Bob49
Everything posted by Bob49
  1. What are yo planning on using for rail on your new masterpiece?
  2. It's tempting but as a club of one there is a limit on the size of a layout I can operate on my own at an exhibition. Marc
  3. Complete kits are available in 7mm with brass 3point rockers sprung buffers and 3link couplings. They can be done in G1, S and HO as bodies on demand. They are currently not listed on the website just because I've not got round to it. These is also a Dundalk Newry and Greenore 2plk open available as well. Marc
  4. I don't suppose they are doing one in 36.75mm gauge
  5. If they are no longer in production then I will have a go at doing some as kits if anyone else wants some let me know. Marc
  6. Are these still available?
  7. Try Alan Gibson (Colin) has a good range of P4 wheels. It's best to email him. Marc
  8. I a dipping my toes into P4 at the moment as an alternative to S7. Marc
  9. I was going for fair dodgers.
  10. I have built plain track using it in 7mm. It was pretty straightforward. Only issue I have in 7mm is they don't do check rail chairs for S7 so I went back to brass rivet construction for my S7 points. I have P4 point kit to build which has all the correct chairs. I believe that they do full sets of chairs in 4mm in OOFS, EM and P4 standards. So if your working in 7FS or in 4mm you should be fine.
  11. I have to say the brake van would be an interesting model
  12. Interesting prototype
  13. Those little platforms are actually quite common one lines around the world were tokens or staffs had to be exchanged. Marc
  14. Where would I get my hands on a copy of the GNR(I) coach book?
  15. Good Luck with the new job. Hopefully it somewhere nice.
  16. There is a 88 preserved and I have seen a drawing stating that the 48's could be supplied at any gauge between 2'6 and 5'3 so it is possible that a 48 came across the sea.
  17. In the 4ft8.5 world the smallest 6 wheeler I have found is a 28ft on a 18ft (9+9) wheel base built by the LSWR in 1879-83. After this date the length of the coaches grow out to 35ft with a 20ft (10+10) wheel base before the move to bogie stock in the 1890's. You can also guarantee that there was a coach with a dimension any where between the two. LNWR 6 wheelers were all 30ft1 long and the DNGR coaches were no difference.
  18. I managed to get a good look at a Dapol B4 tank yesterday. I was intrigued to see they held the roof on with twn nuts glued to the roof and two magnets attached to the inside of the cab. The magnets didn't actually come in contact with the nuts so there was no alignment issues. Marc
  19. Intresting cattle van on the left. Looks like an open topped one that has been given a flat roof. don't think I have seen one like it before. Marc
  20. The 2 plank is now painted. Buffers an wheels should be added tomorrow. I have also been working on 2.GNR(I) opens. A 4 plank open and a 6 plank open. These should be getting their wheels and buffers in the morning. Marc
  21. Looking good Marc
  22. If I'm using rattle can, which is mainly for primer. I stick the can in a bucket of really hot water for five minutes before I use it. It gives a more even coat. Marc
  23. The wagon is in 7mm but as it's a print can scale it down very easily. I've got some brass subframes on there was so I can build it at 36mm track. The print angle is worked out on the ratio between the number of pixels per square inch and the size of the slice. So it will change depending on which printer you are using. There is a web site where you can put your printer in and the thickness of slice and it gives you the angle. Your holes could be because your build plate might need an extra waiting time to allow the resin to settle before the light comes back on. I had the same problem and this solved the problem. Marc
  24. Hi David, Thanks for the tip I will check your thread out. Marc
  25. Fresh off the printer a DNGR dia 1 2plk open. I'm hoping to have it finished in then next week or so. Marc
