Level one is storage I have about 10 full length sidings so I can store full trains and call them up when I want them. Level one is 18" of floor level the trains then come up the lower helix (helix 1) and enter level 2 at the signal box you all see in the photos and videos of my layout.
Level 2 is best described as a square figure of 8 it is 16' x12' and is designed as double main line running with a passing loop for the slower trains to wait in. It is all country side as that is what I like to see model trains running through the country side it's the level you guys are most familiar with as this is where all my photos and videos are done. Level 2 is just over 3 foot of the ground and was designed just as a main line that you can leave a couple of trains running on and forget about them while you shunt etc on level 3.
Level 3 is the upper level at eye level its just over 5' from the floor and is built to suit me (height wise) as I am over 6' tall so its at just lower than eye level for me. Level 3 is accessed from level 2 by the upper helix (helix 2) both helix on the layout are single road and sit one on top of the other they will not be seen when all is finished.
Level 3 will be a single line running around the room (like a lot of Irish lines) it will be 16x12 and will have my little Irish Station (Ballykay) a working turntable, engine shed and a couple of sidings. It will also have a full build of the village of Avoca in county Wicklow which stared in Ballykissangle and is currently under construction with Glenderg. Level 3 is currently under construction the helix has been installed and 80% of the base boards are in. The station will be on a 16' section but what I have to decide is my platform length. I can run full length trains for example a full length of Mk3's is 8 but 7 looks better running around my layout. So do I make the platform to take 7 Mk3's or do I make the platform shorter and have an over hang. Any help here guys do all lager Country stations in Ireland take a full length train do I need to make the platform the same lenthe as my longest passenger train. As the build progresses I will post up more pictures/videos for you guys stay tuned:-bd
