Everything posted by Noel
Hi Robert. Thanks for info. Did you order FUD or WSF versions? Which model did you go for A-1, A-2, A-3 or A-5 (i.e. mounts for Cambrian or Bachmann Y25 bogies, with or without buffers, etc)? Thanks Noel PS: If you get a chance to post pics that would be great.
The main CVs affecting inertia, acceleration, declarations rates are CV 2,5,6,3 and 4, and BEMF setting, or possible a load of CVs of a speed curve has been specified by a single bit in CV29. Ideally to double head (consist) a pair of locos, they should be the same type of loco, or very similar, both be running free and run-in as well as each other. Then setting the CVs the same makes sense. However especially with steam models you may find you need to adjust the settings to more closely match the speeds of the two locos and their acceleration rates. Even with identical locos they will never run identically, with one pushing a little more that the other or pulling a little more, but once they are not a million miles away especially and average cruising speed its not a problem. Don't know if that answers what I think your question was or not, but sure there you go. PS: Tip measure the speed of the two locos individually at low, mid and high speeds to find out if there are significant differences between them.
This is really helpful info chaps, as I'm about to respray some Hornby Staniers and a C class in CIE green.
- 96 replies
Well deserved. Congrats and well done.
Panic? None whatsoever, our wedding anniversary isn't for many months yet! Those who have thus far safely avoided the c/marriage sidings may have to produce suitable merchandise to keep industry happy, comply with programming, and let their boy/girl friend know what they really think of them.
They could end up on the turn table
Two good presidents!!!
Valentines day is for unmarried courting couples (i.e. that excludes married couples). Wedding Anniversaries are for married people. Commerce and marketing hype tries to brainwash us poor male railway modellers into believing that it is both.
Some modellers use cutters like Silhouette CAMEO 3 for cutting thin plastic card and laminate for thicker components https://www.silhouetteamerica.com/shop/machines/cameo
Grand Hibernian - Respray opportunity for someone....
Noel replied to declan64's topic in Irish Models
Yes superb etches. BGH not my sort of thing either but these could tempt me. I'd have to modify the livery though with some fine gold or grey horizontal lining below the windows. IMHO In real life the BGH livery seems rather plain. Ps. Des any update on your BCK GSV etched sides (i.e. 3173).- 17 replies
- mk3 coaches
- grand hibernian
(and 2 more)
Tagged with:
Just my sequence, not necessarily the correct or ideal: Temporarily Lay the track dry using drawing pins (avoid points over board joints or cross members for later point motors) Test run trains to ensure smooth operation, no derailments, clearances between longer rolling stock items on parralell track at bends. (I.e. Avoid corners of passing coaches touch each other). Simulate prototypical operations (i.e. Shunting, run around, building formations, etc) Adjust track if required from steps 2 & 3 Accurately mark finalised track position on base board. Accurately mark holes for point motors Remove track Cut, lay and glue down track bed or yard sheet (i.e. 3mm cork or 3mm dense cell black foam), copydex a better glue than PVA because it doesn't go hard therefore does not transmit rail noise through track bed to base board Drill point motor holes under where point tie bars will be. Option - do messy scenic work now before track relaid, such as forming shapes using plaster/foam, roads, etc. Relay and pin track to track bed Wire primary track power Before ballasting perform test run of all track Ballast track with suitable ballast material using wet PVA method Weather track and ballast (air brush by far the quickest and easiest way to do thus) Clean rail tops Test run variety of stock again Finish track wiring Point motor wiring. Do non messy scenic work, scatters, static grass, buildings, trees, walls, foliage, fences, etc
Saw this great idea over on Railway Modellers Ireland FaceBook site "Don't forget tomorrow Saturday 10 Feb is our hands on Airbrush Demo and try day in the Greenogue Shop. We will have special prices on the day, complimentary tea and coffee 10am to 6pm" I'm hoping to pop over about 11:00, might bump into a few forumites.
Uncannily realistic. The work of one of the masters. Enjoy
Very true PS: I still have the screen grab of a certain PM from 2015 advising me about RTR A class options
Great idea Fran, et al. Will be attending. To add to @iarnrod excellent speculations, my own dream list would be: Single beat wagon (I know, I know I've just made a rake of 3D ones but IRM spec would be hyper-wow) Double beat wagon H-Van CAF Mk4 DVT (really out of my era but its gorgeous and would look great behind an MM 222 or 229) Side Curtain cement wagon Bogie Fertiliser wagon B101 Sulzer B113 Sulzer (Dalek) 2 axle Guinness wagon with keg loads E class shunter The seat may need reupholstering after the mannequin got a fright
Top class. Very elegant buildings both.
Thanks George. Yes hope to finish that up tomorrow. Thanks for your advice BTW.
Hi Gerry Not for the C class but yes for the Sulzer. There was careful consideration and research about using these two MM chassis as donors, and the decision was not taken lightly or without considering alternates. In case anybody thinks I'm being wasteful, I waited patiently over the past two years to acquire both of these donors at very low cost, both costing less than alternate Bachmann BR donor chassis on eBay. I ruled out using Hornby railroad style chassis as often recommended with SF kits because they do not run anywhere near as precisely as Bachmann/MM centre drive chassis, and also ruled out spud drives like Tenshodo with 15:1 gear ratio because of their running quality. Hollywood Iron foundry was another option but are more expensive than these donors, they don't even have PCBs, and not DCC ready. C class: Ironically the MM 141 is the ideal chassis for a C class in terms of length, bogie wheel spacing, lights, speaker space, easy of replacing bogie sides, NEM pocket heights to clear buffer beams, etc, and requires minimal work to fit the SF C class resin body, just cut a few mm of the both ends of the chassis using a mini drill disc cutter. You end up with a top class centre drive double flywheel runner AWD, AWP, lights, etc. Sulzer: The 071 bogie axle spacings are a perfect match for the SF B101 Sulzer, but the chassis requires to be shortened by way of two cut and joins each side of the centre drive motor, including shortening both carden shafts. The reason for two cuts is so the shafts are still long enough to allow both bogies pivot freely when the shortened chassis is reassembled. The MM chassis has all the lighting on the PCB as well as the snap fit bogie covers that are easy to change sides while retain the NEM pockets. Other considerations were that I am already familiar with these Bachman/MM style chassis, they are 21pin DCC and sound ready, both with speaker cradles, both with lighting PCBs, and most importantly of all both run as smoothly and reliable as a Swiss clock.
Transplant donors being prepared for the ritual sacrifice. This risks me being expelled from 'rotting in the bogie of eternal stench' such is the imminent destruction of such sacred cows, however cheaply bought into slavery from eBay.
Range anxiety don't think the BEV would make it that far on a single charge.
Doh - that's nowhere near any of the canals! I told you guys before you can't trust Chinese rockets.
Dave, the only way you'll ever get me inside a rocket is to head over to IRM towers quickly to collect a brace of Black'n'tan livery A classes with working windscreen wipers, and perhaps even one of those modern era Super train livery ones.
Hi Paul. Thanks. It was @Georgeconna who told me about it. I have some of his fab weathered MIR bubbles on which he had used it to create texture on the top sides. I decided to make some sort of attempt to replicate his superb bubble weathering which seems one of the 'go to' standards. There are other ways of achieving this but I decided to try it George's way. There are multiple versions of Mr Surfacer, it is basically a sand-able model filler in different thicknesses 500 being the thickest and 1200 being the thinest almost enough for air-brush use. Plastic modellers use it to fill imperfections not unlike modelling the putty I used on the recent GSV plastic cut'n'shut. I can see a raft of other uses for it to great areas of debris on station platforms, base of buildings, road side texture, etc. It eats into plastic so use sparingly or in multiple coats on delicate or thin plastic surfaces. Noel https://www.ebay.co.uk/itm/SF-285-Mr-Hobby-Mr-Surfacer-500-40ml/263197021597?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 PS: I used AddressPal to get it posted to Ireland
Fair comment Eoin. 'To infinity and beyond' is a while down the road yet.
