I recently installed sound decoders in a couple of my MM 141's and I thought I'd post this little video comparing the sound from different speakers.
Both locos contain the same Loksound decoders and are both loaded with the same soundfile. The volume settings are identical on both.
MM142 is fitted with a bass enhanced speaker that can be bought from several suppliers. I removed the back from the housing to allow it to fit into the body without any surgery to the loco.
MM165 used a 4ohm speaker from Maplins and was a perfect fit into the cradle on the loco frame. These speakers are available from several other suppliers but I just happened to see them for sale in Maplins and picked up a couple at €4.50 each. The part no. is ABS-224-RC which is a 4ohm speaker but they also sell an 8ohm speaker (part no. ABS-216-RC) which is also suitable for the LOksound V4. (Both speakers will also work with Zimo decoders.)
One thing with this speaker is that you have to secure it into the cradle either through the screw holes provided or with some sticky mastic or Blu Tac. Otherwise the speaker will rattle like crazy!
Anyway here's the video, decide for yourself which sounds better. But I think the Maplins speaker as a but more low end to it.
irishthump
16 answers to this question
