Horsetan
Everything posted by Horsetan
  1. That's the thing: you think you know people....
  2. I'm just after finding a possible answer to this. Very similar piston valve guides used to be available from Stelfox (now long gone) and were cast in brass for the ex-LNER K3 pattern. These were supplied in a pack of 4. On the outside face, they appear correct, whilst the inside is not. The idea is to graft the outside faces from one pair of castings to form the inside faces of the other pair....
  3. What Waterford could probably benefit from is some high-capacity drainage.....
  4. There's always India.....
  5. They've designed the website to not give you what you want.
  6. Manchester (MMSI as was) is a bit erratic when it comes to retrieving drawings. Their website has gone through so many changes over the last 7 years that it's virtually impossible to find what you want because the website is geared towards the general public, i.e. content-heavy, yet knowledge-lite. When I was trying to help Graham Nicholas with his kit design for the ex-Great Central "B7" 4-6-0, Manchester were able to find the full-fat GA on request. I think they charged me about £80 for a digital copy. I knew also that they had a similar drawing for the "B3" 4-6-0 because it had been published in a book about Great Central locomotives but, when I requested a copy, they were unable to find the drawing. Likewise, they also have a drawing for the GNR(I) S2 4-4-0, but they were unable to find that one as well - strange, given that it was previously available via their archive website.
  7. That's nothing. In Australia, they've been getting up to 40 degrees Celsius....!
  8. That type of thing also reflects the Irish outlook on life - not hidebound by rules or regs or, at best, paying only lip service to them. You couldn't imagine the Swiss doing that.
  9. That reminds me of a massive meringue....
  10. The greater good.
  11. Good, isn't it?
  12. I imagine there wouldn't be much change out of £150,000 for a model like that.
  13. I've never seen fully working Caprotti valve gear in miniature before.... ....and virtually everything just...works!
  14. CSET 0-4-0Ts
  15. Only if there's a plurality involved.
  16. It probably self-identifies as maroon.
  17. Meanwhile, Lough Erne has spent a longer period "out of use" than "working".... - shame she couldn't go on loan to Downpatrick, as she'd have a better chance of doing some work there if restored to steam. Incidentally, the RPSI page for "Erne" says she was the only one of the two 0-6-4Ts to carry red nameplates and then only after 1959. The photo of "Melvin" above suggests otherwise....
  18. Cabra sez No.
  19. That's a write-off, then. Would be good source of spares, though.....
  20. Out of sight, out of mind..... *shrugs*
  21. I'm not sure of the wisdom of trying a new way of poisoning the planet, when we already have some effective ones. Meanwhile, in Switzerland, this is practically identical to my car, inside and out. Pity the steering wheel's on the wrong side....
  22. Looks more like a fireless....
  23. "The instructions are all in feckin' German!!"
  24. I'm almost tempted, but A39r is probably a model I'll take with me to the grave. There won't be any more.
  25. Märklin might do modestly well if it offered British-outline EMU stock - then the 3-rail system might be justified! At the moment, the HO Gresley A3 is probably just a one-off, a bit like the Rivarossi "Royal Scot" or the Fleischmann "Warship". Not meant to lead to anything else, but useful to compare to Continental outline stock for an accurate idea as to relative size. You can see from the CAD and test-shot model that Märklin have applied their traditionally robust standards (not greatly changed from what they were doing in the 1980s) , so the valve gear links and pivots have been made overscale whilst the wheels have massive flanges. No, that was a Great Western "small Prairie" which also went to Poland and helped to run regular service on the line from Wolstyn.
