Noel
Everything posted by Noel
  1. Great progress. This really going to look the part.
  2. The thing about Jouef is they manufactured their european products in Ireland alright, but the continental rolling stock they merely repainted in a sort of CIE livery never looked remotely like anything that ran on Irish rails. At least the Lima Murphy inspired class 33s and BR Mk1s looked looked half right considering it was the 1970s toy market.
  3. Media reports UC bay fire extinguished after landing http://newyork.cbslocal.com/2015/09/28/aerlingus-flight-returned/ https://mobile.twitter.com/aquamanatee/status/648656000027860992 http://www.independent.ie/irish-news/news/aer-lingus-pilot-tells-jfk-air-control-we-have-lost-hydraulic-fluid-and-have-to-return-to-jfk-31566592.html This had the potential to be a very serious incident. Well done flight crew and ground services.
  4. Opps "This video is private"
  5. Nice. Enjoy your videos
  6. In any scale that that would be excellent, but in 'N' it is even more impressive. Congrats on completion. Hope you enjoy many years operating it.
  7. Lenz shunting tip. This past year I've been using Lenz silver+ decoders on our MM 141/181 and 071 locos and very pleased with their ultra smooth and quiet motor control. However I only recently discovered Fn 4 effectively toggles a shunting mode which temporarily disables the normal accelaration and braking delays (ie cv3/4). This is really useful for direct instant throttle control when shunting. Function 4 turns this off and on. It has meant I have been able to program quite long accelaration and braking delays but not loose precision when shunting.
  8. No but found a few links http://newirishlines.org/2009/09/28/converting-the-murphy-bachmann-141-class-diesel-to-21mm-gauge/
  9. Guys lets chill and give the mods a breather - its time consuming, difficult at times, a thankless role and difficult to get the balance right and please everybody. I'm sure they as much as anybody like banter and good humoured 'craic' on this form, so as long is its harmless, never gets personal and doesn't cross certain lines or break the obvious rules. I've seen week moderation destroy other vibrant forums leading to a minority gradually running amok and ruining it for everybody, and other forums where the moderation was over zealous and killed off the traffic. Personally I find the moderation policy here a good balance and the tone and good humour on here a pleasant relief.
  10. Some really nice photos. Nice to see more locomotives than boring ICRs.
  11. Fools and their gold!
  12. Sadly nowadays little boys (and even some big boys) prefer to spend more time passively watching something entertain them on LCD screens rather than toys of yesteryear such as model trains, scalextric, meccano, climbing trees or kicking footballs, etc. Hence the demise of hobby stores in general.
  13. They seem to sell toys and all manner of other stuff too https://www.facebook.com/mcculloughsbangor
  14. They look great. Looking forward to the rest, and WOW that's an incredible layout.
  15. Ahem - has this thread entered la-la land?
  16. PS: I liked JM's plan with the option to remove the reverse scissors half way down the platform. That plan has a lot of operating potential.
  17. Hi Westport You are quite right the design of the baseboard and track plan need to be taken into account. How much depends on whether the baseboard will be fixed, moveable (i.e. house move), or fully portable. If the latter, joints in the baseboard need to avoid points and if possible the joint in the baseboard at track joins should be as perpendicular to the track as possible to make track alignment easier when reassembling layout boards. That's a whole subject in itself. As you said consideration should be given to positioning of points to avoid joints and structural cross members which make point motor installation and ongoing servicing easier. Routing and trunking for under board cabling also worth thinking about. In some cases it may not be possible to avoid placing a point over a cross beam, but there are ways of siting a point motor a few inches away from a point (i.e. rods, rod and tube, like model aircraft controls, etc). There are many different and equally valid methods of constructing baseboards, from one level table style to 3D layered open systems using lots of foam or timber lattice structures. All I can suggest is the old proverb "keep it simple" Noel
  18. Hi Westport. Good luck and enjoy the planing for your layout. I only comment because you have requested same, and hope its of use. One of the mistakes some of us myself included make is to have too much visible track density that may not actually increase the operating potential. Getting the ratio of visible storage sidings to running track is a personal preference and a balancing act. Not sure what track work you are planning to use, but if you use flexitrack and streamline points rather than set track you will manage to better utilise the available 11ft x 5ft, which is a good size, and also avoid the layout looking too geometric. Also use of curved points at the start of curves can save a lot of space as well as add to visual appeal. Again this is just a personal preference, but consider avoid having all non curved track dead straight. Using track work such as peco streamline code 100 or code 75 also allows for closer track separation and can avoid the set track toy train set look as well as save space. Best advise I can give is to plan, plan, plan, before cutting, nailing or gluing anything down. I used to make up "dry loose assembled" sections of track and point work to test how they might fit and look before committing to fixing anything down. You can use paper templates, but there is nothing like actual track to give you visual feedback. If you loosely tack down your finished track work before committing to ballasting, you can test operate it and make any changes before permanently fixing it and ballasting. You just never really know how operating options really work until you get to operate and shunt trains and rolling stock. Hope this makes sense and is of constructive help. Noel
  19. Glad you enjoyed it. Yes I will get an LMS or GWR express running when I get a chance to DCC convert a few of my old tender locos. I've only DCC'd a few tank locos so far. As to the sound, there is a 141 sound coming from one loco on the upper loop, and I added a few sound effects to the clip while playing with iMovie which is new to me. Used to use Pinnacle Studio for video editing before moving to mac 2 years ago.
  20. I love watching videos on your fabulous layout. The lush green scenery and atmospheric buildings are fabulous. That station building complex near the end is just superb.
  21. Well its a free world so if somebody in the past up the cash to buy this stock in the first place, free enterprise gives them the perfect right to do with them as they please! Even like James May, who paid for the right to throw away the boxes of stock he bought at a specialist model railway auction on the recently posted BBC clip. (obviously deliberately done for dramatic programming reasons). Being the 'boffin' he is who likes vintage everything, I bet you in real life he keeps all his toy's boxes.
  22. €75 for three wagons, thats €25 per wagon, which is just a BR wagon repainted - I think not
  23. That looks superb. Love the roof light shadows cast on the rear wall.
  24. Hmmm crazy price for a mere Lima with a poor chassis, not to mention a less than popular loco livery
  25. Classic Dave
