murrayec
Everything posted by murrayec
  1. Hi roxyguy I'm super detailing it and painting it black n brown with CIE logo, I know its not Irish but I like them.... Eoin
  2. Hi roxyguy This came to me very crudely hand painted green with enamel oil paint, popped it into MMO in bag, 15 minutes later it came out just as you see it in the photo after a rinse in water Eoin
  3. Yes, don't do it...... You could use DIY stripper but only water base and test first!!
  4. Hi roxguy Try Mr Muscle Oven in a plastic bag, leave for about 15 minutes and squidge it around in the hands while in the bag and see if the paint comes off, wash with water I use this method for most applied paints- I did recommend this method to Peter recently but it did not work for him! Also IPA seems to harden up paint when it drys, so MMO may not work now, also IPA is very risky stuff to use on plastic models- paint can be removed but so can the body shell!! Eoin
  5. Thanks Noel Yes split chassis require a bit more work, The decoder will be connected to two little brass screws that will be tapped into that shiny cut I just made on the top- the wires can be soldered to the screws far easier than to the die-cast metal Eoin
  6. Hi Noel OOPS! I gave a link to the soldering paste! it should have been to the soldering & flux head page..... but one can find it from there. Ordinary electrical solder can be used on brass work, but I recommend don't- its already fluxed with messy stuff and with this solder the flux is going in at the wrong time- with the solder! Its a better join to flux independently, heat the work with the solder on the iron, the flux boils and cleans the metal and then the solder flows where the flux once was. Most brass solders have a little lead in them, lead is good for this, it helps the solder to flow beautifully and create a good join. Just work in a well ventilated area and use a soldering extract fan if possible- sure I used to drink me water through it in my gran's old house when I was a kid and I turned out normal:SORRY: Best flux I use is 12% phospheric & water- see my tips on soldering in the Workbench thread http://irishrailwaymodeller.com/showthread.php/3869-Soldering-Tips-by-murrayec?p=59978&viewfull=1#post59978 Eoin
  7. Bashed some metal this evening.... Split chassis was taken apart to remove the gears, seal up the motor with masking tape and put some packing into the split so that the machine vice would not crush the plastic insulators. First I machined out the recess for the Kadee box on the under of the chassis, this was very close to one of the screws so I went into it, through the brass contact and insulator until I could see the threads of the screw and stopped there! It worked, just enough clearance to get the Kadee at the right height. Next was machining out the space for the DCC chip in the top of the chassis, took off 3.5mm. Now you see it Now you don't The Kadee box is fixed to the chassis keeper plate with a counter-sunk screw, just made it! had to sand the box a bit to adjust the level. and loads of space for chip n wires Eoin
  8. https://eileensemporium.com/index.php?option=com_hikashop&ctrl=product&task=show&cid=956&name=solderpaste-188-deg-50gr-jar&Itemid=189&category_pathway=1124
  9. Hi jhb The body shell above is still in LNER black livery- not painted yet, I'm waiting until all fixups and bits are on before painting.... Here is a snippet of the Humbrol Reference Chart and a photo of the tinlet, its the middle one, the other two are for comparison- light grey and black What do you reckon? Eoin
  10. Hi jhb Yes, I picked up a dark gery for this project- Humbrol Matt 67, look it up and let me know what you think. It looked dark in the shop but in the workshop it looks like it may need a bit of black added! Eoin Edit;- Something went a bit funny with the computer and doubled up!!
  11. Hi jhb Yes, I picked up a dark gery for this project- Humbrol Matt 67, look it up and let me know what you think. It looked dark in the shop but in the workshop it looks like it may need a bit of black added! Eoin
  12. Some progress The body is now all cleaned up and sanded, ready for hole filling and bits to go on. The cab roof overhang was reduced, rain strips were removed, rounded edge formed on the back of the bunker, and moulding seams removed. The moulded dart and number plate were removed from the smoke box door. I then took a look at the chassis to see if it had implications on the changes to the body shell, one thing stood out- the upstand of the split chassis which houses the motor protrudes into the bunker, but should be able to cover it! A small amount of chassis will have to be removed at rear base to get the rear coupler in, a Kadee 146. To DCC this lump of metal is going to be fun! There is no space between chassis and body shell but I have a plan. It requires a bit of metal to be removed on the top of the chassis between the tanks, there is just about enough room for the DCC chip & wires. The motor will have to be hacked by cutting the brush tabs to isolate them from the chassis- the original screws that hold the brush plate are the contacts between these plates and the chassis, which has to be eliminated. Eoin
  13. isbn 978 1 906578 26 8
  14. Hey ....he could be stooped over a live steam loco model doing repairs, with lads in caps admiring the link rods! Eoin
  15. Hi David Looking great, you carved the brickwork! thats like laying the bricks to build it... I vote for a motorcycle repair shop, you know the chap with a scruffy lathe and other oily rusty machines lying around, will fix anything including farm machinery!.. Wills do a kit for workshops its got everything in it, and I saw in the Guild Gazette some time back chaps doing brass etched workshop tools Eoin
  16. Borithe I do, or should I say I did a set of DART hats- mini DARTs on a baseball caps for chaps going to the Dart Championships at the Point Depo a few years ago.... Eoin
  17. jhb Are there any photos you know of showing the brackets? Eoin
  18. Hi David Their just standard 12.6mm Hornby replacement coach wheels, having problems finding better wheels in that size! These wheels are used in the spud also... Eoin
  19. Hi jhb I have a Worsley 'First Second Centre Lav' kit, it looks the business, I'll be making it up very soon as my own chassis will be made to take this body as I work things out.... The Brassmasters 6 wheel chassis look interesting Eoin
  20. Hi Branchlines are here;- http://branchlines.blogspot.ie/ Its an old blog site but it has info and contact information jhb I'm looking at doing a chassis for 6 wheelers for myself but can do them for others- it's slightly on the bench but hopefully will have something to show!! Eoin
  21. Hi DC I'm pretty close to all being sorted, I'm tipping away at it while I finish the other things! Then I have six orders to do- these kits have been on the high shelf for about 2 years now!! I also need to work out my pricing Say about 2 months, though I have said that before Eoin
  22. Noel That's a case of 'Now' and 'Then' If a new build was to be designed anything is possible, all dependant on the group doing it- lets go authentic! or lets go modern and efficient! Eoin
  23. Hi Check out L.D.Porta, he transformed the ould steam engine into a high efficiency, multi fuel burning system in Argentina back in the late 40's. His efforts were stunning but very little accepted by British loco engineers- they never even heard of him. Some of his small locos still run today.... Flash steam boilers are the one, though its not the same as shovelling coal or burning black oil, but very efficient, generating more steam than required to run a loco. These systems are very small would fit in any loco boiler and made of modern stuff. Currently used in modern heating systems for large buildings. They are also portable. On the preservation side of things Alan J Haigh loc engineer and others have designed high efficiency furnace & boiler systems for some of the preserved locos in the UK, one loco they did in North Wales runs it's trip on one bucket of coal where before its modern restoration it required several for the same trip. Eoin
  24. Hi Thanks again for the comments Here is the video of the second bogie without the spring under test, the full chassis and model body on;- Eoin
  25. Hi All Thanks for great comments Yes Kirley, I'm really having fun- I look forward to working on this when I get the time. Painting the patterns tomorrow night and hopefully moulding will start after Eoin
