irishthump
I started off with Tony Mirolo’s tutorial to get the streaking effect down the sides of the bubble but I went for a heavier application. The layer of crusty cement on the top was made of plaster of Paris mixed with a small amount of black and brown weathering powder to give it a grey colour. I brush this on the top of the bubble and streak it down the sides. Then mist water over the plaster with a spray bottle to make it set hard. You can repeat this several times depending on what effect you’re looking for.
Very nice! They look like they’ve been coupled together for ages!
- 294 replies
- 13
WOW! I'd no idea it had two levels.
Short video of them on the layout with 080. IMG_7074.MOV
Finished weathering my small rake of tanker wagons. This was another project that took a couple of years! All 6 were weathered in one batch but I tried for a distinctive look for each one.
- 294 replies
- 12
Fantastic! How big is this layout? SO many different scenes.......
Belated Happy Birthday, Patrick!
Back to railways! Finally finished my scratch built brake van. After applying Des’s excellent decals and a bit of weathering she’s ready for the layout. Seen here with a lone tanker wagon and loco 182.
- 294 replies
- 13
been there, done that!
Nice job. I’ll be honest if the speaker failed in one of my 121’s I’d have no problem replacing it and I wouldn’t care if it was visible behind the grill! Would you be able to show us a picture of that installation with the body off the loco?
Repairing a Murphy Models B141 circuit board fault
irishthump replied to Mayner's topic in Tips & Tricks
Very informative, thanks for sharing. I bought a 141 from Ebay a few years back. I got it really cheap as it was sold as a non-runner. Turns out it had a similar-but-different issue with the PCB, the track feeds at one end of the board had failed. I had to rewire to the opposite end of the board and all was fine after that. -
Isn't it true you can reprogramme keys to activate different functions? That momentum button is better of left alone!
Just be careful when ordering, there's another decoder - 58449. This appears to have exactly the same specs but may not operate the lights correctly on the 121. This is to do with how the circuit board in the 121 is designed.
No problem. Let me know what you think of the horn sound.
From what I remember the Momentum button allows you to enter a value of 0-9. Entering a value of 0 turns off acceleration and deceleration. When a value of 1-9 is entered the Powercab takes that number, multiplies it by a factor of 8 and writes that value to CV3, then writes half that value to CV4. So any values you already have programmed to a loco will be overwritten, Problems can arise because some sound decoders such as Zimo have specific values in CV3 and CV4 that are neceasary for realistic operation of the sound file. Loksound decoders have a different problem; acceleration and deceleration values differ from NMRA recommended practices so that their values need to be higher to match other brands of decoders.
Here it is, V36 Top of the page... http://projects.esu.eu/projectoverviews/search?cat=7&q=V36
I found one that I thought is pretty close. I’ll have a look later and find which V5 I took it from! The V5 horn sounds seem to sound much better, to my ears anyway....
@murphaphare you using the horn sounds from the old MM V4 files or have you found something suitable in the newer V5 ones?
The MM decoders are V5 DCC which I thought was a little odd for a decoder aimed at the European market. Curiously though, I recently picked up an MM decoder for an 071 loco from Mark’s and it turned out it to also be a V5 DCC. Doesn’t really make too much of a difference to most modellers here but handy to know as they have different momentum values.
Nice! Athearn Genesis? Atlas?
Have to say that contrasts sharply with my recollection. I vividly remember as a child standing on the platform at Pearse Station, reaching out to touch the sides of the stopped locos and my hand coming away thick with grime. Faded paint was also a common thing. The C classes on the push-pull services from Killiney to Pearse were also never clean and neither were the coaches!
