Mark III EGV
13 answers to this question
Can I use a normal mk3 for the egv because I can't find a cheap restaurant on eBay
Yes. Too many vents to be removed from the restaurant coach. Mods - should these OT's be moved?
Love the detailing on the ballast and oil tank. Yum yum.
An does the mk3 have to be the long hornby or the old short one
You need a full length one as 1) it's the correct scale length and 2) the parts of the kit will only fit a full length one.
Lima and Jouef also make full length Mark IIIs that can be used.
I have put this out on a topic all on its own as it was starting to take over another topic.
Sean,
If you are in Dublin any time, I have a can of RAL2011 which should have enough paint left for you to finish the job. You are welcome to it. Send me a message with your contact number if you are interested.
Ger.
