4 Whwwl Flat Wagon
4 wheel model flat  3.jpg[ATTACH=CONFIG]11811[
Progress on the first 27101 series flat car which will be used with Bell containers. I'm waiting on one eight inch plastistruct channel for the buffer beams. This will also extend the wagons to a more prototypical length.
Edited by patrick
I should add that inspiration for this conversion came from hidden-agenda's tutorial on ballast hoppers.
Edited by patrick
Yes Patrick, his tutorial on converting Dapol chassis to prototypical Irish wagons must the basis for any accurate wagon conversions.
The buffers are from Dart castings http://www.dartcastings.co.uk/mjt/2350.php which can also improve the SSM brake van . The brake lever bothers me, it should be heavier and will be replaced. A handy etch with brake gear and rectangular plates would make this conversion so much easier.........and decals of course!
Fingers crossed I am working on a fret for the earlier steel floored version, several Prestwins & some 20' containers recently turned up in the wagon shops.
This is the second 4 wheel container flat that I have built. An improved brake lever was fitted and the buffers are at 6 foot centers which in my opinion improve the appearance.
