Everything posted by Noel
. . . Oh and a ballast wagon in RPSI livery
Well done sold your entire inventory. wait 30 seconds for requests for re-runs a great success for all concerned and delighted MM finished on such a successful and high note.
FREMO modular layout - polish rail PKP
Noel replied to Jack_Dunboyne's topic in Continental European Modelling
Like the look of that, especially the baseboard construction. Best wishes for many relaxing and enjoyable hours in there. -
Overall these are truly amazing models and they look incredible hauling trains. B125 arrived recently and its even better looking than the photo graphs. Will lightly weather it in the weeks ahead.
Looks ok to me. The lights on B135 and B125 seem spot on. Not sure if any issues could be the decoder set up, but the lights are working perfectly for me with the Wheeltappers LokSound 5 decoders.
In this example two locos with their own addresses become a consist with a consist address of 127 no longer responding to their own individual addresses until the consist is deleted. This takes care of CV19 automatically in each decoder within the consist.
Yes advanced consist on some DCC systems is very easy to setup without needing to know anything about consisting CVs. I use NCE system which it has a user friendly consist menu that takes care off all the necessary CVs and buries the complexities when using 'advanced consists'. It is fun driving a loco up to another coupling up forming a consist with the pair, driving a train, then deleting the consist and driving one of the locos away independently again without having to programme any CVs or without having to move the locos to the test track. The 1st 2mins of this clip illustrate this. Both MM locos have LokSound V5 projects (by WheelTappers), and also match the 121 WheelTappers project so MM121 + MM141 consist really well together and are speed matched pretty much out of the box.
That's exceptional. Love this layout. Pure atmosphere.
Have one consist with sound in both locos because I regularly split them while running (ie interesting shunt options), another with sound only in the lead loco and a speed matched LokPilot in the following loco. WheelTappers sell them as matched pairs. Kevin, FYI, I contacted MM directly and was advised by them to send the loco back to them for warranty repair or replacement. Excellent service and only took a few days to get a replacement loco sent back to me. I even got a note to say it had been test run and the sound checked. If you send the loco back to the middle man retailer you may have to wait while they send the model back to MM, from MM back to retailer, retailer back to you. Unless you can get the retailer to just send you a replacement immediately and they can deal with MM retrospectively saving customer a lot of time. Under consumer law your contract is with the retailer, but this manufacturer seems very good at honouring warranty issues directly. Just my tuppence. Most of the issues with disconnected or loose grab rails and hand rails are easily fixed by the user without need to use glue. They are friction fitted. Easy to remove for weathering and then put back.
Suggest contact MM by email and arrange to post loco back to them. They will just send you a replacement by post under warranty. Excellent service.
MM have excellent warranty support. They quickly replaced one of my 121s (faulty speaker) a few weeks ago. Obviously I had to pack it up and post it back to them, but being in Ireland I got the replacement back within 3 days. Suggest emailing MM direct for advise. No
They should go back on fairly easily using a tweezers without the need for glue, and the base of the stanchions nicely friction fit into holes on the side of the walkway. My eyesight is not great so I wear an optivisor to see what goes where. I had to remove the grab rails from my 121s to weather them including the cab door rails, but they went back on again ok. just be gentle. On one of mine the cab door grab rail fell off in transit inside the box, I had to use a micro drill to marginally enlarge the hole above the doors and used the tiniest smear of PVA to secure once pushed back into place. I’ve used a new technique if I ever have to revert to glue when fitting wire parts to models. I put the glue on a piece of plastic bag, hold the part with a tweezers and dip it in the glue to just get the tiniest amount of glue on the end of the wire so when pushed into a body side hole there is no unsightly or messy blob of glue visible. Not neccessary for friction fit parts like walkway rails. I never apply glue using its nozzle directly to a model, a recipient for a mess, instead always indirect transfer using a piece of plastic bag to dip in, or transfer using a cocktail stick.
Good shot. So some of them still had tablet catchers at that late stage even in CIE ST livery.
You can adjust brightness using CVs. MM should have an ESU tech sheet on this like they did for the 071 and 201 decoder projects
Yes well battery prices continue to fall exponentially rapidly approaching $100/kWh, and battery density tippled in the past 10 years now over 300Wh/kg and ever improving but unlikely to every be as small as a suitcase for a car. 15 years ago Hydrogen seemed the future, then Tesla came along and disrupted the entire auto industry and changed the world. The legacy manufacturers are still playing catchup. Dieselgate ironically may have been the best thing that ever happened for climate action as VW\VAG now lead the legacy's in a strategic switch to BEVs from fossil cars, about face GM, Ford, Daimler who are now rushing to catch up. Interesting times ahead, especially the next 5 years.
Yes, it seems so. Totally nit picking, but one minor enhancement would be easy access to add a driver to the inside of the cab, or provide the loco with a driver inside the cab (eg: magnetic or pop off cab roof unless loco comes with a driver inside).
https://www.rte.ie/archives/2019/0326/1038732-malahide-model-railway/?fbclid=IwAR3wKmQUQfU8-ab9FxfXbMh7P910u_7dfOch4BQTde6PaNq89VE2xcXXpRY
- 4
Despite Tesla's HGV, the future of HGVs seems more likely to be HFCEV (Hydrogen Fuel Cell) HGVs rather than BEV (battery). Its just physics, a battery big enough to haul a HGV load say 480km is likely to be heavier than the actual load, rather inefficient, energy wasted transporting energy store. HFCEVs missed the boat as regards cars (ie personal mobility transport) and there is zero fuelling infrastructure, but HFCEV HGVs could refuel in their own depot yards rather than public filling stations. In Germany they have been running trials with pantographs like the Luas for HGVs on autobahns. Rail really lends itself to electrification, we won't see big diesels lasting for decades, their CO2 foot print is off the richter scale!
Photographic Website Updates
Some great pics. I have fond memories passing under that bridge on Shannon hire cruisers of summers past. A popular spot with anglers as the hot water running out of the power station just to the east of the bridge seemed to attract some of the larger coarse fish. Yes sad to hear about the closures of these two once important power stations, but there seems some cause for optimism about new jobs perhaps on the boglands as they are converted into wind farms, forestry and carbon traps. End of an era but as a nation we have little choice due to the need for urgent climate action. Here's hoping for new employment in the midlands from green energy and forestry, etc. I see from the national grid dashboard that most of ROI's grid is now coming from wind and natural gas with coal generation almost eliminated (<5%). Changing times. -
Ah one of the incredible Gareth Brennan scratch built specials. One of only 21 ever built. Probably on a Bachman class 20 chassis so a good runner too I expect. Rarer than a faberge egg. Love that livery. MVL?
Hattons, Rails of Sheffield and DC Kits should have them in stock by now.
Wonderful. Pure class
