Kirley Posted December 11, 2014 Posted December 11, 2014 I wish to insert a table from 'Word' into a Post but am unsure of how to do if, if it can be done. I had a look at the 'Table' button but I could not get it to work for me.
snapper Posted December 11, 2014 Posted December 11, 2014 I am pretty sure (assuming this is the same as most other forums I use) you cant copy and paste a table from word into a post but you can create a table in a post manually using the table button. An alternative here might be to attach the word document to the post.
gm171 kk Posted December 11, 2014 Posted December 11, 2014 Or you can open the table up in Word, press FN and prtsc at the same time to capture an image of the entire page including the table, then open Paint if you have it, press CTRL and v at the same time which will copy the image into Paint. Then crop the image so only the table is visible, save it, and upload and post the image to the site.
Noel Posted December 11, 2014 Posted December 11, 2014 Or you can open the table up in Word, press FN and prtsc at the same time to capture an image of the entire page including the table, then open Paint if you have it, press CTRL and v at the same time which will copy the image into Paint. Then crop the image so only the table is visible, save it, and upload and post the image to the site. +1 Or Save the document as a PDF, upload to a hosting site and insert url here inside tags
BosKonay Posted December 12, 2014 Posted December 12, 2014 There are a few options - as have been mentioned, the simplest is probably to screengrab and import the image of the table. You can also export the table in HTML format in word, and paste in the HTML, which the forum might be able to make sense of. The 'safest' bet if you want the table looking as it does on your screen, is to add it as a picture / image.
Alan564017 Posted December 12, 2014 Posted December 12, 2014 As Noel said above, save it as a pdf document and insert it like it was a picture, I did this recently and it came up in the post as a link but was successful.
WRENNEIRE Posted December 12, 2014 Posted December 12, 2014 Can you still get your money back if you press button B?
rebelred Posted December 12, 2014 Posted December 12, 2014 Why would you be posting a table, you're gonna need some size envelope!!! 1
Noel Posted December 12, 2014 Posted December 12, 2014 Can you still get your money back if you press button B? If you didn't know how to tap
josefstadt Posted December 13, 2014 Posted December 13, 2014 Why would you be posting a table, you're gonna need some size envelope!!!
Grambit Posted December 21, 2014 Posted December 21, 2014 If you're still looking to insert a table, the table icon will work, but it doesn't give much in the line of help or an example. Hopefully the below will give a better idea of how the table works. It took a bit of searching to find the "class: grid" part. That was bugging me. I had to figure that out. It's kinda hard to find good examples out there. Anyway hopefully that helps. [table="class: grid, width: 200"] [tr] [td]Left 1[/td] [td]Middle 1[/td] [td]Right 1[/td] [/tr] [tr] [td]Left 2[/td] [td]Middle 2[/td] [td]Right 2[/td] [/tr] [tr] [td]Left 3[/td] [td]Middle 3[/td] [td]Right 3[/td] [/tr] [/table] [table=class: grid, width: 200] [tr] [td]Left 1[/td] [td]Middle 1[/td] [td]Right 1[/td] [/tr] [tr] [td]Left 2[/td] [td]Middle 2[/td] [td]Right 2[/td] [/tr] [tr] [td]Left 3[/td] [td]Middle 3[/td] [td]Right 3[/td] [/tr] [/table]
Kirley Posted December 22, 2014 Author Posted December 22, 2014 Thanks Gambit for your reply. I have already taken other's advice and posted an image of a table on Irish Coaches under Questions and Answers looking for help in filling the gaps. Unfortunately I was very disappointed in the lack of response to my question.
josefstadt Posted December 23, 2014 Posted December 23, 2014 Thanks Gambit for your reply. I have already taken other's advice and posted an image of a table on Irish Coaches under Questions and Answers looking for help in filling the gaps. Unfortunately I was very disappointed in the lack of response to my question. Sorry Kieran. I started to do some work on getting this info together but got side-tracked! Will put something up on the Q&A forum when I get a chance.
