Everything posted by Broithe
Talk of the Killamuck Bog Trail reminded me that I found this video the other day, recorded under the skew bridge on the Rathdowney & Templemore road, by the old station house.
https://consultations.tipperarycoco.ie/consultation/littleton-labyrinth-proposed-greenway
Is it sound-fitted..?
I often wonder if anybody ever found a old box of spares at the back of the stores in the 1960s, with "Westland Whirlwind" written on them, and then wondered why they wouldn't fit the big yellow helicopter he was working on..?
It may not matter so much if concrete sleepers are buried.
https://www.facebook.com/watch?v=8275431195813290
Looking forward to it. In general, model ballast tends to be overscale, I find - so N usually looks better on a 00 layout.
That's the loop platform, about ten years ago now.
A stand magnifier on the bench, and a head-mounted magnifier for mobile, 'on site' work. I rarely use a head-mounted one, but there are some times when it is the better option. On the solar fire-risk issue, the type with the cover, as above, will preclude that issue, and keep the lens clean.
There is something to be said for both types of arrangements, in different circumstances. There is also the odd occasion where a single magnifier over one eye will still leave you with 'real' vision from the other. You can get nice small ones that will clip onto the arms of spectacle frames and easily swing into and out of use. If using the magnifier on a stand-type of arrangement, then do be sure not to leave it in a position where sunlight can be focused onto something, with the associated fire hazard. I also have the advantage of being very short-sighted, so, in circumstances where eye-protection is not an issue, then I can just take my glasses off and focus down a couple of inches.
Track and lineside maintenance for the outdoor modeller.
Broithe posted a topic in Letting off Steam
Probably best to make sure the cat is indoors and insist on full PPE for any operational staff on site - that hacksaw blade went past at some speed. -
It was OK, I was upwind. It was probably less difficult than the time he was walking downstairs behind me and another chap who was describing an explosion to me and illustrated it by flinging his arm backwards and accidentally punching Barry in a delicate region, provoking him to fold into a foetal position and only just be caught by us as he hurtled past, no longer in control of his own descent of the stairway.
Seeing @Dempsey's terminal boards reminded me of a highlight event of my time in the factory. Our control cabinets had large columns of terminal boards and relays, as there was not enough commonality for the wiring to be done with a loom, but each wire was individually terminated and run to be bundled up. This also, coincidentally, gave a means to find out what was going on, if the control arrangements failed, as they often did. The relays were meant to have protective covers on, but it was common to leave them off until things were working reliably. One day, myself and another chap were walking past Barry, often mentioned in reports of events, whilst he was delving into a suspect cabinet with his beloved Fluke meter. Just as we reached him, he suddenly adopted a position very like a figure skater - on one leg, with the other pointing straight back and both arms outstretched and fluttering. He had clearly found a live bit, and not with the probe, as intended, but with his head. Test items were mounted on a large cast-iron bedplate, with T-slots in, for ease of clamping things down quickly. Thus, being on a very nicely earthed floor, this meant that dragging Barry off the source of the shock was really not a good idea at all and I took a step back to aim a kick at his chest, as he performed his (potentially real) dying swan act. This would separate him from it and give me the minimum time exposure. I was actually quite disappointed when he managed to extricate himself before I could kick him off it, but I was still treated to the memorable sight of the small hole in his forehead, as he turned to face us, dazed. The hole was where he had put his head onto the 415 volt connection of one of the relays. There was quite a significant wisp of smoke coming out of the hole, not a thing you'll see very often. He survived the event without any extra issues, but he wasn't right before it, to be fair.
Take it easy. Have a can. Then start annoying them. The Guards are even joining in, they have this now, seized as a "proceeds of crime".
You have to start somewhere.
A discussion elsewhere has reminded me of this. We still made and maintained air-blast switchgear in my time and that had its own issues, as the pressures could be quite high and failures could be fairly spectacular. One thing which became an issue was that the compressors that maintained the air supply did, occasionally, blow up dramatically, sending big lumps at speed around substations. There were obvious safety issues about this, although it usually happened with nobody there, but statistics would catch up in the end. It was decided to produce a 'cage' for the compressors, to catch the bits and contain the damage area safely. It was not easy, or economical, to blow up actual compressors, so estimates were made of the size and velocity of the bits. Me and my lad were tasked with testing and modifying the mesh enclosures, as necessary. We ended up, through a few stages, building a large air-powered gun. It fired brass slugs, about 2" diameter and 4" long, by means of a 'snap' valve that dumped 3,000psi from a reservoir onto the back of the shell, driving it out of a three foot barrel. To avoid the firing device being damaged by the ricocheting shells, as the ones that got through rattled round the sleeper-lined walls, we fired it into the blast cell, through a cracked open door - waiting for things to go quiet before we opened the door to see what had happened. We altered the cages until we got an arrangement that contained the shell most times and that was deemed 'OK'. It wasn't until later that we started to consider the legalities. The UK would let you have an air rifle up to 12 foot-pounds without a licence being required. Our gun was many, many times beyond that - basically a small cannon. It seemed best not to raise the issue...
I found this t-shirt available from Waterford Whispers. https://waterfordwhispers.shop/collections/t-shirts/products/dart-vader-premium-wwn-t-shirt
https://www.offalyindependent.ie/2023/06/02/exciting-velo-rail-project-revealed-for-lough-boora-park/ https://www.offalyexpress.ie/news/tullamore-tribune/1531581/bord-na-mona-going-ahead-with-pedal-powered-rail-cars-for-offaly-bog.html I reckon there won't be on-board catering, at least to start with.
I did notice some very pale tarmac last night and forgot to get a picture going past this morning, but Street View does it well enough. That is the actual tarmac surface, not a layer of debris, and not much darker than the concrete, https://www.google.com/maps/@52.8555049,-7.5848455,3a,56y,186.43h,50.68t/data=!3m7!1e1!3m5!1s8a5CdK72i8-DsGJ5bKnp9w!2e0!6shttps:%2F%2Fstreetviewpixels-pa.googleapis.com%2Fv1%2Fthumbnail%3Fpanoid%3D8a5CdK72i8-DsGJ5bKnp9w%26cb_client%3Dmaps_sv.share%26w%3D900%26h%3D600%26yaw%3D186.42561092700657%26pitch%3D39.31964564632779%26thumbfov%3D90!7i16384!8i8192?coh=205410&entry=ttu
The pothole situation has basically reversed. I spend time in Laois and Staffordshire, within a few hundred yards of the same latitude and a mere 220 miles apart. I hear people in Laois moan about the roads and try to explain the state of things to the east - and I realise that I sound like I'm making it up. My house there is on a secondary main road into a town of 70,000 people. Every time it rains, the road floods like this. It's been doing this, at an increasing rate, since 1980. It probably blocks the road about 25 to 30 times a year now. The flood in that picture was there for six days. The potholes are legendary, all over the road network. Driving on roads that you don't have experience of, in the dark or in wet weather, is fraught with danger - you can easily end up hitting a big one. The half-finished ring-road round the town (started in 1935) has had unnecessary 'temporary' traffic lights on it, that will stop you every time, since July 2017 - 24hours a day, permanently. Driving in the Republic gives one a great sense of relief, not foreboding...
Interestingly, (well, if you have little else going on at some point), it can be informative to spend some time looking at various random samples of tarmac as you go about your daily rituals. The variations in colour can be surprising, at times it can even be almost a light grey, and no two pieces, laid at different times, will ever be the same colour, or even remotely similar. The wear of the tyre runs and the scuffing of the surface at bends and junctions, particularly from three-axle trailers, can also be worthy of note.
It's just a matter of compromise and getting the wheel/track spacings to be compatible.
