Robert Shrives
  1. yes that is it in one ! I recon that if I make the three yellow unpowered and use the "facelifted" one as the powered - I can use that for two consists. Following on the good works on some on here I will chop up coaches for these vehicles nad keep the NIR etches for passenger sets . Lots of bright idea plans once wagon fleet is progressed and the crate stored away.
  2. Today started well with a tidy up and I thought it will not take long to finish some long outstanding coaches. Several diversions along the way and this was all that got done. Bill Beford sides let into a lima mk 2 and given a quick spray of Halford`s Peugeot Seville orange which gives to my old eyes a match to pictures. The yellow beast is a case of can you guess ! painted in Halford`s Rover Inca yellow. Also a lima coach where model has truly mimicked real life with a MK2c SO hacked to suit along with a casting from MIR let into the outer end and etched drivers window frame - which is a bit chunky but is mid-train so hopefully not too noticeable. Has to be said the Bill Beford Etch was first fitted over a decade ago. And the driver trailer about eight years - wheels do turn very slowly.
  3. That would be nice and for sheer bedevilment of the false god of wish listing let it be Hunslet.... but guess the C class is most likely but both after 80 class... Gets helmet and runs for cover ! Robert
  4. I might have missed it in the 25 pages but today saw a review in Rail Express Dec 2020 issue for the 121 - given excellent review " The design of the model has been carefully considered to accommodate the drive and electronics in the narrow bonnet along with a good level of weight and delicate detailing resulting in a lovely machine which is good value for money." Double page spread on 135 worth a read. I think the quote says it all, thanks due to Mr. Paddy Murphy for seeing this project completed with such style.
  5. Interesting background items with two types of feathers on the signals. Give OCD signal engineers a dose of the swerves.. Loco does help rule one mix and match as well. Robert
  6. Barriers got a dose of grot but pictures show even worse - do I do more open to suggestions ? and mounted. whoops lads required with jacks! and some tanks to go in between!
  7. Thanks ! I will keep an eye out .
  8. Hi Just a quick one , I cannot see anything of my order - GLS is just greyed out and has a flickering sort of water mark passing on the screen- other aspects of site seem ok. Any chance that if you have an order on the way for ballasts and or gypsums could use the tracker to see if it is working or if it is me ! many thanks Robert
  9. I had but sold on the kit for the 071 in 0 and it was a killer model ! Given the excitement in UK 0 gauge but set up costs would make eyes water in a small part of Dublin and with nothing else to run with it - How to make a fortune in the model railway business , start of with a large fortune! I guess in time ITG will be after a real one or one to become part of the National collection. Totally off topic but I guess the GM201 a bit complex for occasional outings but perhaps Cultra would fine a home for 208/9 when the time comes so future generations can wonder/ be horrified ( other emotions available.) Back to the coffee and waiting for postie..
  10. Ok you win, due to a quick fire sale this end just ordered a bundle , thanks , I think ! Spoil bodies should make a good diorama base if anybody wants to offer. Robert
  11. Going off topic but I have a box with 6 Mk3s painted up and Adam Warr at Electra graphics has the available kit to do some. 3D print 71 available - but a bit weak on details and chassis a fun mod. If Dapol get the N 59 out then the chassis would be a good crossover for a 3D print 201. Sorry modes ! back on topic if sales go well good it all helps clear the shelves!
  12. DJD , Now a bit of N would certainly flat spin the big boys ! but the OO/N market share is a 10/1 so if we cannot get a GSV past the boys then N fat chance ( throwing silk glove to the floor - N 071 anybody !) ( Dapol Mk3s a possible commission but no GV.- £80K for tooling ...... ) Dapol / Gaugemaster GWR HST celeb set arrived today and spot on ! ( sorry off topic !!) Robert
  13. Back on 7th July the first photo has right corner the hint of a problem - the two lift door palletised cements. Hard to find decent pics on the web and on here and RM web allowed a read and view of others and improvements - really helpful to me. Castings on the three wagons varied and I was unable to use the crosshandles for the pallet retainer controls and used some small brass brake wheels to hand - seems quite a few got changed in real life. As a result while not finished progress has been made, couple of pics of work up to this morning. One of the three -all now the same with end door runner chain supports and the counter balance wheels fitted. Just need to sort fixing chains to doors themselves - anybody got close up pic ? Kayee 19s on plasticard mounts , hook from Lanarkshire model, 1.5mm channel to add substance to the simple bar moulded, bodies cut down to right height This end has the clamping system part built, need to add a bit of tube - first effort removed as to clumsy in plasticard - now considering bras tube. You can see the two brake wheels - I can see the white metal shafts breaking one did see blob of glue - brass 0.7mm wire will be the way forward. On interest is the pulley on the shaft - A rubber belt drive pulley from Nigel Lawton stable , 4mm dia 1.6mm wide , 1.5 shaft hole - sleeved to 0.7. looks much sharper than the cast offerings - the others I used a dremel as a lathe and cut groves and parted in half to give a simmer affair, to match the photos I found. Nigel`s pulleys recommended. Rake of cements waiting a 141 ! The book "From CIE to IR" by Mark Darby and friends has on page 83 and 94 two inspirational pictures of these wagons at work. Showing livery had deteriorated to faded pale blue and rust with the taughtliner sides looking colourful in comparison.
  14. cheers lads a great bargain and hope you sell out , sadly all cash on gypsums and 121s - and some N gauge that has been on order for several years now up for delivery the next couple of weeks - so will have to pass ! but would have been useful.. Eating dry bread as it is ! I would like to keep a roof over the boxes of models ! Will save up for the 50% A class next year of course ! or 20 % of the class 80 multi pack Sandite option. regards!
  15. Bang goes eating for a month, no heating or lighting as well given its the month of festive COV19 cheer! Advised ballast pack on its way, hope gyps will follow shortly. . Thanks lads !
  16. A chance to revisit the work pile saw work on 12 items this evening, bogie beets, Bell containers, barriers, 4 wheel taughtliner cement and the IFM 47 footer got a bit of details added. - but as supplied as part of the bogie history project. Some quick pics follow. The 4 bogie beet bodies with on left a BT xx number panel and then a height notice and a "Dublin containers" label, all from the Robert Roache stable ! and readable with good eyes but beat my little camera or what I know about it anyway. Will look good behind a 121/141/181 lash up, yes it should be 13 long but layout will, when built not be big enough... The tanks are in the last of a precision paints brunswick but will get weathered after transfers dry and over coated in klear floor stuff- seems quite inert. I muted the blue with just a drybrush of a tan earthy colour and happier as a result. The IFM 47 footer - a 3D print and 3D bogies - added kaydee 19s and rail tec transfers to the buaxite livery along with yellow stripe - not sure that goes with the round buffers but it makes a splash of colour !
  17. Des at Studio Scale Models shows transfers for the Intercity legend and has loco numbers - as does Railtec , who also does a very good lining stripes. The SSM logo is shown for coaches but I guess could be enlarged if asked . The respsray does look good and could be refreshed and then varnished - lack of a protective layer as has been mentioned above was a shame and shortened life of the product. SSM also do some natty etches for headlamp surrounds and the like which would lift the front end. When you put MM alongside it is fun to note driving cab end windows differ everso slightly! with the Lima version taller. I just wondered with the resurgence of Irish modelling in Hornby would consider a "Linmby" 201...
  18. Good luck to the seller! I got mine for £45 from the now closed Ian Allen in Birmingham off the bargains table... I have put this on the watch list just for fun. Robert
  19. Good to see 66s in action, Just a topical thought on the depressed centre PCA should you not be dragging them in sideways !! The RHTT train must be on delivery - only that clean once.. Thanks for showing Robert
  20. Brilliant news , just hope nobody of (in)substance in what might be called the UK government has a bright idea ! - mind you past perf does mean we are pretty safe !!! Sweaty palms at idea of big box gypsums and 121s landing shortly. Can join a MM 201 in Enterprise livery that came this week... might be on dog chews myself .. cheers Robert
  21. I guess anything that stops multiple new border crossings must help in keeping costs under control, I am sorry on a personal level that these changes have been required but it is indeed the "price" of democracy in its many colours at this time. I look forward to IR 121s before three long and hopefully before border doors slam shut.. Sadly A class will incur added costs due this change or "new opportunity" as UK gov sees it in the world of flat spins.. Robert
  22. Dhu Varren - It was the build report and esp grills on yours that inspired me so thanks for showing again! Sadly I guess the sales of rtr fall on the same alter as the weedspray / GSV but by an even bigger margin ... Even a pregrouping British 2-4-0 will sell more if latest news is to be believed ( off topic I wonder if the chassis will be of bigger help to bashers and scratchers out and about / on here .)
  23. As a result the market will cool for a while the implications and ramifications sink in and adjustments made to the lack of easy of purchases. I guess we just had it lucky now the pain that others around the globe trying to trade will be experienced in this bit of the globe. Like the U boats in the early years - the happy days are over. I am sorry that the UK has gone down this isolationist path but at least it does mean it can return albeit a poorer player in future years. Robert
  24. Have to say I got the original dutch van from SF and mugged up the "apendages" and a new end from plasticard and a jouef MK3 donor for the corridor connections and a load of filler - got as far as the grills which to me looked like MK3 Gen vehicle spares - but can you get then on their own - so now looking at how to use suitable plasticard made grills - but having made a start with the Enterprise have enough grill material from the power car bodies - to last a long time or several attempts, this thread could well tempt be to get it out of the naughty toys box for another go.
  25. Good work, some pics show shiny ratchet strap holders - perhaps a later addition but having straps over will give some colour and relief to the bags. I wonder (not looked) if military modellers have anything of used in the way of sand bag walling that could make moulds if the unit train idea gets wings ? Thanks for showing Robert
