Scale HO.
Hi Would HO Scale 1.87 look out of place on a 00 gauge layout. 1.87 scale compere to 1.76 scale. Is there big difference ? And would HO Loco work on a 00 gauge track ? Thanks Lads.
9 answers to this question
00 track is essentially H O. If you mix the stock HO looks all wrong. If it's all the same stock it's will not look too bad. Things like platforms tend to look wrong , I.e anything that shows up the smaller scale
The track is the same 00 will run on H0 and vice versa.
The scale difference is about 10% - it is noticeable, but whether it's too much difference is up to you.
H0 road vehicles are less of a problem than H0 rolling stock, from an appearance point of view.
My advice would be 'don't do it'! At least, not if you are planning any scenic work. On the other hand, if you are simply planning something 'train set' like, then as the others have said, HO stock will run on 00 track, because the gauge is 16.5mm for both.
The history behind 00/HO, is that HO = 'half 0'. in other words 1:87 instead of 7mm scale, which is 1:43... In the good old, bad old days, 00 was created because British outline locos, being smaller than European and American counterparts, were too small to fit in the then new small mechanisms.
The result of course is that Brtish 00 stock has forever since run on track that is 4'1" gauge, instead of 4'8.5 - which means that Irish 00 stuff running on 16.5/00 track has a gauge which is over a foot/30cm narrower than the prototype.
On the same principle, N gauge[9mm] track is only 4'6, while TT [3mm scale] track at 12mm gauge is only 4'. All this means folk have developed P4 [18.87mm] track for 'proper' 4mm scale or EM [18.2mm] as a reasonable compromise, though with wheel standards similar to 00 fine scale. As that were not confusing enough, in the '50s & '60s there was 'Trix Twin', which aimed to be a compromise & is therefore [i think] at 3.7mm/ft.
Anyone still awake now has permission to run out of the room screaming.
