had a few of these to make next There was about 60 odd in total which kept me busy for a few days.
- 56 replies
After a coat of L&YR blackberry black, some transfers and some wheels it made it on to the layout for a show or two. The roof needs replacing with some brass sheet as the plasticard that it comes with is too thick and I will also add the missing rainstrips and chimney to prevent it being knocked off.
Thanks, We can't take credit for all the photos that are posted up as some are from the British Railway Modelling Magazine article that was in the May 2019 issue after we had a photo shoot at the 2019 Doncaster BRM show with Andy York. We also do a few phtos for those Accurascale guys as they keep sending us stuff to play test on the layout I have to admit you may have been going a different way since that photo as I don't think we have had the lorry on the layout since. We have that much 80s stuff to go on the various 80s layouts, we have plus a couple of future ones that are in the pipeline
When we are at shows we have as much intrest in the fiddle yard as we do in the front of the layout, Seen here during one of our working weekends having the colour tape added to make it easier for guest operators to see which road they are driving in to.
Thanks
A bit of panel work on the bench, well the office table as the panel won't fit on the bench with all the bits on there at the moment.
- 56 replies
- 4
Hi all, A mixture of things on the bench at the moment with lots of re-spray and lining work happening and some some ditch light fitting
After a few more hours I ended up with this..... Still door handles and handrails to be added and then on to painting.
HI, I use various sizes of pin vice that hold bits from 0.3mm up to 3mm. Drill bits I use are from Expo tools and they last me around 8-12 months with the cutting edge becoming blunt after that but then I use then a lot and once blunt I still keep them for drilling in to softer materials and for applying glue etc. I also have a set of PCB drills to do anything in plastic as that seam to work better than anything else. One of the issue is that unless you are using a pillar drill as you drill by hand the dill bit flexes due to the movment of your hand. When using the samller dill bits I only have a few mm of the drill bit sticking out of the bottom of the chuck it try and give it a bit of strength whilst drilling. Also dont press down as you drill let the drill cut at its own pace as this also helps to prevent breakages. Lubrication wise, I don't on anything other than white metal and for white metal I use a bit of spit as it works better tha anything else. Thanks Simon
So one of the main problems when you model an era or railway company that isn't in the main stream market means only one thing......Kit building the 95% of the stock. So here is the start of a Dia 61 20T L&YR 6 wheel gaurds van being built from a D&S kit.
Not the grestest photo but here is one of the lareg logo 37s thats in the fleet with the Bachmann inspection Saloon. I have one of the Comet models one to build to add to the stock collection.
- 56 replies
- 6
