Everything posted by The Derry Road
Hi All, Just a quick update showing progress to date, Sheds build and exterior paint work almost completed outside, inside starting tomorrow, Backscene frame work added and ply panels painted, to be fitted shortly.
- 33 replies
- 10
Hi, MM, The original buildings are from Pikestuff HO kits, with various added parts from Slaters plastic, Wills plasticard and plastruct To bring them up to OO Gauge TDR
Couple of pictures of the progress thus far, showing Lisneal Road TMD structures, 3 road engine shed, paint shop and office/stores in their plotted positions. Fuel point also in position although in basic form. All buildings and structures are yet to be painted and detailed interiors aswell as outside etc. TDR
Hi All Just a quick note and some pictures of a new layout I'm working on. Its 8ft x 18ins, and in two pieces, I have been struggling with a track plan for well over a year and the initial plan was a bit ambitious, so after working out a final plan here it is, featuring a 3 road shed , paint shop and fuelling point. Power is by DCC and I’ve soldered all track joints except those fitted with insulation fish plates.Although its at an early stage I hope to have this ready for exhibitions next year.
Rachelstown and St Stephens Green
The Derry Road replied to The Derry Road's topic in Irish Model Layouts
Thank you, the hunslett is silver fox with bachmann class 20 chassis with sound. TDR Thank you TDR -
- 406 replies
- 10
Some pictures of the progress on the wagons thus far, with all detail parts fitted, wagons ran well with no derailments. Wagon numbers to fit and varnish to seal transfers then fit door chains. So far very pleased with the build.
Point and Signal console finally assembled and sprayed with under coat, panels placed to test the look, will give it a finishing coat of metallic grey, tomorrow and hopefully fit in place at weekend. The big task of connecting then begins TDR- 406 replies
- 12
hope to see you all there on Saturday, also looking forward to the reveal Fran. TDR
Some pictures and several short videos of some of the exhibits at the URM show today. It was great to meet up and chat with many fellow modellers there present TDR 20190824_124727.mp4 20190824_124727.mp4 20190824_125424.mp4 20190824_125554.mp4 20190824_124903.mp4 20190824_125152.mp4 20190824_131154.mp4
Ladders with Safety Rings / Pump or Hose Points
The Derry Road replied to Rob's topic in General Chat
- 1 reply
- 1
Thanks Popeye I did not notice it, hover will sort it tomorrow. TDR -
Hi all, Some pictures and a short video of the layout with Loco 183 pulling a rake of cement bubbles, This is the last train to run on the layout, as some changes are coming into play, track work is changing slightly to permit better running possibilities and the retaining wall and tunnel mouths are going. To be replaced with a new arched wall being three inches closer to the track to allow a better and deeper backscene. TDR Bubbles.mp4 -
very tasty looking model Boys
Yes, bachmann class 20 is in both my hunslets
Hunslet primed and head lights temp fitted, temp wired selecting the correct resistor, positioned and tested for light bleed, working perfect happy days
Further progress on the hunslett today, new brass hand and step rails fitted to door sides and cab fronts. I removed the remaining side grills and fitted brass etches, they provide a better finish. Marker lights also bored out, some test running beside my other hunslett, a few pictures and a short video Project_hunslett_2.mp4
A few pictures showing the progress thus far on the hunslet, moulded side and roof grills bored out, removed and new brass one in their place. I have also removed the hand rails hopefully fitting replacement brass ones tomorrow, on both cab fronts and doors. Head lights have been bored out and tapered from inside to outside to accept LED lights. I’m still wondering about fitting marker lights, I’ll sleep on it tonight. TDR
Thanks, it keeps them in a tidy order for access to when required, TDR
Just started this morning the second NIR Hunslet (DL) number 102 FALCON, to be in NIR light blue with Bachmann class 20 DCC sound chassis (same as maroon version posted two weeks ago). The main difference is this body will have, molded hand rails removed along with roof and side grills, and replaced with brass ones. also considering head and marker lights TDR
Noel totally agree with you, however the chip shown by Heirflick is not a sound chip it is a plain dcc chip supplied by hattons, if memory serves me, they are £16.50 each. TDR
Seamus Ive use these in two 071s and a 201 and 4, 141/181s without any issues, on a recent visit to Hattons I was informed that these chips are supplied to them by DCC supplies. Most of my BR stock has these also. Again never had any issues Regards TDR
Loco almost finished, just buffers to paint and a piece of red tape to tuck in, gave it a run this morning and quite pleased with the results. some pictures and a short video from this mornings outing, Hunslett loco 103 (MERLIN) pulling a rake of 5 coaches painted into NIR maroon and blue, The DVT is still under construction. This is my favourite NIR livery, it brings back fond memories from child hood. 103_hunslet__running.mp4 -
The body is from Silver fox kits, chassis is bachmann class 20 with sound fitted, grills are from A1 Models. TDR
