jhb171achill
  1. The very steepest gradients in Ireland were the quarter mile just short of Hillsborough station in the Knockmore Junction side and the cutting just south of Downpatrick station, through which it will one day become possible to travel again by train. These were 1 in sixty-ish - I'd have to look it up. One in sixty - for example - would be one inch rise per sixty inches (or five feet / about 1.5m) length. A model railway will comfortably cope with gradients three times this steep.
  2. You're quite right, minister - I had forgotten that. 00n3 or TT is indeed what's needed. There was a lot of dual gauge track in Larne Harbour station at one time. After the last remaining bit of the Ballymena & Larne closed in 1950, fragments remained about the yard almost until its removal in the early 1960s. At Strabane, one might have expected the same, but it was nit so, other than a wagon turntable. The Derry docks had a lot, and the RPSI's 0.6.0T "R H Smyth" had a narrow gauge chopper coupling set off centre on each buffer beam so that it could haul CDR or LLSR stick as well as NCC or GNR stock around the quays.
  3. Stevie, what is known is that the tender it arrived at Whitehead with is not what it ran with. Rumours abounded for years at Whitehead that it came from a 400, but this is nonsense! In GSR, let alone CIE days, tenders were swopped. This was common in other countries too. I remember seeing steam locos in Indonesia in the 80s at the end of steam. The particular livery they had involved having the loco number on the loco itself and the tender. So you got B5002 paired with the tender from B5008, B5004 with B5010 and so on. CIE and GSR were no exception to this. The GNR numbered tenders in a separate series because they knew they'd be swopped. However, swops were generally within a class (but not always). CIE inherited a wide range of non standard locos, so swopping between classes was quite common as well as between locos within a class. It's probably impossible to say at this stage where 186s tender originated, but we can be sure that it would have travelled around behind many locos of several classes! Photographic evidence shows that this type of tender was often found with the J15 class. It may well have designed with them in mind, or not!
  4. 009 is the same 9mm gauge but with narrow gauge sleeper spacing might look a lot better?
  5. The grey used by the GSR was as close to LMS grey as anything, though prior to that the GSWR used an extremely dark grey, almost black. CIE continued this shade to the late 50s / early 60s, then used a much lighter shade as shown on that open wagon above and on numerous "H" vans in the 60s and still like that in the 70s. The brown used from the late 60s onwards always had a slight reddish tint, though this has been much more marked since the 1990s, as witnessed on Taras, timber wagons and container flats nowadays. In the 70s it was close enough to British Railways wagon brown. Again, bear in mind that unlike BR wagons, Irish ones never had black chassis, always body colour; grey for grey wagons, brown for brown ones. Exceptions to that rule were Asahi wagons, ammonia tanks, flat sided cement wagons of both types (blue chassis like bodies), bubbles (originally all over grey, then orange with black chassis, finally Irish Cement cream with - eh - cement coloured chassis!, and modern products of Limerick - brown bodies / chassis with black bogies, springs in all sorts of multi colours. But for good old 4 wheel stock, see above.
  6. I should add, the buffer beam numerals really look well too.
  7. Absolute gem, stunning! I showed the pics to Senior, who knew it well. He says it was grey initially and would have spent most of its life like this. I think CIE did indeed paint it green latterly, but it doesn't appear to have been doing much by then. If I may be permitted one slight detail comment, the number plates should be either all grey, or grey with yellow cream raised edges and numerals. But overall, what a stunner! How to follow that one.... Maybe an 820, the 4.6.2T based on the 800s, which never saw the light of day!
  8. Ah! Indeed; memory suitably jogged! The price and quality would indeed have been why I never bought any....
  9. At the risk of misguiding this thread away from the original point, I once saw the Gardai having to shovel up the remains of a very large dog which had come to grief at the Mad Cow roundabout..... stomach churning.
  10. That is indeed a masterpiece of one with exceptional eyesight - and skills. Dare I live in hope of seeing a few blue 4.4.0s about the place! On a serious note, this idea of 3D prints seems to be generating a lot of valuable new opportunities. Presumably it would be a relatively simple matter to churn out DD stock, various modern railcars and 141s. For a 141, though, what chassis would be short enough?
  11. This may be a little obscure, and Mayner reminded me of it and might be one of the few who might know; but there was a firm about 40 years ago in England called "K's kits" or "K's" something, who made white metal kits of a wide range in British loco prototypes. By today's standards they looked perhaps a little crude, but they had a big range of them, often of prototypes ignored by the lines of Hornby. I never bought any, but I had several of their catalogues. Thus, while I cannot be certain, I believe they relied on the buyer to either build or buy a suitable chassis - certainly they weren't suitable for all modelling skill levels. Perhaps if any of those can be tracked down, there might be something in there that would suit as an Irish prototype. It was Mayner's post above which reminded me that they did do several LNWR prototypes.
  12. Or a squashed badger? .....
  13. That would be the MGWR's D16 class, of which there were six, all rebuilt about 1901 from former 2.4.0s which were built in 1882. So synonymous with the Achill line, they were often referred to as "Achill bogies". They occasionally worked into Ballina after the Achill line shut, but were quickly withdrawn as they were too weak to do much else in other places. They didn't actually get to Clifden, as far as is known. That line was the preserve of G2 2.4.0 and J18 0.6.0 types. With the wild western turf, sky, river and mountain scenery, an Achill or Clifden based layout would be a winner!
  14. No probs, Rialto - brake vans are indeed a much neglected subject generally. Good to see them being given their place!
  15. Excellent, David! Can't wait to see the outcome!
  16. There were several GSWR 4.4.0 classes with outside framed bogies. Even if you used the chassis of this and built most of the rest from scratch, you could use it as a basis for a very convincing GSWR lookalike! But yes, a D17......
  17. I remember doing something like that with a Hornby roof many years ago. I got rid of the roughness by applying several coats of paint and waiting until it was really dry and rubbing it down a bit before painting it again. Time consuming and adequate for the times, but I am sure some of our experts here would have far superior ways of doing it.
  18. Indeed, mine's on the wall. And it supports a very good cause!
  19. Platform Six is where you get the 5ft 3 train to Hogwarts.
  20. STUNNING! Excellent stuff. Between the 80 class set and this, the often-neglected area of old UTA & NIR railcars is being well and truly addressed.
  21. The Irish Shell loco was (and is) plain unlined mid green with certain bits picked out in red. If memory serves me correctly, Shell petrol tankers had a livery of red and green in the late 50s / early 60s. It's currently out of action, but served faithfully as the Whitehead shutter for years. I believe its build date was 1951.
  22. David, my last post there had a word recognition typo. Upholstery colour should read greyish light blue.
  23. Re banana vans, very very few Irish wagons were ever in private owner liveries, unlike UK; and when repainting, remember to do the chassis too.brown wagons had, and have, brown chassis and (until very recently in the case of container flats only) brown bogies, grey wagons had grey chassis. The ubiquitous application of black as a chassis colour for wagons is a GB / BR thing, not UTA, NIR, or CIE.
  24. Correct, killucan, though I don't have the numbers, and it was very short lived in particular for one of them.
  25. I enquired of those who might know. The inside walls were probably light or mid brown, with ceilings a light colour, almost certainly cream. This would not be unlike many laminates or Park Royals. Cab interior probably brown too. My own best guess, for several reasons, is that upholstery was either green or greyish black ue - very unlikely to be anything else.
