Everything posted by ttc0169
Friday night fun and trains on Tara junction. 127+130 work the FO Dublin Connolly-Sligo ten piece Cravens set 129+187 work an IRRS charter train formed of the Mk3 Executive set.
Many thanks to Arran for his excellent customer service and speedy postage,the containers arrived earlier today
Just purchased a Komatsu PC 340- ideal for ballast & gypsum loading
A good friend of mine who is not on the forum has contacted me and says the first photo is Ballina, and the third photo is what is now known as the Crossmolina road siding formally the Killala line beside the show grounds in Ballina-the bus eireann garage would be on the right today.
A variety of locomotive liveries can be seen here in this video representing the 1980s,1990s and 2000s era on CIE IR and IE IE 085 works a Mk 3 ser IR 127 working a passenger & mail train CIE 126+132 work a branch set which has a second BR GSV in the formation as insurance in case the heating in Dutch GSV fails.
The NTA-= No Trains Authority....useless shower of incompetents.
A selection of photos showing the preparation,installation and tamping of a new trailing FullSizeRender.mov FullSizeRender.mov crossover between the up and down lines at Tara junction station a few weeks ago. Locomotive 072 was in attendance with the bogie spoil wagons. FullSizeRender.mov
Three had the logos on the ends,1557 was one,I’m looking through my notes for the other two ,I think it was decided that the two white lines were enough on the Cravens
An additional Cravens coach was added to the mail train earlier, The coach was one of a small batch that had the IR points logo applied to to side during the 1990s
Fresh from the workshops and paint spray facility at Tara junction after its overhaul and repaint is Mk3 composite coach 7170, These coaches were part of a fleet of eight in the series 7165-7172 and were fitted with a first class section in one half and standard class in the other half. The exterior had a red thumbprint on the door area and the roofs were painted grey The coach is seen here after being added to the set which is working the 18:20 Westport-Heuston hauled by 085.
Order placed...
My wish list.....no pressure lads........ 1- Asahi two axle coal & oil flat wagons and twenty foot coal and oil containers, 2- Ammonia bogie and barrier wagons 3-Bogie bulk cement wagons 4- Bogie 62' timber wagons 5- Two axle timber wagons 6-Two axle MX type Guinness wagons
With thanks to Baseboard Dave for supplying the yard lights,they replaced a tower light that has now been moved to the bus depot.
cie The Road freight section at Tara junction
ttc0169 replied to ttc0169's topic in Trucks, Vans and cars
Locomotive 126 has arrived on a local service at Tara junction and is uncoupled,it then operated to the turntable where it is turned ready to work the evening
Just need to find the right programme to put the diagram onto.....
If the said coupling broke between the Cravens and the EGV then the locomotive could be used to shunt the coach quickly to a siding, Mk2 coaches had buckeye couplers while Cravens had screw couplings
No-Mk2s normally operated in fixed formations on a diagram that started and finished in Dublin Connolly or Heuston stations, On rare occasions if a fault occurred with a Mk2-then the coach would be locked off with passengers moved to another coach-with the offending coach being shunted next to the locomotive when returning to Dublin.
When the Ballina branch Cravens and GSVs needed to be swapped out for exams the replacement coaches would be taken from the Friday’s only service, When Mk2ds replaced the Cravens on the Fridays only service it was normal practice to attach the replacement coach between the locomotive and Mk2d EGV on the outward journey and again after shunting took place in Ballina the coach or GSV would be attached between the locomotive and first coach, On a few occasions I witnessed a Cravers coach ‘tagged’ onto the rear of the Mk2s,this technically wasn’t allowed due to the screw shackle being used to couple to the Mk2,had the coupling broken then it would have been difficult to recover-although the emergency coupling could have been used it would restrict the speed of the train to 25mph. Passengers were not permitted to travel in these coaches and they were always locked out of use while the rest of the train was in service.
