GNRi1959
Everything posted by GNRi1959
  1. I appreciate all the comments. The main problem is a design flaw. One engine is only able to take two wagons max into sidings. Being end to end makes the project somewhat dead. I can move 'sideways' but little up and down travel. I'm in deep thought.
  2. I've put a lot of work into getting Omagh North off the ground and now three months later I'm a bit disillusioned by the limitations of a 2m x 500mm end-to-end layout. My engine simply moves from A to B and back again with no illusion of travel at all. I'm putting it on hold for a week of so as the doubts are causing me much concern. I don't know whether I should move to N-gauge or try something totally different in 4mm. I'd like to hear other modellers thoughts on my plight.
  3. I'm using RailMatch sleeper grime and it looks pretty good. To be honest, when ballast is added and a bit of detailing on the track side the track will be the least of my worries!
  4. I'm using Code 100 Peco on my Omagh North layout and yesterday I started painting the sides of the rails. This seems to take the harsh look off the rail sides to some degree. Thirty years ago when I read the arguments about modelling 5'3" it was so difficult and today I don't think it is any easier. I don't too many people are bothered about the odd millimetre here and there, are they?
  5. I'll make every effort to be there
  6. As much as I would, I have to pass. This month has been expensive. Two days in Dublin, concert tickets for September in Dublin, £400 car service and last of this years University bills for my daughter. I don't even think I'll make it to Bangor in April.
  7. UTA UG Class 0-6-0 No. 49 (Ex GN No. 149) at Omagh 1963. The ‘Up Platform’ on the right was the longest
on the whole GNR system so carriages were parked in a siding as the curve of the platform was too sharp
to allow safe boarding.
  8. Hi, thanks for all responses. I have been doing a lot of thinking and drawing at the lattice steel work on the passenger footbridge. Its really the only way that I can create a view blocker for the Enniskillen and Portadown line. I just need to use a little bit of modellers freedom and bring things forward along the platform. Will work though...
  9. I'm on the waiting list for production if it takes off again!
  10. No. 49 has been in Omagh too, I have a few pictures in my collection!
  11. Dave182, I could swap the dimensions around and have 400mm behind the shed. Thanks for your efforts, looks good!
  12. North end of layout 400mm - South end 300mm
  13. The photographs show Omagh North layout. The first picture shows the incomplete bridge at the North end of the station where locomotives can exit this 'shunting layout' for the Derry Road. The is where I hope to store and turn my engine and stock. The other photograph shows the south end with the low relief goods shed buildings where locomotives can enter the shed openings and exit the layout (out of view) also. The plywood is open behind the shed. At each end I have limited space but I want to be able to basically turn the engine either mechanically or otherwise for the return to Omagh. Can anyone suggest a simple method, with least trouble.
  14. In terms of stock and building a collection, my plan is to pick up the occasional bargain and also to scratchbuild a collection of wagons that frequented the area, in my case Omagh. I am in the process of identifying and sourcing brass W-irons, axleboxes and parts to build at least one or more of every type of wagon I need. On a small shunting layout like Omagh North, long trains of wagons or passenger coaches are not possible. Therefore, I would appreciate any photographs of wagon detail, if possible from other forum members, please.
  15. I'm really gutted that I didn't get to hear about 00 Works earlier and maybe I could have put in an order for both locos also. There certainly are none left and nothing coming out until the end of the year. When were they first advertised and how long ago were orders placed? I don't suppose anyone has one for sale?
  16. Thanks for that, glad I got it.
  17. Bidding ended just half an hour ago, I've no idea but there are experts here who no doubt will tell me!
  18. Just managed to win this on eBay at £15 Really nice to add my first to the layout from CIE
  19. I just met an old friend Leo Flanagan who in 1950 at 9 months old, lost his father when 5 permanent way men were killed. All five stepped into the path of the oncoming Derry train. It was a foggy morning and visibility was poor. The men were told to clean the line because 'someone important' was expected in the station that morning. He said his father jumped from the line in an attempt to clear the train but was dragged under. His mother visited him in hospital but he died the next day. What a sad day in the history of the railway in Omagh.
  20. Noel, I am assuming that the picture (TOP) is the real thing and the one below the model. The grass looks like it really is growing. What is the ballast type you're using - looks great!
  21. Leslie, I got a sample piece of Andy's 'System' that he kindly made up for me. Unfortunately the small DPDT switches are a bit fiddly for my 'sausage sized' fingers. In the meantime I have simply screwed a piece of electrician block connectors to each wire and it does the job until I find a suitable knob. Thanks for that Leslie.
  22. No better man to advise on paint, thanks Noel. I presume that I'm going for acrylic based paints, I imagine the oil based would be quite messy.
  23. Ok, everyone who has followed Omagh North. My track is laid, wired, tested and points now on mechanical wire and tube system. Am I right to go ahead with painting of the rails? I've no plans on buying an airbrush so can someone advise on a couple of things. 1. The correct paint/make/name to purchase 2. Best brush for the job 3. Do I avoid contact with sleepers?
  24. I saw the A380 in Adelaide airport last year while parked at Adelaide Airport, massive.
