I was reviewing some stuff on vacuum and air brakes
I was trying to relate the standard US control stand to the brake controls on the 141 GM
The black brake lever was the train brake and the red on e, was the independent brake ( i.e. train brake )
The black one had the typical release position ( vacuum being generated and the vac pipe being emptied ) , Then it had a full service , which was typically the full application of the brakes , Normally vacuum brakes had a " run " position , i.e. no vacuum being generated and the driver typically moves the lever from "run" to full service to modulate the train brakes
I notice that on the independent brake ( which I presume is air operated ) there is an additional position in front of " Release " which is on a spring detent, This is described as " Release Auto "
IN most US controls stands the air brake has 5-6 positions on detents, including release, running , lap, full service and emergency
Looking at various videos , and from memory the 141 drivers, brought the brake lever to the mid position and then back to release and modulated the brakes that way, full service only being applied at the very end . Was it that the brake positions just weren't marked on the irish GMs ?
in the US, there is the concept of " bailingof, or Bailofff" i.e. applying the train brakes whilst leaving off the loco breaks to avoid snatch and jerk. Since the normal way train brakes work is the the train brake lever also activates the engine brakes , did Irish GM engines not have Bailiff control?
The other aside is that on most GM engines there is a amp/power meter , yet I dont think this was every fitted to Irish locos
Junctionmad
for a treatise on how it worked on steam https://books.google.ie/books?id=1w8TAwAAQBAJ&dq=steam+locomotive&hl=en&sa=X&redir_esc=y&output=reader&pg=GBS.PA163 you can knock yourself out on technical detail !!!!!
Dave
Edited by Junctionmad51 answers to this question
