Everything posted by Horsetan
...and yet these items will suddenly become worthless for Inheritance Tax purposes if the seller drops dead.
There'd be quite a bit of modification of both engine and tender: Driving wheels and bogie wheels Frame width, and quite likely footplate width as well Boiler pitch - the U2 is pitched noticeably higher Differences in cab front and roof curvature Tender outside frames are different from a standard Fowler - the 483 uses what looks like a Johnson tender which would be wrong for a UTA engine anyway
...we still haven't found what we're looking for.
This one suggests there is a fold-up chassis in the pack....
Photographic Website Updates
Horsetan replied to thewanderer's topic in Photos & Videos of the Prototype
Remarkably untouched from the original SBB Re460 / BLS Re465. -
Interesting that the website doesn't mention that omission....
So that's eight etches so far.....
Horsetan replied to Mol_PMB's topic in Irish Models
I think they have to cater for the surprising number of people who still use Code 100 track. -
Not all hornblock bearings are alike. AGW and LRM bearings are similar, but AGW has the sliding groove running down the centre of the sliding surface, whereas LRM is biased to one side. I've used AGW bearings in an experimental LMS Duchess chassis, but I didn't use the 0.45mm guide wire supplied as this makes the bearings too loose in the guides. I found 0.6 or 0.7mm wire to give much better sliding characteristics. High Level bearings are smaller, as are the guides. Then there's the rectangular Brassmasters/Comet bearings which are designed to slot into the frames directly without needing separate guides.
I'm after pre-ordering another Park Royal just in case the first one goes missing.
BEST WEBSITES FOR DISCOUNTED NEW/USED ALL THINGS IRISH MODEL RAILWAY
Horsetan replied to josh_'s topic in Irish Models
You must be joking! Irish stuff is usually beset by price-gouging!! -
My points have transferred over together with my basic details, but that's all so far.
I've just checked into the Accurascale account. The basic details have been retained, but unfortunately my previous IRM order history is not visible, and my existing pre-order for a Park Royal coach is also not shown....unless I'm looking at completely the wrong bit or unless the Accurascale account system isn't supposed to cover that type of thing.
They're not. Charlie Petty stopped production of all of his kits years ago. Something about it not being economically viable to carry on, especially as the RTR lads muscled in on his DMU territory. He earns his money from that bewildering range of DCC sound chips, DVDs and books.
Would you model in 21mm if RTR track and models were readily available?
Horsetan replied to BosKonay's topic in Irish Models
He might need a new printer after doing my batch. Replied. -
The Worsley Works one is probably the one with the most potential, but you have to make your own detail castings.
Same here. -
Count me in for one set. I'd like to see if they can be adapted to take the Dave Bradwell sprung cradles. EDIT to add: and a matching set of 3D-printed detail parts
Making an ‘E’ – the Maybach Diesel Model Assembly thread
Hiding in plain sight? -
If it's there you want to be, I wouldn't be starting from here! -
He can do that anywhere....and frequently has
I frequently had to use them between Victoria and East Croydon when I was acting for clients in the Croydon area. The other thing about the Southern 377s is that they played a major role in some of the Microsoft Train Simulator add-ons: London South-East, and South Coast. I had the original MSTS and "drove" the 377 to various virtual destinations including Brighton, Ford (change here for the open prison), Littlehampton, Bognor Regis, Worthing, etc. Hmm, I think 100mph is equivalent to 161km/h. 128km/h is more like 80mph
Mine was a Sinclair Cambridge Memory. Looking back on it, the digits would have been the correct size for theatre indicators on 4mm scale colour light signals.
My first calculator was a Sinclair pocket thing, with red 8-digit (not LED, but sort of electroluminescent) display. Cost ten quid from Lasky's, the hi-fi specialists, in Oxford Street in about 1976.
