To address both Horsetan and Warbonnets thoughts, the Minimum wage in Ireland is €8.65 an hour. So let's start with that in respect of the chassis alone. I timed it this evening to trim, fix, add larger irish buffers plates, and add some detail. Cleaning up the underside and adding a passable brake gear would easily take another 15 minutes. So we're up to €16.00. Squirt of primer and let the whole thing dry, another 50 cent. Oh and what if you wanted steps for that brake van, or a plough for the ballast plough. Another half hour to get them right, form them, wait for them to glue, so we're up at €21.00. At this point lets assume, as a wagon, I'm going to do the Ballast Plough. Do I ask the punter to pay for my design skills that are put into it spread over the cost of the amount of wagons I intend to produce?
Of course I do. A meagher rate of €22 per hour would be absolute base, and looking at least 8 hours to produce and refine accurate CAD drawings would be damn fine progress. So let's go with that for pig iron. €176. Let me assume I'll sell 36 of those units over the lifetime of the project, that adds another €5 to each kit.
So, quick recap. Loads done, but only a chassis glued together - €26.00. I need to cut out the styrene parts to form the cab, glue them and let them sit. €1 for the styrene and 1 hour to assemble the cab. €35.65
By the time I form a roof, get the ventilators, add the handrails to the sides, another hour has gone by. €44.30 - say €45.00 to pay for the brass and the glue and the vents.
Another squirt of primer, and let her sit. Paint will take another hour in the morning, and that's only the base coat. €53.65 and wait for the base coat to harden, usually overnight. Make it €55 to pay for the paint. And the masking tape.
Decals can be sourced from whomever, say €2 as a rough figure. It takes me ages to put decals on, don't want them sliding all over the shop, so we're up to €65.65. Once that's done it has to get a coat of sealer to blend the decals, and lock the finish. That takes a few hours to harden properly, and then the windows and etches can go on the top, so probably up around the €70.00 mark now, and you have a finished ballast wagon. Here's the hidden bit - If I started one on a Monday morning 9 a.m., I would be lucky to have one haven gone all the stages of drying for paints by friday afternoon. I'd also have to do about 8 of them to make my time worthwhile.
Now imagine I had the cheek to add a modest bit of profit on top, say a tenner for taking the risk and so on, would you buy a poxy ballast plough for €80 ????
I certainly wouldn't. Thoughts on a postcard...
Richie.
