Riversuir226 Posted April 22, 2013 Posted April 22, 2013 (edited) Blame Boskonay for this one:D, I ve been finalising this for what seems like an age but the loco depot is here at last, well on the screen anyway:p The depot I was going to base my loco depot on Cork diesel depot but seen that Mr Scahalane (making a fantastic job of it) has it covered i went for a little part of another depot. I ll be still building Glounthaune on one side and Waterford West on the other side leading into this plan. I ll be building it in stages starting with the depot, then Glounthaune, countryside and then finally Waterford west. Edited April 22, 2013 by Riversuir226
BosKonay Posted April 22, 2013 Posted April 22, 2013 Looking good Tom - what's the overall area? I assume the double line running around is the mainline? If I could make a suggestion, you might want to change the crossing for a slip / point to allow locos enter the exit the depot branch from the left / outside line? (ie: locos can enter from the outside track, and exit to the inside track) It might also be useful to incorporate a headshunt (even a short one) to let locos, or short fuel oil trains shunt between the depot lines? Have you can idea of shed / wash / other feature placement?
Riversuir226 Posted April 22, 2013 Author Posted April 22, 2013 (edited) Played around a bit with it, 4m x 1m is the area set aside for the depot area.Total area for the layout will be 5m x 4m. The sheds are based on the southern end of Inchicore's running shed, practically everything else is condensed or remodelled to fit the space. The shed area needs to be big with the "little" loco fleet that i have;). The buildings will be scratchbuilt, the main 4 road shed will be able to accomadate up to 8 071's, 2 per road, the 2 road shed will be able to accomadate a 201 on each. I ll have various jacks, forklifts around the area and at the back there'll be a car park and a few bits of condemned stock with an excavator doing its evil deeds. Edited April 22, 2013 by Riversuir226
Glenderg Posted April 22, 2013 Posted April 22, 2013 Lovely work on Inchicore, uh, I mean Cork. The loop and the headshunt are a great simple addition. Refuelling road is the loop?
Riversuir226 Posted April 22, 2013 Author Posted April 22, 2013 Lovely work on Inchicore, uh, I mean Cork. The loop and the headshunt are a great simple addition. Refuelling road is the loop? Many thanks Richie, i didn t even think i d be able to get even a portion of the great works into my space, good old google earth and eiretrains were very handy to get the plan of that part of the yard and for drawing out the shed plans, hardest part was ignoring the tranverser at the back of the sheds as id love to use the heljan one. Many thanks to boskonay for the suggestions as they make a big improvement to the general plan. Any other suggestions are very welcome:tumbsup:
Hunslet 102 Posted May 6, 2013 Posted May 6, 2013 [ATTACH=CONFIG]6842[/ATTACH] Played around a bit with it, 4m x 1m is the area set aside for the depot area.Total area for the layout will be 5m x 4m. The sheds are based on the southern end of Inchicore's running shed, practically everything else is condensed or remodelled to fit the space. The shed area needs to be big with the "little" loco fleet that i have;). The buildings will be scratchbuilt, the main 4 road shed will be able to accomadate up to 8 071's, 2 per road, the 2 road shed will be able to accomadate a 201 on each. I ll have various jacks, forklifts around the area and at the back there'll be a car park and a few bits of condemned stock with an excavator doing its evil deeds. The changes certainly make a big difference to the operating potential.If I might make a couple of suggestions to consider,firstly,I am not sure of the purpose of the link line introduced coming of the inner line from Glounthaune,although Glenderg may have called it right.If so,then I think from an operating point of view the loco's running into Waterford West and reversing wrong line to the sheds would be quite prototypical.Secondly,if you change the 2 points at the headshunt for a double slip,one line from the slip can go to the 4 road shed and one line can go to the 2 road shed.This would allow your shed roads to be a bit longer rather than all coming off one point and if you remove the aforementioned link line,it could be possible to have the refueling depot as a 2 track fuel point with a line either side of the fueling point.
Riversuir226 Posted May 9, 2013 Author Posted May 9, 2013 (edited) The changes certainly make a big difference to the operating potential.If I might make a couple of suggestions to consider,firstly,I am not sure of the purpose of the link line introduced coming of the inner line from Glounthaune,although Glenderg may have called it right.If so,then I think from an operating point of view the loco's running into Waterford West and reversing wrong line to the sheds would be quite prototypical.Secondly,if you change the 2 points at the headshunt for a double slip,one line from the slip can go to the 4 road shed and one line can go to the 2 road shed.This would allow your shed roads to be a bit longer rather than all coming off one point and if you remove the aforementioned link line,it could be possible to have the refueling depot as a 2 track fuel point with a line either side of the fueling point. I ve been playing around with the plan again and managed to get the loop parallel to the mainline, as a result the plan will be Inchicore, countryside, Glounthaune(till the n25 bridge), Middleton line & mainline will emerge into Waterford West from the otherside of the bridge and finally a bit of a run by the river before arriving back into Inchicore. The inclusion of the double slip is a major improvement thanks lads Edited May 9, 2013 by Riversuir226
Riversuir226 Posted September 29, 2013 Author Posted September 29, 2013 (edited) Trying to squeez Waterford West into 5m length is a nightmare!!!! Im still thinking of changing the crossover on the left to curved points the shortest of the loops are 15OOmm which fits in with my mk3 rakes of 5 coaches Edited September 29, 2013 by Riversuir226
BosKonay Posted September 29, 2013 Posted September 29, 2013 Looking good!! I've a love of the curved point myself, it lets you create a lovely flow to trackwork.
IrishModelRail Posted September 29, 2013 Posted September 29, 2013 Excellent plans! How did you draw these?
Riversuir226 Posted September 29, 2013 Author Posted September 29, 2013 Excellent plans! How did you draw these? Im using Anyrail which is very good & free up to 5O track pieces;) This is the plan with curved points think it may be better
Glenderg Posted September 29, 2013 Posted September 29, 2013 Tom, I assume this plan links up with the other one on the first page, and if so, how do the 4 lines to the right work. Are the middle two the main lines, and the others loops/sidings/headshunts? I'm very impressed by it. I think the key to good track design is that every major route on its own looks natural. I have one suggestion though. Adding a slip at the end of the top siding and a curved point on the inner line, so that if you're running a goods train from a siding, it makes a smooth transition to the main line. Cant remember the technical term for it, something to do with opposing curves and flange squeal! R.
Mike 84C Posted September 29, 2013 Posted September 29, 2013 That looks very good lots of operating potential, if you are using Peco points they will stand a bit of cutting of the web between the sleepers so you can ease them into places. Watched a guy do that at the Nottngham show and was surprised how well it worked. Mick
Riversuir226 Posted September 29, 2013 Author Posted September 29, 2013 (edited) Here is what i would like to achieve The two outside lines to the left are to the fiddle yard off scene & the inside lines are the mainlines. The city side will be the backscene with the edge of the river modelled so in real terms you d be looking in at the yard from the hillside. Like this view Edited September 30, 2013 by Riversuir226
Riversuir226 Posted September 30, 2013 Author Posted September 30, 2013 For the 2 floodlights i ll be using these:)
BosKonay Posted September 30, 2013 Posted September 30, 2013 Looking good! Those express models towers are gorgeous.
Kirley Posted September 30, 2013 Posted September 30, 2013 Good luck on your layout, it's good to base it on a real location so you can copy what's already there and it ends up more realistic.
heirflick Posted September 30, 2013 Posted September 30, 2013 Here is what i would like to achieve[ATTACH=CONFIG]9405[/ATTACH] The two outside lines to the right are to the fiddle yard off scene & the inside lines are the mainlines. The city side will be the backscene with the edge of the river modelled so in real terms you d be looking in at the yard from the hillside. now thats a potential layout i would pay to see! good luck with it tom!
IrishModelRail Posted September 30, 2013 Posted September 30, 2013 Im using Anyrail which is very good & free up to 5O track pieces;) This is the plan with curved points think it may be better [ATTACH=CONFIG]9395[/ATTACH] Cheers.
