Bob49 Posted June 17, 2025 Posted June 17, 2025 I have just been having a email chat with Wayne from British Finescale who do a growing range of point work. I asked him if he had considered doing some of his 4mm standard gauge points in 21mm using the rail components from his growing EM/P4 range, he hadn't but he might consider it in the future if enough people asked. In the meantime he is making the rail components for his A6 and B7 points available from his website https://www.britishfinescale.com/product-p/milled-switchblades.htm https://www.britishfinescale.com/category-s/1517.htm So with the aid of templot 21mm point kits are now available. Marc 2 5
Mol_PMB Posted June 17, 2025 Posted June 17, 2025 1 hour ago, Bob49 said: I have just been having a email chat with Wayne from British Finescale who do a growing range of point work. I asked him if he had considered doing some of his 4mm standard gauge points in 21mm using the rail components from his growing EM/P4 range, he hadn't but he might consider it in the future if enough people asked. In the meantime he is making the rail components for his A6 and B7 points available from his website https://www.britishfinescale.com/product-p/milled-switchblades.htm https://www.britishfinescale.com/category-s/1517.htm So with the aid of templot 21mm point kits are now available. Marc Interesting, many thanks for asking, and certainly makes things easier for bullhead track. Are there suppliers that will 3D-print the turnout bases from Templot geometry? I'm still getting to grips with Templot myself, but I can see the possibilities it opens up.
Bob49 Posted June 17, 2025 Author Posted June 17, 2025 I'm learning how to do the printing I have the equipment to print but I can't get it to work. I have a A5 Y point I need to print in P4 very shortly. 1
Fiacra Posted June 19, 2025 Posted June 19, 2025 Some nice examples of printed track and points in this RMweb thread. I haven't used Templot, but I assume it would be easy enough (?) to print in 21 mm gauge as well. With tools like this, and the fact that most IRM products have been manufactured with 21 mm conversion in mind, it's beginning to look like modelling in 21 mm could finally be a realistic option for the average modeller. 2
Mol_PMB Posted June 19, 2025 Posted June 19, 2025 I’m learning Templot and selecting 21mm gauge is easy, as is setting your preferred checkrail clearances etc. Some other aspects have a bit of a learning curve but I’m getting there. Personally I don’t have printing capability. Also a lot of the standard templates are for bullhead rail whereas my preferred prototype is flat-bottom. But it’s all getting closer… 2
David Holman Posted June 20, 2025 Posted June 20, 2025 While 3D printing may be the way forward for many things, don't forget about old school stuff like copperclad or ply and rivet sleepers. There is always the C&L method of plastic sleepers and separate chairs too, fixed with solvent, for anyone who wants to avoid soldering. Making track is a long way down my list of favourite pursuits, but on my 21mm gauge Fintonagh layout, I found I could construct a turnout in about an hour, using Code 83 fb rail and copperclad sleepers and Tempo of templates. The latter were the 'standard' three foot radius "Irish EM", printed straight from the website. Although 20.2mm gauge, it was easy to enlarge them to 21mm on the copier. Crossing and checkrail clearances used are the standard one millimetre for 4mm finescale. Both 4mm scale and Slaters 7mm scale narrow gauge wheels are fine with this combination, using 19.2mm back to backs. The main work involved in making your own points is first of all sourcing 21mm track gauges. Mine is a roller gauge, turned on the club lathe by a friend. The other job is filing rail to make the crossing vee and point blades. Neither are difficult, once you've made a couple, though worth noting that C&L supply both as ready made components, albeit only in bullhead rail. Anyone who has made their own track knows all this of course, but for anyone who hasn't, it is not had hard as it might seem. There again, there is Marcway of Sheffield, who are happy to take on commissions for trackwork and for any scale or gauge combination. Prices are about 50% more than Peco. 3 1 1
Horsetan Posted June 20, 2025 Posted June 20, 2025 14 hours ago, Mol_PMB said: I’m learning Templot and selecting 21mm gauge is easy, as is setting your preferred checkrail clearances etc. Some other aspects have a bit of a learning curve but I’m getting there.... There's the PlugTrack function as well, so you could print your own 21mm if you're not too fussed about having the correct 1-in-20 rail inclination 1
Horsetan Posted June 20, 2025 Posted June 20, 2025 4 hours ago, David Holman said: ....The main work involved in making your own points is first of all sourcing 21mm track gauges.... If you're happy to work with P4 standards, then all relevant trackmaking gauges for Irish 21mm are available from Scalefour Society Stores. Code 82 FB is currently available from S4 Stores, the EMGS Stores, and C&L. Code 75 FB is only produced by PECO; I haven't seen anyone else offer it. 1
Rob R Posted June 20, 2025 Posted June 20, 2025 I haven't got any of the code 82 fb to work from but if anyone wants some sleeper bases and can supply a 6 inch length of rail as a sample then I am willing to give it a go. I used Peco code 75 for the previous batch of bases 'cos that is what I had to hand. Is there much difference in shape between the code 82 mentioned above and the Peco code 83 they use for the USA HO track?
Mol_PMB Posted June 20, 2025 Posted June 20, 2025 9 hours ago, David Holman said: The main work involved in making your own points is first of all sourcing 21mm track gauges I have bought a few tiny milling cutters with a view to making some track gauges of the flat type. I just haven’t got round to doing it yet! Unusually, I have a mill but not a lathe - this goes back many years when a friend and I bought one of each with a plan to share resources, and then ended up moving a long way away from each other! I guess I could also make jigs for milling switch blades, given time
Andy Cundick Posted June 21, 2025 Posted June 21, 2025 Simple way bolt and washers check with vernier.Andy 3
Horsetan Posted September 21, 2025 Posted September 21, 2025 On 20/6/2025 at 1:05 PM, Rob R said: I haven't got any of the code 82 fb to work from but if anyone wants some sleeper bases and can supply a 6 inch length of rail as a sample then I am willing to give it a go. I used Peco code 75 for the previous batch of bases 'cos that is what I had to hand.... Code 75 is probably more representative of the Irish network before the modern era of concrete sleepers and continuously welded rail, for which Code 82 would be perfect.
Horsetan Posted September 23, 2025 Posted September 23, 2025 On 17/6/2025 at 8:37 AM, Bob49 said: I have just been having a email chat with Wayne from British Finescale who do a growing range of point work. I asked him if he had considered doing some of his 4mm standard gauge points in 21mm using the rail components from his growing EM/P4 range, he hadn't but he might consider it in the future if enough people asked. In the meantime he is making the rail components for his A6 and B7 points available from his website https://www.britishfinescale.com/product-p/milled-switchblades.htm https://www.britishfinescale.com/category-s/1517.htm So with the aid of templot 21mm point kits are now available. Here's a method for building points using FB rail 1
islandbridgejct Posted November 15, 2025 Posted November 15, 2025 Here's a link to Brian Harrap's very easy way of making crossing Vs: https://www.rmweb.co.uk/topic/38591-quai87/page/43/#findComment-5278749 It worked for me. (Now, if only I could get around to doing some.) 3 1
David Holman Posted November 16, 2025 Posted November 16, 2025 Brian Harrap - a real track guru. Made some triple gauge pointwork back in the day. I think it featured in Model Railway Constructor magazine, so that was quite a while ago. 1
Horsetan Posted November 16, 2025 Posted November 16, 2025 5 hours ago, David Holman said: Brian Harrap - a real track guru. Made some triple gauge pointwork back in the day.... Brian is brilliantly mad. He has worked in P4 and P87, but decided that Märklin's MiniClub Z-gauge was much too rough, so he came up with Proto-220. That's finescale Z, with correct clearances through pointwork and wheels turned down to correct width and flanges. He brought a demo P220 board to one show years ago, and all the pointwork worked flawlessly. This was in the days when my eyes could still focus on things that small. Completely mad. 1 4
GSR 800 Posted November 16, 2025 Posted November 16, 2025 31 minutes ago, Horsetan said: Brian is brilliantly mad. He has worked in P4 and P87, but decided that Märklin's MiniClub Z-gauge was much too rough, so he came up with Proto-220. That's finescale Z, with correct clearances through pointwork and wheels turned down to correct width and flanges. He brought a demo P220 board to one show years ago, and all the pointwork worked flawlessly. This was in the days when my eyes could still focus on things that small. Completely mad. finescale z sounds mad indeed! 1
